Question about Sony SDM-HS75P/S 17" LCD Monitor
Monitor works fine on power up then display goes black after a few minutes. The green/orange power led stays green (not asleep). If I turn it off for a few minutes it works again for a few minutes. No bulging capacitors in the power supply.
  • 8 more comments
  • sid3489 Nov 10, 2010
    I tried the booting windows F8 test and found that the B&W text display is normal, ie, the screen does not go blank.
    I've waited much longer than it usually tkes for the screen to go black but it continues to be ok. Perhaps having the back off the monitor changes the heat situation.
    Here's a picture of the power supply. What's the next step?
  • sid3489 Nov 11, 2010
    I have a XP SP3 installation disk.
    I've had the monitor powered up for hours now and it hasn't failed. The only difference between when it was failing and now is that the back shroud is off and the guts are exposed.
    Comments to date ...
    1. Monitor works fine on power up then display goes
    Problem with the Sony SDM-HS75P/S (Silver) 17" LCD Monitor
    Monitor works fine on power up then display goes black after a few minutes. The green/orange power led stays green (not asleep). If I turn it off for a few minutes it works again for a few minutes. No bulging capacitors in the power supply. I tried the booting windows F8 test and found that the B
    The 7 biggish black cylindrical capacitors are all more or less the same temperature. They feel warmish, not really hot. If I send you a picture of the solder side of the board, would that help?
    do I have to be careful taking the board off, unplugged of course. No chance of a big capacitor discharge?
    I've had this monitor on several computers: Windows 7, XP and Linux and it behaves the same on all of them, so I don't see how updating video drivers is going to help. The machine I want to use the monitor on is a Intel D495GSEJT mini-itx and I just undated the graphics chipset software a couple of days ago. I don't have a CD drive for this computer. If necessary I can boot XP from a USB drive, but with some hassle. Are you sure?
    Thanks very much for your help. I'll do what you suggest.
    how hard is it to find a new power board?
  • 10,594 Answers
As you mentioned no bulged capacitors in power board but problem seems with capacitors in power board.
Let monitor work for longer time then unplug it and check each capacitor top for its temperature, if any one is warmer than others, replace it to solve the issue.
Capacitor become dried as well due to heat and dried up capacitor lose its capacitance.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Posted on Nov 11, 2010
  • 10 more comments
  • Shahid Electronics
    Shahid Electronics Nov 11, 2010
    Can you repost your comments, I do not see your comments in question thread.
    Thanks.
    OK, that is why I suggested to take temp test of capacitors in power supply board because temp could be increased when back cover is fixed.
    Since back cover is off and power board is exposed that seems helpful to maintain capacitors temp.
    Thanks.
    And next possible cause would be dry/ cold solder joint in power supply board, unplug monitor, remove power supply board and check solder side for possible dry/ lose solder joint/ connection.
    Thanks.
    Thanks, I got all your comments in question thread, please check my suggestions to solve the issue.
    Thanks, I got all your comments in question thread, please check my suggestions to solve the issue. :)
    Yes, solder side picture will help me to trace any cold solder joint.
    Please email me good focus and full size picture at welcomejee@yahoo.com as reduced size picture wont work to see dry solder joints.
    Thanks.
    Unplug monitor while its working, this will consume all charge of big capacitor in power supply.
    Then you can touch it without any problem.
    Thanks, picture has been received and I'm working on it.
    I do not see any cold solder joint/ connections in picture of power supply board, however, please resolder any solder joint if its color is faded/ dull. Resoldering will refresh its contact. Fix power board in monitor and turn it On, take temp test of capacitors then put back cover temporarily and check, if monitor turns Off, remove back cover and check capacitors temp, you will find few more warmer than others, these are defective and causing problem. Replace them to solve monitor problem.
    I been fixed many tv/ monitors in similar problem and capacitor temp test worked for me.
    Thanks.
    Thanks, I'm sure this will solve monitor problem.
    Power board calls G Board and part number is as follows:
    178917611 ... MOUNTED PWB, G
    Available in Sony Part Store for $98 (seems bit costly)
    Click on above link, put part number 178917611 in search box and hit red search button to get result.
    Thanks.
