Question about Beam Industries Vacuums
The electric powerhead for my Beam Central vac shakes or vibrates as I vacuum.Cannot find an obvious problem. Brush strips are not worn.
    Problem Solver:
  • 18 Answers
I imagine the roller is wooden and bent , change roller , metal available
Posted on Jun 26, 2016
    Novelist:
  • 147 Answers
The brush roller itself may be warped, or the bearings may be starting to wear out.
Replacing the brush roller may solve the entire problem.
Good luck.
Mark
Posted on Nov 09, 2010
  • Beamvacman Apr 15, 2011
    I agree ,warped wooden roller
Electrolux central vac powerhead (N106M) frequently tripping built-in circuit breaker. It seems to be only when pushing in one direction, why would the motor draw more current in one direction? (it doesn't...
Have you checked the roller brush. Thread, string, and hair wrapped around the brush will create stess on the motor, resulting in overheating and shut off. Clean the brush and try.
Jan 26, 2011 | Electrolux Centralux Vacuum
Filter bag is full of dirt
its a weight that is supposed to be there ,shake it and forget about it ,this vac is very low maintenence
Mar 11, 2010 | Beam Industries 2900 Serenity Plus Central...
My beater head will not turn on
If you could wire the beater head with out using the hose you could determine if the short is in the hose or in the head. If you wire the head directly and it turns on obviously you have a short in the hose. It is possible to change just the switch and wiring harness in the handle if it is bad. If you have a Vacuum store near you that sells central vacs it would only take them a minute to check your hose for continuity to see if electricity is getting through your handle.
Some heads have a reset button also. Make sure you check that out first!
Oct 10, 2009 | Beam Industries 2775 Serenity Plus Central...
Problems with Beam central vac
My Beam central vac has started turning off after about 10 minutes of use. I thought it was the hose, but the hose in the garage does the same thing, and I've also tried the other outlets, and the same. The canister was just emptied about two weeks ago. I have also reset the breaker, and unplugged and replugged in the system. Could this be a bad motor?
Feb 22, 2009 | Beam Industries 2775 Serenity Plus Central...
Central vacuum power head no work
Looks like a Beam central vacuum www.beamvac.com, and a Kenmore vacuum head.
Reply what problems you are experiencing and I will try to help.
Jan 23, 2009 | Vacuums
I need a new hose for my Electrolux central vac
Do you need a new powerhead too or only the hose? If you need a new powerhead than I would recommend looking at the Imperium Pro Elite Attachment set. It is an excellent quality powerhead and hose. If you only need a new hose than you will need to contact the Aerus because they will be probably be the only company who can sell you a hose that wil be compatible with your powerhead. Their website is http://www.aerusonline.com/products/
Jan 21, 2009 | Electrolux Central Vacuum
Vacuum brush
your suspision may be correct especially if vac is well used/older however may i suggest you turn vac over and investigate by removing the brush cover plate? then you may see what problem is?this could be debri trapped in roller/brush housing? or the bearings/bushes at each end of bruch may be worne or even come loose from their seats whatever is causing the vibes i feel sure you will find on removal of the cover hope this helps/inspires you to diy good luck
Oct 20, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Beam Central Vac Breaker Pops
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=797869
Generic problem for all Vacuums
Posted by tinateggart1 on Jul 17, 2008
The breaker on our beam model 167 central vac popped while in use. Every time I try and restart it, it immediately pops again. What's the problem? Circuit board? Motor? Overheating?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Chances are it is the relay switch on the inside of the Beam Central Vac, if it was a motor, it would not turn on @ all. If it was a circuit board, it may or may not be turned on, but if it will turn on and then pop your circuit breaker than it probably is the relay switch. Please, check with your local Beam vacuum cleaner dealer in your area or contact the Beam website or cust serv @ the phone number listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.beamvac.com/usa/ Owner Support
Customer Service 1-800-369-2326 Phone #
Email: beam.dir-support@beamvac.com
Technical Support: beam.tech-info@beasmvac.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 17, 2008 | Vacuums
I have a one year old Beam central vac. It has supervalves. The handle (connected to the hose stopped turning on the unit. The handle still powers the brush but no longer turns on the suction?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=566201
I have a one year
posted by jon89 on May 02, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Beam Central Vac may have more than a one year factory warranty and it sounds to me that you may have a bad relay switch the Central Vac, if you do it should be covered under the factory warranty. Otherwise, you may have a bad supervalves or a wire came loose, if the hose switch turns on the power nozzle then it may be a bad supervalve or a bad relay and to contact the installer or the manufacturer of Beam. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Vacuums Logo
184 people viewed this question
Top Beam Industries Vacuums Experts
Thatvacguy.com
Jerry Kramer
Jerry Kramer
Are you a Beam Industries Vacuum Expert? Answer questions, earn points and help others
