Question about Kodak EasyShare P850 Digital Camera
Insert point for computer connection loose and doesn't function
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Posted on Jun 17, 2011
The little insert in the usb port on my targus dual fan chill mat has become loose. How do I re-insert it and keep it from becoming loose again?
Tawny, If port still functioning, use 2 part epoxy to secure port, be care, no glue inside port.
press the helpful button
Feb 18, 2016 | Targus netbook chill mat dual fan awe39us1
My Dell studio xps 1640 lap has sim card slot for internet connection , when I insert the sim card it doesn't read .so what can i do to make it functional?
i would suggest calling technical support to see if the sim card you are using is even compatible with your laptop, you should not be having this problem if it is.
Jan 18, 2013 | Dell Studio XPS 1640 Laptop
Loose jack connection to speaker
It sounds like you need to get a new jack socket and replace it. It could be just a soldering problem. Especially if you have removed the plug a lot in the past.
Jan 06, 2018 | Edifier Audio Players & Recorders
Pxe-m0f : Exiting intel pxe rom
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Feb 19, 2012 | Acer Computers & Internet
When I turn my Packard bell NetBook on it keeps saying check cable connection no bootable device insert boot disk and press any key but I can't insert anything
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Thenthe hard drive needs to be replaced in the computer/laptop, Windows installedand the computer or laptop's device drivers plus your programs etc. to get afunctioning computer/laptop again.
Feb 16, 2012 | Computers & Internet
When I connect the printer esp5 to the computer it doesn't seem to recognize it, why?
remove the cable and insert again.if it doesn't work change the cable
Oct 29, 2011 | Kodak ESP 5 Printer
Operating system not found Problem
Just load OS CD in to your dvd driver and restart it
  • Press any key..... when show this message
  • And do it as given instruction
Installation
*Note to wi-fi users. I recommend you use a wired connection for everything until XP is completely setup. Disable the wi-fi connection on first boot or as soon as you get the drivers installed. To disable the connection Open your Network Connection Properties, go to Start > Run > type control ncpa.cpl exactly as you see here > right-click on the wi-fi connection and choose disable.
Start your computer and insert the XP disk. If your computer supports booting from a CD you may need to change the bios startup options. The key you press to access the bios may differ depending on the make of your computer. Most use the DELETE key, if not then it will be one of the FUNCTION keys (F1, F2, etc.) Save changes and exit. If your computer does not support booting from CD then insert the first Windows XP floppy disk.
As the system boots you will see a message at the bottom of the screen:
"Press F6 if you need to install a 3rd party SCSI or RAID driver." If you do, follow the instructions.
May 22, 2011 | Computers & Internet
I am trying to connect to my virgin mobile internet via the virgin mobile flash drive, the netbook isn't even picking up that I have the flash drive plugged into the computer.
If this is a Sylvania Netbook running Win CE 6 it is possible that the operating system simply doesn't have a driver for Virgin Mobile cellphone.
The only way I have been able to connect to the internet is via Wifi or a LAN cable plugged into the back. I doubt you will get any other method to work.
Please note the Wifi can be via a Wifi access point on your cellphone, a portable, mobile hotspot that connects via a USB modem or any other functional Wifi access point.
Tom M.
May 03, 2011 | Sylvania G-Netbook
No hdd detected
First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. The hard drive needs to bereplaces in the computer and Windows installed and the laptop's device driversand your programs etc to get a functioning computer again.
Apr 15, 2011 | EliteGroup 661GX-M Motherboard
Kodak EasyShare P850 Digital Camera Logo
13 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