  • 386 Answers
Hi Good day!!! Try to run in safemode by tapping f8 while booting. and see if you monitor goes blank (same problem)
Well It's a common problem with sony hs75p
the problem is with the power board's transistor in the monitor
people might try some stuff and may get some results, but trust me it's all luck...
i had the same problem, so i gave my monitor for repairs as it was under warranty and the culprit was the power board (sony calls it the 'A' board). The only problem is u need to have patience as u are dealing with sony here i mean, i got my monitor back, but after 2 tries and with many dead pixels and analog signal being greenish...well at least the DVI port worked fine >.>, which they said wasn't their fault ( i was like...right, so the dead pixels generated all by themselves, huh?..by the way if u are wondering...before giving my monitor...they checked the monitor and it's written in the receipt that the monitor had no dead pixels).... so dont be surprised if your monitor comes up with another problem, after giving ur monitor for repairs to sony
in any case it's 'A' board problem
Thank you for using FixYa
Hope my solution helps you thanks
Posted on Nov 10, 2010
  • 1 more comment
  • Adolfo Espinas
    Adolfo Espinas Nov 11, 2010
    OK sorry for late reply because I'm on a field in our company, by the way do you have a operating disc of your system? because we will run some test in your system. before we go to your monitor board because its very complicated there. ^_^ please tell me your operating system you use and then if you have the disc or not?
  • Adolfo Espinas
    OK thanks we will try to repair your system driver of your OS by the way did you try this repair before? if not insert the disc to your cd/dvdrom and then it will boot to your CD drive and then a message appear "Press any key to boot from cd" follow it and then a blue screen will appear it is windows setup . w8 until it load after that there will be 2 repair there skip to the 1st repair option and go for second repair. it will remove all your system files, and replace it with new. note see if your monitor will go blank. reply to me i will be here.
  • Adolfo Espinas
    ohh my well if you don't have cd drive, you can use usb drive as long as it is working and can read your winxp cd. what hassle do you mean? ^_^
Acer AL1716 monitor goes black after a few minutes
if u have an extra gpu try it, becuase i hade the same problem and it was not the monitrs fault
Jan 12, 2018 | Acer Computers & Internet
Hi I wonder if you can help me. I have the flatron L1918S monitor and it was working fine yesterday, however today when i turned on the pc, the monitor flashed the green light on and then goes into power...
When after power up the computer press num lock key if num lock led is flash on and off when you press num lock key then your cpu is working fine.But if it stay constant then open cpu cabinet cover then reconnect RAM memory and processor and it's fan pull cmos cell from motherboard for 10 minutes then reconnect it then check.Make sure motherboard is not ground with cabinet. If num lock led is on and off then when you power up the computer press F8 key 5 to 6 times so you can see safe mode and other menu then enter in "Enable vga mode" then go to display property ->settings change screen resolution to 1024*768 then apply and ok. then check. If everything are fine in cpu then your monitor need repairing. Let me know if you need further assistance. Thanks for using FixYa.
Aug 25, 2010 | LG Flatron L1919S LCD Monitor
Hello, I have a ViewSonic N1700w. I have hooked it up correctly(all drivers downloaded, proper connections, etc.). When I turn it on the power led blinks until there is video or graphics to display. When...
it sounds like the inverter was defective, the monitor will be fine for few seconds then go off but power light still stay on with Green. You can contact with manufacturer for repair service if it still under warranty.
Mar 22, 2010 | Computers & Internet
I have a Dell 1707fp monitor. When I power the monitor on it powers on normally. After a few miniutes, even though the power button is still green the display goes blank. I have tested this on other known...
I just fixed my for less then 1 minute. Here was the problem, when turn on the PC with the monitor connected. The screen appear like normal for about 2 seconds then shut off black but the GREEN power LED stay on, if i press the power off and turn it back on the screen act the same thing.
Here how to fix it, turn off the PC, unplug the monitor power cable then plug it back. The power LED will stay amber. Hold down both brights minus - and plus + same time, turn on the PC, keep hold the - and + buttons press the power button turn on the monitor.
You will see the screen back on, just hold for about 10 more seconds till you see the screen seem to stay on fine then realse them. That's it how i fixed my.....GOOD LUCK
Oct 27, 2009 | Dell E173FP 17" LCD Monitor
Viewsonic VP2030b takes 5-10 minutes to start
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
Oct 07, 2009 | ViewSonic VP2000s 20.1" Flat Panel LCD...
Sir Help me with my Compaq monitor MV520 it won't turn the power led flashing orange to green continously
it could be th epower supply and it could be the monitor.
power ON button should not flash orange regardless what you do. it should stay green. then orange. not orange to green to orange.
try the monitor on another PC if you can fine one.
the other thing is are the 2 monitor similar (CRT to CRT and LCD to LCD), you can't mix the the two, they will work but need different video driver to function correctly.
Oct 20, 2008 | Compaq MV 540 15" CRT Monitor
Monitor goes blank less than a second after turning on.
Beautiful screen, lasts about for a few minutes, goes black. Power button still green. If I turn it off, and then back on, it works again for a while. Any ideas?
May 11, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Sony SDM-HS75P/S 17" LCD Monitor Logo
426 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
