Question about Blaze BH Voyager Treadmill
Does it matter what order the wires are hooked in?
  • 297 Answers
What order and which wires are you refering to?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Nov 10, 2010
Which wires hook up to the regulated stater
Should be 3 of the same color. Usually 3 yellows or 3 whites Shouldn't matter what order.
Mar 02, 2015 | Motorcycles
I havea LP8500 superwinch. I unhooked the cover wires RED,WHITE and Black and I can remember how they go back onto the solenoids. can you help me. thanks mark
This may help (or maybe not):
The Black wire is the ground wire, and the other two are considered Hot wires, and their
order does not matter - they carry 240 Volts AC.
So, once you identify which terminal on the solenoid is ground, connect Black to it, then just hook up the remaining two Hot wires in any order.
Jul 04, 2011 | Electric Superwinch LP8500 Series Utility...
Tryin to replace heating element. I have 3 wires. 2 black and one yellow. How do I hook them up?
The yellow wire should be the earth wire. Earth is generally yellow/green or just green. This goes onto the frame of the element. The other wires go onto the main 2 pins of the element. There is no polarity so it doesn't matter which order you put them in.
Feb 10, 2011 | GE Ovens
I have a Hatco c-6 and it is set up for 208 volts 3 phase hook up and the terminals are labled 1-2-3 in the heater.. I have 3 phase and the wires are from the 3 phase panel to the heater..the wires are...
Thanks for your reply. The order in which you connect the wires 1-2-3 does not matter, all three terminal block screws will accept any one of the hot wires from the breaker, one hot wire per each terminal screw.
Sep 12, 2010 | Hatco Corporation Compact Electric Booster...
My 1999 tracker just shuts off at any time.It doesn't matter if it's hot or cold. I took it to a shop, they hooked it up to their computor. It showed nothing was wrong. They said it would have to do it...
many engine grounds are tied to the sane point, check these and also check the coil wire
Either of these could be intermittent and they would only show up on a computer if the systems lost their ground connection or the coil wire shorted to the engine block while it was hooked up
Sep 23, 2017 | 1999 Chevrolet Tracker
2000 honda cbr929 i have a new alternator but the end has a plug on it the other end the plug was cut off . i have three wires on each end ant they all are yellow do the have a sequence and if not the bike...
trace your wires coming into the batery from your stator if the wires arent grounded than i would think that you could hook them up and they would charge but i think you have a ground coming off the stator that has to be hooked up look up wiring schematics for your stator to the battery and go from there
Mar 08, 2009 | 2000 Honda CBR 929 RR Fireblade
Generic relay switch
can you describe the relay to me?
the most common relay does have a specific place for the wire to plug onto. hold the relay with the holes that plug into the compressor upright and facing you. now turn the relay so that you are looking at the spade connectors(remember that the holes should still be upright) either one of the spades on the right side is the correct one to plug into.
if this doesnt sound like your relay message me back with a better description or a part number thx peyton
Jan 25, 2009 | Refrigerators
3 wire dryer 4 wire plug how do I make this work
Connect the two hot wires(black and red) to the two outside teminals(order does not matter here as long as you put one wire to each terminal). Remove wire or metal strap from center terminal to frame. Connect white wire to center terminal. Connect green wire to frame. (ground)
Nov 13, 2008 | Dryers
Blaze BH Voyager Treadmill Logo
198 people viewed this question
Top Blaze Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Blaze Exercise and Fitnes Expert? Answer questions, earn points and help others
