I have an Ariston margherita CD12TX with water leak from a screw in the bottom of the drum. It seems that the screw does not tighten.
    Brigadier General:
  • 4,088 Answers
That might be someone's idea of a leak repair. Take the screw out, clean the hole thoroughly, then repair it with epoxy cement only. Don't use the 5-minute kind, but the 24 hour type. You can get an excellent epoxy from your appliance parts store. Be sure to mix it well before applying. Moderate heat increase will speed the setting time of the material. Hope this helps!
Posted on Nov 09, 2010
  • John Briffa Nov 11, 2010
    That screw holds the element retainer in place? Without the screw holding the retainer, the drum may hit the elemnt when the machine goes into high spin.
Washer mashine Ariston Margherita 2000. Fills drum with water. How can I change water inlet valve please?
Looks like you have the right things. All you need to do is order and new valve set and attach it. The problem could be the power or the switch to it though
Nov 29, 2012 | Washing Machines
I can't stop the dryer from coming on Ariston AL128D, I just want to wash
Hi there, the F button on your washing machine (see manual http://www.gebruikershandleiding.com/Hotpoint-Ariston-al-128-d-margherita/preview-handleiding-431405.html?page=0004) is the clue. if pushed in it won't dry. don't know why, but by trial and error this seems to work
Sep 12, 2012 | Ariston Technologies AL128D Margherita...
User manual ARISTON AB1056TX
ariston margherita AB 1056TX how to check the engine, The drum is not turning at all...
Sep 06, 2010 | Washing Machines
I CAN'T FIND THE FILTER IN THE ARISTON MARGHERITA 2000 AB43 IN ORDER TO CLEAN IT
The filter is usually in the top tray or bottom in the little square.
Hope I helped
Dr Reed
Apr 06, 2010 | Ariston Technologies Ariston AWD12 Front...
Noisy Washing machine drum
To replace bearings is quite a job. iyf your good at diy i rate this as a 9/10 ....A bearing kit is available from makers and instructions.
Apr 03, 2010 | Ariston Technologies AWD120WH Ariston
Problem : Water leaking out from under washing machine
NOTE. PLEASE UN-PLUG THE UNIT FROM THE ELECTRICITY SUPPLY BEFORE ATTEMPTING THE FOLLOWING JUST TO BE SAFE:-
Problem may be due to a blocked dispenser hole. Completely remove the dispenser unit and check for blockages in the hole where the water goes in. If you cant see anything immediate, take the top off. (Remove the 2 self tapping screws on the back holding the top on). Looking at the unit from the front. look inside where you took the top off and locate the rubber hose that connects the dispenser unit to the drum (it's a tight space, but if you look inside , front left you will see where the hose connects to the drum). Remove the hose and check for blockages. (The hose just pushes into the drum). Let me know. I had a similar problem and found that somebody had shoved a sock and pair of knickers down the water dispenser hole. This was also causing the machine to make a loud noise when spinning. Have you also checked the filter in the bottom right hand corner of the unit ? You have to remove the kick panel to get access to it.
Jan 20, 2010 | Ariston Technologies Washing Machines
We have the Ariston Margherita front loader washing machine and cannot get the door open
if the machine is full of water pump blocked or broken if machine empty needs new door interlock or pressure switch blocked or broken
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
May 17, 2009 | Ariston Technologies Ariston AWD12 Front...
Ariston Margherita 2000 "AL109X" very noisy when spinning
To start ensure that machine is well balanced, and that the load is well distributed inside the drum.
If the problem is not balancing, then the most common is a broken drum bearing spider or a bad drum bearing. A symptom of drum bearing problems is the drum having excessive play when you spin by hand.
Also struts and springs must be checked.
Apr 18, 2009 | Ariston Technologies Ariston AWD12 Front...
Ariston Margherita ald 1 40 Error code H2O
H2O is the symbol for WATER and probably indicates a WATER related fault on your machine. A pressure switch is the normal way the machines 'sense' when the level is sufficient. Overfilling suggests a faulty switch, which will need to be replaced by a technician. Also, ensure that the machine drains as it should, if not, the pump filter may be blocked.
Jan 03, 2018 | Ariston Technologies Washing Machines
Washing Machines Logo
284 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
