Question about Samsung LN-S4041D 40 in. LCD HDTV
No color just black and white
Tv is on but the color is black and white. where do i insert the video/audio cables on the tv itself
  • Samsung Master
  • 5,568 Answers
Try setting brightness, tint, contrast and color intensity from the main setup menu.
If these have no effect, you have an internal failure beyond your reach.
Some sets have the inputs for external devices partly covered by a snap-off cover.
These are customarily in the back of the set; look for a piece of plastic that seems separated from the rest of the surrounding plastic.
This will normally have a crack at the bottom so the cables can exit with this cover on.
Our set has some inputs (more frequently used) on the side, others where described.
Posted on Jun 17, 2008
How to add an Exterior Speaker to Sony KV-13M10
Welcome to FixYa!
To add an exterior speaker to Sony KV-13M10, you have to have an AMPLIFIER.
  • At the back of your TV you will be able to see 3 RCA output namely = VHF/UHF, Audio and Video.
  • Use an RCA cable and connect to the Audio output.
  • At the back of your amplifier, connect the other end of the RCA cable to an RCA input labeled Audio - L (left, usually in white color).
  • Your speaker should be connected to your amplifier labeled output or audio out. The connection type depends on the make and model of your amplifier. The speaker wires usually come in red and black color. red goes to red, black goes to white.
A simple diagram will look like this:
TV audio out -------------> amplifier audio in (left, white color) amplifier audio out (left, white color) -----------> speaker (black wire) amplifier audio out (right, red color) ------------> speaker (red wire)
Thank you for using FixYa.
Have a great day.
Aug 26, 2011 | Sony KV-13M10 13" TV
How do I connect DVD to TV please
on rear of tv you will have video and audio input jacks red and white are audio yellow is video , make sure they are input jacks the jack will be labled and and on back of dvd player will be red white and yellow jacks that are labled output using the cables supplied with the dvd use the red and white insert them on dvd out corresponding colors and the yellow into the video out, now on the tv take the other end of the cables and insert them into the audio and video inputs again with the corresponding colors audio red and white and video yellow ,,,I hope this helped
Nov 10, 2010 | TruTech Televison & Video
How many wires go from DVD to TV and what colors are they?
Ok. If you have a tv that has a five hole input (green, blue, red, white, red) this is the preferred hook up. That cable is called a component cable. The green blue and red part is for video and the white is audio left and the red is audio right.
If your tv does not have the five hole input it should have a three hole input. Those colors are yellow, white, and red. This is called a composite cable.
You just match up the colors that's all. Your tv should have an input or tv video button on the remote control that would allow you to switch inputs or you may be able to get to video 1 and video 2 and etc by using the channel up and down button and going lower than channel 2.
May 06, 2010 | Sony DVP-NS575P DVD Player
I need to know where to plug in my connectors for my cable box. I have two red ones and one blue one I can't find the right holes to plug them in. I have a green one and white one fixed so I have a black...
This would be 5 pins, red-white is for audio and rest of 3 pins red-green-blue for video signal, it calls component video.
Find out red-green-blue jacks at back of TV that would be label as Y, Yr, Yb
Plug each pin in same color to get color picture.
Jan 08, 2010 | Proscan 32LA30Q Television
Games are in black and white-no color
Make sure the cables are hooked up properly. Audio to the audio input and video into the video input of the tv.
If they are hooked up right and you still only get black and white pictures then the cable might be bad so get a new cable.
If you still have a problem even with a new cable then its something to do with the connector in the SNES or the main board itself.
Ben
May 21, 2009 | Nintendo Super NES Console
DVD plugged into red, white and green(Yellow) TV imputs, results
Yeah no color coz its black and white. Color coding commonly yellow wire for video, red and white wire for audio. It should also be from DVD to TV, video out and audio out going to video in and audio in. And switch the TV to play video and the audio inputted. Maybe TV/Video Switch or button.
Hope it helps
Apr 06, 2009 | Jensen TS2750J TV
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
Color to black and white and back again
Since you're using a composite cable (yellow RCA) that carries both luma (brightness) and chroma (color) information, it's not the cable that is the problem.
That means it's either the DVD player itself, or the TV. If you have another video device (VCR, etc) that you can connect to the TV, try that. If the other device also goes from color to black and white, then it's your TV. Otherwise the problem is your DVD player.
Since your TV only has mono audio (white RCA, but no red) I would recommend getting a new TV if the TV is to blame.
Jun 13, 2008 | Sony DVP-NS57P
New system - no color on screen
the cable colors have to match the tv ones if you have different colors on cables then look for the label on the cables saying video or audio (red)=audio (white)=other audio (yellow)=video EXAMPLE if the cable colors are different than the tv then if the label on the cables say video and the color is blue etc. then you have to put it on the yellow putin on the tv no matter the color. If it dosent work then try holding the cables in many angles try pulling them or anything unlit they work get something to hold them up if that dosent work then i think you should buy new cables. DGKME@yahoo.com for more questions
Mar 29, 2008 | Nintendo Wii Console
Samsung LN-S4041D 40 in. LCD HDTV Logo
54 people viewed this question
Henry  Thomas
Henry Thomas
