Question about Motorola Computers & Internet
I want to hook up my wii through my wireless connection, it keeps asking for a password or key
  • 1,679 Answers
This Utility program from HP will help you locate few details on your network
1. SSID ( network name )
2. WEP/WPA Key ( Your network security key )
3. The PC/Laptop IP Address
4. Router IP address
5. Which all Devices are connected to your Router/Network Wireless
6. Which all Network are available nearby your place
7. Let you access the Router Configuration
Click here to Download the HP Network Diagnostic Utility
Download the file on Desktop and Run the program ( Ex. File name = HPNDU.EXE )
Follow the Instructions on the Screen and do accordingly.
Regards,
Ron
Posted on Nov 09, 2010
What does error code 51330 mean?
The password or key for your wireless router that was entered is incorrect.
Make sure the password or key is entered into the Wii exactly as it appears in your router's settings. Keep in mind that security keys are case sensitive. A simple typo may be causing the problem.
Jan 06, 2015 | Nintendo Wii Video Game Consoles & Games
I cant get my wi to connect to the internet
Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button. Now, select "Wii Settings" to access the "Wii System Settings" menu.Using the arrow on the right side of the screen, scroll to page two and select "Internet." Select "Connection 1: None"(Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.") Click on "Wireless Connection" and then "Search for an Access Point."(Are you using a wired Internet connection to your Wii console Select "OK" and the Wii will display all the wireless networks it finds.Select the wireless network that is yours. (If you're not sure which is yours, or you don't see any wireless networks, Asked to enter a security key? If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK."Select "OK," "Save Settings," and then "Yes."
The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen:OR Go to this link http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
Aug 15, 2011 | Nintendo Wii Console
I need help setting up internet connection
Let's get you connected!
Aug 14, 2011 | Nintendo Wii Console
How to get connect from your wii to the internet
  1. Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
  1. Now, select "Wii Settings" to access the "Wii System Settings" menu.
  1. Using the arrow on the right side of the screen, scroll to page two and select "Internet."
  1. Select "Connection 1: None"
(Don't see"None" in Connection 1? Click the Connection 1 button, then choose"Clear Settings.")
  1. Click on "Wireless Connection" and then "Search for an Access Point."
  1. Select "OK" and the Wii will display all the wireless networks it finds.
  1. Select the wireless network that is yours.
  1. Select "OK," "Save Settings," and then "Yes."
    • The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen:
Aslong as you see "The connection test was successful," the "WiiSupport Code" does not matter and can be ignored
    • The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates.
Jul 18, 2011 | Nintendo Wii Console
Unable to cannect to the intrenet
Wont hook up to a connection for internet i have wireless asking for a password from belalliant
When hooking your wii up to the internet make sure you are connecting to your wireless network that you have set up at home. Make sure you have the correct password that is set up from your router setup. The password is not usually the same password you use to connect to your router via 192.168.1.1 but a different password you set up from within your router settings. You may need to refer to your routers user manual to set this up.
Apr 25, 2011 | Nintendo Wii Console
I have a wii, and it is asking mefoe a security key or password. how do i find it
If you only have that modem, and no wireless router, the Wii isn't going to hook into your internet.
If you do have a router, the password is the one you need to hook up wireless with a computer or laptop, and would have been set up by you.
Mar 15, 2011 | Arris SURFboard® SB5101 Cable Modem
I am tryin to hook the enternet up to my wii
  2. Now, select "Wii Settings" to access the "Wii System Settings" menu.
  3. Using the arrow on the right side of the screen, scroll to page two and select "Internet."
  4. Select "Connection 1: None"
  5. Click on "Wireless Connection" and then "Search for an Access Point."
      (Are you using a wired Internet connection to your Wii console? If so, click here for specific help.)
  6. Select "OK" and the Wii will display all the wireless networks it finds.
  7. Select the wireless network that is yours.
      (If you're not sure which is yours, or you don't see any wireless networks, click here.)
  8. Asked to enter a security key? If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK." secureaccess.png Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands
  9. Select "OK," "Save Settings," and then "Yes."
        As long as you see "The connection test was successful," the "Wii Support Code" does not matter and can be ignored
    • The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates. Click here to find out what's next!
    • The connection test was not successful - If the test was not successful, you will receive an error code.
      • Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step seven (7) above for more information.
      • All other error codes: Try our error code troubleshooting where we have detailed information on many common error codes. (You can ignore any "Wii Support Code" you receive on a connection test.)
Jan 26, 2011 | Nintendo Wii Console
52030 error message when trying to hook to the internet
Jan 23, 2011 | Nintendo Wii Console
My wii finds my wireless connection. but it is asking for a password or key to be entered, cuz my access piont is sucure. what can i do
You cannot connect to wireless internet due to wep key password because it is secured that requires password. try to connect to your home internet or unsecured connection
Nov 24, 2010 | Nintendo Wii Console
Computers & Internet Logo
107 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Peter Dragonetti
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
