Question about HP LaserJet 2550L Printer
I had not used my HP Laserjet 2550L for a year. When I use it now, blank pages appear.
    Guru:
  • HP Master
  • 2,178 Answers
Remove the toner cartridge and shake it then re-install. If you get a streaked image, then the toner may be out or low.
Posted on Nov 09, 2010
Printing blank pages
MAKE SURE THAT ALONG WITH THE SOFTWARE YOU INSTALL THE PROPER DRIVERS
Oct 23, 2013 | HP LaserJet 2550L Printer
HP LaserJet 1020 PATCHES ON PRINT OUT
if the patches are random, and not ghost images duplicating down the page, you may need to take out the toner and gently shake it - tilt it right 90 degrees, then left 90 degrees, etc a few times to redistribute the toner...
failing that, the toner could be almost empty.
otherwise, check and see if they are duplicating down the page.. ie the same image defect 3 or 4 times down the page, if so, it is probably one of the drums.. toner or fuser drum...
Hope this info helps.
May 15, 2012 | HP LaserJet 2550L Printer
My HP laserjet 2550L is set on Amercan 'letter format' after a reset. I want to print on A4 paper which causes a problem after a few pages. If I change to A4 in the toolbox, on the surface it looks ok but...
Hello,if you are using Microsoft Word, check the page setup and printer settings in Word as you have the option there to change paper size as well as on the printer.
Hope this helps
nicam49
Jan 17, 2011 | HP LaserJet 2550L Printer
HEMOS CAMBIADO DE ORDENADOR Y QUERÍAMOS INTSTALAR LA CAJA DE HERRAMIENTAS DE LA LASERJETCOLOR 2550L PERO NO ENCUENTRO EL CD. CÓMO PODEMOS INSTALARLA?
Vaya a www.support.hp.com
Ponga el modelo de su impresora (laserjet 2550l) y oprima "next"
Ahora podra descargar los "drivers", descargar el manual, y mandar pedir "software"
Suerte!
Dec 28, 2010 | HP LaserJet 2550L Printer
Did the Laserjet 2550L make duplex prints? if
It is called a manual duplexing option, the bottom rung of the duplexing ladder, you phisically have to take out the peice of paper after one side is printed, turn it over and reinsert it
http://www.retrevo.com/r/258bh050/38/Printing+on+both+sides+%28duplexing+manually%29#q=HP+2550L
Sep 09, 2009 | HP LaserJet 2550L Printer
Help, My Hp 2500L won't print
if you have a new cartridge in it it has to be primed with a test page. If it still doesn't work then the cartridge may be a defect.go through the "clean heads" process and see if that makes a difference.
Oct 12, 2008 | HP LaserJet 2550L Printer
HELP! HP 2550L printer needs installed with NO CD!
You need to download and install the drivers and software of the printer. They can be downloaded here from HP. Just pick your operating system.
Jan 27, 2008 | HP LaserJet 2550L Printer
HP 2550L Printing Problem
check to be sure you tool the strip out and that it's seated correctly
all the way down.
Dec 07, 2007 | HP LaserJet 2550L Printer
HP LaserJet 2550L Printer Logo
95 people viewed this question
Ben Johnson
