Question about Crown I-TECH 6000 Amplifier
I have a crown Itech 4000 and when I plug it in it the green light around the front power button does not light up and when I turn on the power button on the front only the blue "power" light turns on the screen and everything else on the amp stays off. Any ideas on what might be wrong?
    Novelist:
  • 87 Answers
Nice amp. There is a breaker/switch on the back that trips to protect the amp. Turn it off, then back on and see if the green indicator comes back. If the breaker trips again, that's probably an indication of a more serious internal problem.
Posted on Nov 10, 2010
My amp was blinking while it was working then it went off.Now it doesn't power up..Crown Xti 4000
Power supply likely failed. Electrolytics are the primary culprit.
It should have a switchmode power supply, so it is lmost likely the 5 volt section failed.
Sep 17, 2012 | Crown XTi 4000 Amplifier
Tip
How to reset waste ink counter of canon ip 4000?
the procedure to reset waste ink counter of canon ip 4000 printer is as follows,read it carefully step by step:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons.
The LED lights in green to indicate that a function is selectable.) .
2) While holding the Power button, release the Resume/Cancel button. (DO NOT
release the Power button.) .
3) While holding the Power button, press the Resume/Cancel button 2 times, and
then release both the Power and Resume/Cancel buttons.
(Each time the Resume/Cancel button is pressed, the LED lights alternately in
orange and green, starting with orange.) .
4) When the LED lights in green, press the Resume/Cancel button 4 times. (Each
alternately in orange and green, starting with orange.) .
5) Press the Power button. The LED lights in green, and the reset is performed.
(When the operation completes, the printer returns to the
menu selection mode automatically.) .
6) Press the power button to exit service mode.
Note:- if you accidentally press the Resume/Cancel button more than 4 times in
step 4 then just press the Resume/Cancel button at least 10
times and the printer will be returned to step 4 automatically.
BTW the other functions that are available at step 4 are -
press 0 times = power off
press 1 time = Service Test Print
press 2 times = EEPROM information print
press 3 times = EEPROM initialisation
press 5 times = Destination settings (country information, do not play with
this)
press 6 times = Printhead Deep Cleaning
press 7,8 or 9 times = not used in servicing so do not play with these.
press 10 times or more = return to menu (step 4) .
This will help.thanks.
on Mar 10, 2010 | Office Equipment & Supplies
Dell Inspiron Desktop 546MT, green light on the back, but no light on the front
Could be a faulty switch, switch wire connector loose from the motherboard, faulty power supply.
Jan 29, 2012 | Dell Inspiron 546 MT Desktop Computer
My crown Itech 4000 left channel is phasing in and out. Could it be a collection of dust problem?
It is POSSIBLE that it could be a collection of dust problem however my guess would be on a loose wire being vibrated by the sound from a nearby speaker.
I would
  1. Clean all dust you see off
  2. Test and see if problem is corrected
  3. If it isnt check to see if there are any loose wires.
  4. If there are no loose wires. Let me know.
May 07, 2011 | Crown iTech-8000 Power Amp (Certified...
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I need raido wire color code for ford crown victoria 2000
2000 Ford Crown Victoria Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Violet/Light Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Antenna Trigger: Blue
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Apr 05, 2010 | 2001 Ford Crown Victoria
I have a Canon Pixma IP 4000 and keep getting the error message that the ink absorber is nearly full. Print quality is not good even after cleaning. What should I do?
Resetting Ink-Waste Overflow Counter Canon Pixma iP3000, iP4000, iP5000 Printers
1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. (DO NOT release the buttons. The LED light should be green to indicate that a function is selectable.).
2. While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.).
3. While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
4. When the LED light is green, press the Resume/Cancel button 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
5. Press the Power button. The LED lights in green, and the reset is performed. (When the operation completes, the printer returns to the menu selection mode automatically.).
6. Press the power button to exit service mode.
Note: if you accidentally press the Resume/Cancel button more than 4 times in step 4 then just press the Resume/Cancel button at least 10 times and the printer will be returned to step 4 automatically
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 09, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Hello, I cant get the Keyboard on the BTVKB to turn on. Does it have light to indicate charging?  Thanks. John
YOU MAY HAVE TO WAIT UNTIL THE LIGHT TURNS GREEN, LOOK FOR A RESET BUTTON ON THE BUTTOM OF THE KB IT IS THE SIZE OF A PEN HEAD PUSH IT UNTIL THE COMPUTER SAYS IT HAS FOUND A NEW PIECE OF HARDWARE
RODGANDYSR
Mar 05, 2009 | Itech BTVKB Keyboard
Lcd monitor power light flashing with no img. seems 2 be frozen
The display is in safe mode and you will need to reset the display to get the display out of the safe mode. There are 2 different model revisions. Please choose the method that will match your revision. Depending on the revision of the monitor, one of the following 2 methods should reset it to a normal state. This reset generally requires both hands and it is sometimes easier with another person.
If the serial number begins with an A and/or your power button on the far right (5th button from left):
Method #1
1. Unplug the VGA cable.
2. Remove the power cable from the back of the monitor.
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 3 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
5. If the procedure worked, the green light will go to amber and you should see a "No Signal" message on the screen for a few seconds.
Method #2
4. Keep holding the buttons until the 4th green LED blink; then, let go. The green light should be steady when you release the buttons.
If the serial number begins with a B and/or your power button is in the middle (3rd button from left):
Method #1
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see attached picture) and while continuing to hold the buttons, plug the power cable back in.4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
Method #2
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
If you have tried the reset a few times and it does not solve your issue, please Ask a Question to submit a request through the system or call 1-866-752-6271 Option 1 to contact technical support.
Mar 02, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
463 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
