Question about RCA RS2664 Shelf System
I have a RCA brand home stereo system. Model number RS2664. Recently, the big speakers (the bass reflex subs) quit working. And I plugged them into the smaller speaker Jack, and they work fine. The subwoofer ports [bottom two ports indicated in purple(+) and black(-)] are dead. No sound AT ALL travels through. Even the negative port doesn't work. Can you help me?
    Guru:
  • 2,178 Answers
The sub-woofer amplifier is probably blown. This is a separate circuit from the other channels. It will need to be repaired. It is likely a bad transistor or open resistor that over heated.
Posted on Nov 09, 2010
  • igotyourpinx Nov 09, 2010
    How much will it cost? Can I put in the new one if I bought it?
  • Rommel Alilin
    Rommel Alilin Nov 09, 2010
    I recommend taking it into an audio repair shop. It requires troubleshooting, isolation, and skill in using proper test equipment to replace. Get an estimate first. I'd say around $85 - $100. If this is too expensive for you, then get another unit.
RCA RT2770 Sub-woofer sound doesn't come
The sub should generally have its own power supply, is it plugged in ???
Feb 16, 2016 | RCA RT2770 Theater System
My powered subwoofer no longer works through the receiver
if you have your front and centers set to 'small' you want your Bass out to be subwoofer only, and the rca jack labeled 'sub out' is the only place to connect your sub to if you want to control the frequencies with your reciever. I dont know the brand of your sub, or the inputs on the back of it to advise you where to connect, but it sounds like it worked for you at one time, but suddenly it does not
Mar 05, 2013 | Audio Players & Recorders
I have a sony HTDDW7600, i cannot get the dedicated subwoofer amp to work. The fan is running on it, but for some reason the only way i can get it to do anything is to unplug the cable that goes from the...
H?,
You have a very good system...one of the best of SONY..SUB does not get activated automatically especially on STEREO mode.DIRECT STEREO Notes • No sound will be output from the subwoofer.
.your system has Dedicated Power Amplifier for 2 Externally Driven Sub-Woofers (200W RMS x 2)..in order to activate the sub woofer amplifier you need to make a selection on the surround modes while you are switching the modes of the surround you will see the speaker position on the display of receiver as well..if you do not see the sub woofer it wont be activated..Sound Field Program (A.F.D) is a good example to test it..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Additionally please follow the instruction on your user manual to activate the SUB ,as is follows..
BASS-OUT
Low-frequency (bass) signals can be directed to the
subwoofer and/or the front left and right speakers
according to the characteristics of your system. This
setting also determines the routing of the LFE (low-
frequency effect) signals found in Dolby Digital or DTS
sources.
Choices: SWFR (subwoofer), FRONT, BOTH
• Select SWFR if you connect a subwoofer. LFE and
low-frequency signals from other channels are directed
to the subwoofer according to the speaker settings.
• Select FRONT if you do not use a subwoofer. LFE and
to the front speakers according to the speaker settings
(even if you have previously set the front speakers to
SML).
• Select BOTH if you connect a subwoofer and you want
to output low-frequency signals from front channels to
both the front speakers and subwoofer. LFE and low-
frequency signals from other channels are also directed
to the subwoofer according to the speaker settings. Use
this function to reinforce low-frequency signals using
the subwoofer when playing back sources such as CDs.
Jun 23, 2011 | Sony MUTEKI HTDDW1600 Theater System
I am attempting to reconnect my home stereo but do not see a cord or wire to connect the bass to the system. is there supposed to be a connective cord for the bass speaker? it is a 530 watt MHCGX99 model...
Hi from one Lakers fan to another 8^) - Yes you do. You need a cable to plug into the
sub-woofer out port on the receiver to the connection on your sub-woofer.
If you can't find the original cable, get a short (three ft.) standard stereo cable (one that has two cables, a white and red). Just plug one of the cables (the red or the white but it has to be the same color on both connections) into the receiver and the sub-woofer.
You'll be ready to pump up the bass.
Enjoy and thank you for using Fix Ya
Mikeywaf
Mar 12, 2011 | Audio Players & Recorders
Need to hook up bass system to 1999 ford explorer can anyone assist me
Probably need an installer - depends on yr/make/model of car - stereo and wiring diagram for sub system. There are lots of questions need answering and if not installed properly, you can certainly damage the stereo, sub system. Subs use a lot of power and improper wiring could cause problems, even fires !
Apr 19, 2009 | Car Audio & Video
Subwoofer.......
Please check your model number, I can not find it on the JVC service website.
This is a powered sub-woofer I think. You need to have a thick black cord that connects the sub to the head unit. Then the satellite speakers get connected to the speaker jacks on the sub-woofer box. The sub-woofer should also be plugged into an A/C outlet on the wall.
The speaker outputs are labeled right there where you connect the speaker wires. You should see a red and black connector for each speaker and they are labeled "front right" "front left" "center" "rear right" "rear left".
If you do not have the thick black cord you need to connect the head unit with the sub-woofer, you can not use this system.
If you look at the head unit and give me the model number on it, I may be able to find the part you need. But I must have a good model number to work with, preferably from the head unit.
Dave
Nov 10, 2008 | JVC SPPWA670 Subwoofer
No bass...
i have the same problem
Dec 27, 2007 | RCA RS2652 Shelf System
RCA RS2664 Shelf System Logo
376 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
