Question about Uniden BC340CRS Base Scanner
Scanner will not accept any freq with 4 digits to the right of the decimal. Is this a scanner limitation or am I just not very smart : ( Thanx
    President:
  • 2,761 Answers
You can enter up to five decimal digits, but the 4th and 5th are limited to 25, 50, or 75. These do not show as full sized digits during programming, scanning, or searching, but should be displayed as small digits to the right of the full-sized numerals - as shown on page 15 of the operating manual. I hope this helps.
Need the manual for your scanner? You can download and print it, at no cost, here:
http://www.radiopics.com/1.%20Manuals/Bearcat/Bearcat%20BC340CRS%20%28Manual%29.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Posted on Nov 11, 2010
Try to enter a frequenci but do not allow me to enter all numbers ex 154.38500 only allow me to enter 154.385
The zeros at the end of the frequency are meaningless (154.385 is the same as 154.385000), so the scanner drops them. You can enter up to five digits after the decimal, but after the third digit it will only accept "25" "5" or "75", and these will display as small digits to the right of the third decimal. -- see the display on page 16 of your owner's manual. I hope this helps.
Bill B.
Dec 28, 2010 | Uniden BC370CRS Base Scanner
Can you help me program in a frequency of 48.28000 that goes to my local utility dispatch in my BCD396XT scanner?
- With the scanner ON and scanning, press the Hold key.
- enter the frequency, including decimal point (48.28)
- Press E
- Scanner will query "Quick Freq Save?" Press E (Yes) and the frequency is entered.
Bill B
Aug 20, 2010 | Uniden BCD396T Handheld Scanner
I'm having problems programming radio frequencies on my scanner.
You didn't mention the make or model of your scanner, so I can't provide a response specific to your unit, but the trailing zero is meaningless, so there's no reason to enter it. Some bands on some scanners will only accept three decimal digits, but the scanner should round off your entry and still receive the intended frequency.
Bill B
May 02, 2010 | Radio Communications
Need freq for scanner for albany ga
Press Manual,enter the channel number, then press MANUAL, enter the FREQUENCY you want including the decimal point, press E to enter,if you make a mistake,press CLR to erase,....You can get the frequency's for your state at www.RadioReferance.com ...hope this was helpful...
Apr 22, 2010 | Uniden BC60XLT Handheld Scanner
How to install new freq in a Uniden BC 560XLT
For the BC 560 XLT, choose "MANUAL" mode on front of scanner. Push the manual button until u reach the number you want to program on your scanner ( 1-16) press the "E" button or "Enter" enter your number i.e. 555.555 in the six digit format with the decimal after the first 3 (industry standard) than press the "E" or "Enter" again. You're done. Hit scan or if u want you can press "REVIEW" to double check your number. Works the same for all numbers or if you want to replace a frequency with another.
Jul 09, 2009 | Uniden Radio Communications
Cant get a answer on how to program my pro-97 scanner
here is a quote from the manual; hope it helps you.
1. Press MAN, enter the bank (0-9) and channel number (00-
99) where you want to store a frequency, then press MAN
again. M and the bank and channel number appear at the
upper left corner of the display (for example: M000).
Press FUNC. Then press e or d. The bank number moves in
the direction of the arrow pressed.
Press FUNC. Then hold down e or d. The bank number
moves continuously in the assigned direction.
Press e. The channel number moves upward one by one.
Or, press d. The channel number moves downward one
by one.
2. Press PGM. M changes to P.
3. Use the number keys and ./DELAY to enter the frequency
(including the decimal point) you want to store.
If you make a mistake, press CL to delete a single digit or press
and hold CL about 2 seconds to delete all digits.
4. Press ENT to store the frequency into the channel.
If you made a mistake in Step 3, Invalid Freq. briefl y
appears and the scanner beeps when you press ENT. Start
again from Step 3.
Your scanner automatically rounds the entered frequency
to the nearest valid frequency. For example, if you enter a
frequency of 151.553, your scanner accepts it as 151.550.
May 27, 2009 | Radio Shack Pro-97 Handheld Scanner
My scanner is locked on hypersearch. How do I get
Answer: Hypersearch can only be turned on and off through a limit or direct search. To turn it off, you should do the following: Through Limit Search:
  1. Press PROG, then LIMIT (SRC). Lo and 29.000 MHz appear. 29.000 MHz is the low end of the scanner's range.
  2. Enter the frequency that is the lower limit of the range you want to search (including the decimal point), then press E (SVC).
  3. Press LIMIT (SRC). Hi and 1300.00 MHz appear. 1300.000 MHz is the upper limit of the scanner's range.
  4. Enter the frequency that is the upper limit of the range you want to search (including the decimal point), then press E (SVC) again.
  5. Press \/ to search from the upper to the lower limit or /\ to search from the lower to the upper limit.
  6. While the scanner is searching or is on a transmission, press H/S.
  7. HYPER should disappear from the display.
Through Direct Search:
  1. Press MAN.
  2. Enter the frequency you want to start from using the number keys. (Press . to enter a decimal point). NOTE: To start the search from a frequency already stored in one of your scanner's channels, press MAN or PROG. Then use the number keys to enter the channel number and then press MAN or PROG again. If you enter an invalid frequency, the scanner displays Error. Press MON/CLR (.).
  3. Press \/ to search downward or /\ to search upward from the selected frequency. -d-, SEARCH, and either \/ or /\ appear.
  4. While the scanner is searching or is on a transmission, press H/S.
  5. HYPER should disappear from the display.
May 15, 2009 | Radio Shack Pro-94 Scanner
Programming Bearcat BC 55XLT Scanner
Ok doc, I'll see if I can walk you thru this as there don't seem to be a manual available for download.
* Push manual button and bring it around to channel #1
Enter the freq including the decimal point. Push the E button to enter the freq into the first channel.
* Push manual again and move to channel #2 and repeat.
If you need some new freq's for your area, go here, click on your state, county, and it'll give you a complete rundown.
http://www.radioreference.com/apps/db/
If you need 10 codes for your area, go here and click on your state.
http://www.nat-com.org/radio.htm
If you need anything else, let us know,, Mechanic
Feb 19, 2008 | Radio Communications
Reprograming
Hi, looks like page 24 of your manual covers that part.
1. Press PGM. PGM appears. Then enter the channel number (1-200) where you want to store a frequency, then press PGM again.
2. Use the number keys and DELAY/. to enter the frequency (including the decimal point) you want to store.
3. Press ENT to store the frequency into the channel.Your scanner automatically rounds the entered frequency down to the closest valid frequency.For example, if you enter a frequency of 151.473, your scanner accepts it as151.470.
If you need a new manual, you can download it here.
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/2000315_PM_EN.pdf
If your needing new freq's to use, you can go here and click on your state and county and get a list of freq's.
I hope this helps you with your question, let us know,, Mechanic
Feb 14, 2008 | Radio Shack Pro-82 Scanner
Uniden BC340CRS Base Scanner Logo
113 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
Greg Cann
Greg Cann
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
