Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Oven taking very long time to hit temperature. set at 400 it takes forever (1/2 hour) then gets stuck at 398
  • 1,543 Answers
Replace the oven ignitor. (they get weak after a period of time, and will give those results, or stop heating altogether)
Posted on Nov 10, 2010
On a Frigidaire Gallery oven, it takes forever for the oven to heat to the set temperature. 20-30 minutes. This seems like a very long time. Once it reaches the temperature the oven temperature is fine,...
Replace the door seals, they are the thin rubber strips around the front of the oven when the door is open. They are simple to change as they just clip on.
Jun 26, 2014 | Hotpoint RGB745 Gas Kitchen Range
Oven takes forever to preheat
check to see if both broil and bake elements/gas works
May 25, 2010 | Maytag CWG3100A Gas Single Oven
The oven temperature isn't correct. Ovenw Won't heat up.
has the oven got a fan on it. if so then maybe fan is faulty.
if convection oven then maybe one of elements is faulty
or the thermostat is a problem
regards
richard saupe
Appliance repairman colchester
appliance repairman
Mar 14, 2010 | GE Profile JT915 Electric Single Oven
My Maytag electric oven will not heat beyond a
Your temperature control has gone out and this is simple repair!!
Oct 20, 2009 | Maytag 30" Built-In Single Electric Wall...
My JGBP26 seems to take forever to pre-heat. When
Does your version of this model have the electronic control? -I need the rest of the model number to look it up...
If so, 3 possibilities come to mind:
1. Bake or Broil igniter/glowbar could be bad.
2. Temperature sensor could be bad.
3. Control board could be bad.
Can you see if the glowbar shuts off early or hear the relay click off before reaching temperature?
Does the control display the correct temperature or does it "think" the oven is much hotter than it actually is? If the latter, then #1 is not likely the cause.
#2 can be tested with an ohmeter (should be about 1080 ohms at 70F unplugged from control board).
If #1 and #2 ruled out, then likely cause is the control board (ERC). This is a common symptom on these units. If so, we may be able to rebuild it for you.
Regards,
Bruce
www.fixyourboard.com
Aug 31, 2009 | GE JGBP26 Gas Kitchen Range
Takes what seems to a an extended time to PreHeat either oven.
Sadly ours performs this way also. I've always had GE wall ovens and NEVER did they take very long to get up to temperature.
Has anyone else communicated with you about this problem?
Jun 14, 2009 | Frigidaire PLEB30T9DC Electric Double Oven
Ovens won't heat up beyond 250 degrees.
if you cant program it for more than the 270 you may have changed it from farienhiet ( bad spelling) to celcius. pushing and holding broil may switch it back.
May 02, 2009 | KitchenAid Architect ® II KEBS208S...
Preheat takes forever
http://www.applianceaid.com/nuker.html
click the link  Oven temp sensors sense the temperature is the oven cavity and the temp sensor changes resistance, this change in ohm resistance tells the oven control what temperature the oven cavity at and tells the control to shut off the element or turn it back on. The most common temp sensors used today ( *not all ) are approx 1000-1100 ohm resistance at room temperature ( 70�F )
Some ohm readings and there temperature:
Degrees F    -   Resistance
            100 - 1143 ohms
             200 - 1350 ohms
             300 - 1553 ohms
             350 - 1654 ohms
             400 - 1753 ohms
            500 - 1949 ohms
click this link
http://www.applianceaid.com/elecrange.html
Mar 01, 2009 | GE Ovens
Oven temperature
Replace the bake igniter in the bottom of the oven. It corrodes over time and as the resistance increases it finally reaches a point where the voltage is two low to open the gas valve. It's a ten minute job and the part cost $45-65.
Jan 22, 2008 | Amana ARGS7650SS Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
172 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
