Question about Swintec Office Equipment & Supplies
The caps lock on my Swintec 2410 typewriter suddenly won't lock anymore. Suggestions?
  • Swintec Master
  • 3,594 Answers
I don't know if tou are talking about shift lock ir caps mode. If it is shift lock gently pry the S.L. keytop off, push down thu the small hold in the middle of the stem if that makes it work make small spitball and push it down the hole, replace the key top. if this dosen't work you need a new contact pad in the keyboard.
DickyO
Posted on Nov 11, 2010
Beep when hitting space
You may have spell check on. goto nadist.com the nAE740 is the same as your T/W you can download the manual.
DickyO
May 23, 2013 | Swintec 7040 Typewriter
Where can I look at a manual for a Swintex 2410 typewriter?
I needed the manual for the Swintec 2410, TOO! I found an add on eBay that happen to show a photo of the metal MODEL label on the typewriter. It listed an additional Model number that led me to the: Nakajima Typewriter AX 150. Seems to be the same machine / model of typewriter with manual online! Manual for that at: http://www.nadist.com/WPT150_Operation_Manual.pdf
Jul 14, 2011 | Cameras
Purchased used Swintec 7040 typewriter. Looking for a user manual for same.
Swintec was made by Nakajima, If you call Nakajima @
800-809-7138 they may be able to help you.
DickyO
Feb 03, 2010 | Swintec 7040 Typewriter
Change a swintec 1186 typewriter ribbon
Move the red lever to the front of the ribbon, remove it, drop the ribbon in place, be sure it goes thru the feed roller on the left, move the lever back, done.
DickyO
Oct 26, 2009 | Swintec Office Equipment & Supplies
When turned on - a beep is all i get-keys won,t work at all. 7040 swintec typewriter
Sounds like a broken wire attached to the carrier motor. If you remove the shell from the typewriter you can see the wiring inside. I suspect one of the wires has come disconnected or broken. Replace the wiring assembly or you can try to strip the two ends of the broken wire and twist them together, then use some electrical tape to secure.
May 19, 2009 | Swintec 7040 Typewriter
MANUAL FOR SWINTEC TYPEWRITER 8014S
Go to the Swintec web site at
Swintec.com
you can order one there.
Feb 03, 2009 | Office Equipment & Supplies
How to set decimal tab - Swintec 7040
Move to the position you want the tab, hold down the tab set key and the mar rel key the display will show an arrow above the decimal. to use tab to the position type number with the. then tab the number will print with the dec. lined up.
DickyO
PS If tou have a fax # I'll send tou that page.
May 27, 2008 | Swintec 7040 Typewriter
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
