Question about Jensen KA-4 Car Audio Amplifier
Jenson ka 4040hlx protect light is on - Jensen KA-4 Car Audio Amplifier
Scan the film sound "ka!ka!ka!" from the top light box, and the light box stop at 1/4 position. As the result, the scanning picture over exposure. Leo
Some scanner prescan, if the object is only 1/4 of the size of the area this is normal. If not you have tracking problem.
Aug 13, 2014 | Epson Perfection V700 PHOTO Flatbed...
Radio code ford ka
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Ford service centre and get them to enter this code for you.
Mar 14, 2013 | Car Audio & Video
Remove write protection from kingston mmc memory card
mera 2 gb ka king stone ka mmc farmat nahii hu raha hey jab farmat karta hu too write protect ka option a jata hey tell me what i do
Oct 30, 2010 | Nokia 6600
Hazard warning lights and horn on a 2006 Ford KA don't work
Hazard warning lights and horn on a 2006 Ford KA don't work but indicators do
Aug 20, 2009 | 2003 Ford Escort
Need wiring diagram for jensen ka 4040hlx 500 watt amplafier
Hi Rordawg01
Pretty straight foward. You need to connect power via a heavey duty cable direct from the battery to 12v terminal. Fit a fuse in line at the battery the same value as that on the amp(30a is good). Ground(chassis of the vehicle to the earth/ground connection. The remote terminal on the amp connects to your head unit to turn the amp on and off when you turn the stereo on and off. . You will need to supply signal via rca sockets to the amp also, these then connect to rca connectors that can be found at the back of your head unit.
Dont forget to disconnect the battery when doing 12 volt wiring on your car. If you wanted to get up to speed with installing car electronics, check out this site. It may help you get up to speed.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you still have problems, before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jun 02, 2008 | Audio Players & Recorders
Protection light comming on.
I'd be inclined to check to make sure there isn't a short circuit somewhere in the output lines. Maybe a wire is crushed against the car's body or bare wires touching or badly fitted RCA plugs. All of these things could activate the protection circuit. If you have a multimeter it would make life easier but don't forget your speakers will show up as 4 ohms so that's not a short. BMW
May 31, 2006 | Jensen 100W x 4 Amplifier KA5 Car Audio...
Jensen KA-4 Car Audio Amplifier Logo
167 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
