I am trying to feed a video camera into the tv and can not figure out how to operate the video monitor function of the television. The television is a LXI series, model number 43248, it is made by sears roebuck, the chasis number is ctc1668, and it was manufactored January 1992. it has a remote. Please help!
  • 4,472 Answers
First try cycling through all the channels. Or on the remote it should say something like input or something else like that. What does it say near the jack on the tv that you plugged the camera into. Maybe say video 1 or something.
Keep me posted,
Posted on Jun 17, 2008
Please Help!!! Logic 32' LED. L32HE23. STUCK IN STANDBY MODE???
Assume you have lost remote. Look on reverse of both sides to see the manual operation buttons. These will operate all the functions of the normal tv operation, and should be able to select different source feeds, dvd ect. If you still have remote try unpluging tv, wait for a few minutes then plug back in. Hope this helps.
Aug 25, 2016 | Televison & Video
How can I use my lg 3d tv as netbook pc monitor using agp to hdmi cable
Connect your tv to your PC . Turn your pc on and let the os (operating system) boot up. Then find the function key (f1-f12) usually has a rectangle symbol with a line on either side. Example f4. Then hold the function key fn which is located bottom left of key board. And press f4 (if this is your video toggle) it will cycle through original monitor, both original and external monitor, and finally external monitor only. If done again it should reset to original status.
Jan 04, 2013 | Televison & Video
Tcl tv problem were the video output, and after few minutes switching on, no more picture show in the screen, but the audio were still functioning.
Sir try to check the audio video cable at the back of your tv or replace a new one, feel free to send feed back good day and best regards.
Aug 16, 2011 | Televison & Video
How to set 1080i on a toshiba tv
You do not set the resolution at the TV, the video signal you are feeding it has to be 1080i, TV will only display what you are feeding it with, just the same as you set the PC video resulotion at the PC, not at the monitor.
Aug 02, 2010 | Toshiba Televison & Video
How do i get my tv from 480 to 1080p
The video source will determine what resolution the TV will display. You do not adjust the resolution at the TV, it works the same as your PC monitor, the resolution is done at the PC (video source) which feeds the signal to the monitor.
Jan 07, 2010 | Televison & Video
No video feed on tv. trying to view movies from
You will need to change the display to external monitor under display setting settings. First find the monitor and then select the monitor from the drop down list. If you can just specify the the Operating system you are using on the laptop, I can provide more precise advice.
Jun 11, 2009 | Televison & Video
ThinkPad T21 and S-Video Output
the lcd display screen has to be set to 1024x768 60hz refresh rate 1st to be able to send the signal to a tv.
then try the function/monitor on keyboard or boot with it connected.
Apr 13, 2008 | Lenovo ThinkPad T21 2647 Notebook
Video Channel
does anybody ever solve these problems? i keep looking and not a single one has a solution.
Apr 05, 2008 | Sylvania SST4322 32" TV
Make sure you have set the camera to the appropriate mode under the Set Up Menu -- choose NTSC or PAL (for USA it should be NTSC.)  Ensure the proper connections are made to the TV -- Yellow to Video and White to Audio (the camera plays music to accompany your photos).   Make sure your TV is tuned to the proper video channel, which is usually 3.   Now you can turn the camera on.  Now go under the Playback Menu and choose the folder your photos are located in, usually "Current" Now, since there are quite a few options from here, check on page 75 of your manual under Slide Show, and you will see the various options available, such as choosing the music to play.
Mar 26, 2008 | Nikon D80 Digital Camera with 18-135mm...
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
