Question about Terminator Aquastar 125FX Tankless Water Heater: FX Hood Horizontal Vent
Bosch AQ 125 FX will not ignite. pilot lites everytime the gas rails do not. turning water on and off 5-10 times uit will ignite and be fine. Any thoughts?
2 Suggested Answers
SOURCE: BOSCH AQ125FX TANKLESS WATER HEATER
Well, after an hour of internet searching, I can give some real advice.
http://www.houseneeds.com/shop/HeatingProducts/WaterHeating/parts/bosch125fxbrasspartsbuy.asp
This website has excellent trouble shooting and illustrated parts breakdowns. They'll even place your parts order too.
For my AQ125FX the problem was the Electronics Control Box (PN 87007207011). I didn't have the 1.3 Volts DC required for the igniter. I also recommend that you check the Water Inlet Filter (PN 8700507059) for deposits and blockage. While there is no specified time change for the filter, I suggest that it be changed at least every 2 years (cheap insurance at $10 a filter). There is a Service / Replacement kit for the Water Inlet Valve (PN 8703406178) if you've got a gummed up valve but it should not be necessary if the following things happen when you turn on the hot water tap:
1. The Exhaust Fan Vent Motor starts
2. The Pressure Demand Micro Switch closes (this is the black device at the very bottom of the unit)
The key to this system is downstream water pressure (demand for hot water) and the Water Inlet Valve and Pressure Demand Micro switch is the heart with the Electronics Control Box being the brains. I hope this helps you with your Bosch Aquastar water heater.
Posted on Mar 12, 2009
How to light the pilot light in a bosch aquastar 125 fx ng tankless water heater
I have the same machine first they said replace the micro switch i did then rebuild the water valve did not enough gas presure had it checked revented the unit the unit is brandnew relubed the water valve idk
May 11, 2014 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Bosch aq 125 bng
sounds like pressure relief valve is stuck closed free of or replace
Sep 24, 2013 | Bosch AquaStar Indoor Natural Gas Tankless...
Bosch aq 125 b manual
Open following links for possible manual.
http://www.tanklesswaterheatersdirect.com/shop/tanklesswaterheaters/manuals/125B_manual.pdf
http://www.tanklesswaterheatersdirect.com/shop/tanklesswaterheaters/manuals/125BS_manual.pdf
When searching for product manuals on the internet, add .pdf to search parameter.
Search: bosch aq 125 .pdf
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Oct 03, 2011 | Bosch Water Heaters AquaStar 125 series...
My Bosch Aquastar water heater has a reoccuring problem where when the hot water is turned on the pilot igniter clicks for several seconds and when the pilot is finally lit, I get a large fireball at the...
sounds like the part he cleaned should get replaced, have him come back and replace the part instead of cleaning it, we some times clean it hoping to save time and money, but if that doesn't fix it it should be replaced.
Jun 17, 2011 | Bosch AquaStar Indoor Natural Gas Tankless...
Our Bosch model AQ 125 Bong water heater pilot light will not stay on. We've tried numerous times. The instruction suggest a service technician. There are none available in our area. What the best...
It sounds to me like your thermocouple is bad . See if you can trace it from the gas valve to pilot light. Remove thermocouple and try to get a exact replacement part. If the length varies don't worry about that. Install new thermocouple and see if that doesn't solve your problem. Thanks
Dec 01, 2010 | Bosch & Tankless Water Heater
Pilot light goes out randomly on 6 year old Bosch Aquastar tankless water heater. When I restart it it may work for a day then goes out again.
The pilot light can be blown out just by the main gas being ignited especially if the pilot flame is a little weak. Some times a bit of grit gets into the pilot nozzle reducing the flow and hence a weak flame. Try cleaning the piolt jet nozzle with a fine piece of wire. You may have to dismantle the jet nozzle to clean it properly.
Aug 30, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
I have a Bosch AquaStar AQ-125-BNG tankless water heater. It has worked very well until recently. The problem: The hot water at the tap is turned off, the flame on the main burner keeps burning and...
there is a small dia copper pipe which has a thermal coupling on it the end of it sits in the flame of the pilot light,
if it fails which it does after about 25-15 months,it shuts down the gas burner
Jul 05, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Looking for Outdoor Tankless propane water heaters
it will tell you right on the box if it for indoors or out doors either way they have to have a cover over them,,
Jun 09, 2009 | Bosch AquaStar Propane Tankless Water...
Tankless water heater pilot light will not stay on
It is most likely the water valve stuck open, telling the controls to heat water, that it thinks is flowing through it, but without actual flow it overheats. Depending on how comfortable you are with taking it apart yourself, you could open the valve to see if it just needs cleaned out, or if you have a ruptured diaphragm or some other cause.
Jan 25, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Terminator Aquastar 125FX Tankless Water Heater: FX Hood Horizontal Vent Logo
254 people viewed this question
Top Terminator Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Terminator Kitchen Range Expert? Answer questions, earn points and help others
