Question about HP LaserJet P3005n Printer
When you send something to print it stops, the attention light blinks red and once you click on the green CHECK button it prints again. Why does it act like its jamming?
  • HP Master
  • 7,733 Answers
  1. Slide the paper-width guide to its widest position, and then pull out the paper tray extender. Figure 2: Move the paper guidesWhen you send something to print it stops, the - c00648140.gif
  2. Insert plain white paper into the input tray with the short edge forward and the print side down. Slide the paper forward until it stops. Figure 3: Insert paper into the productc00636180.gif
    CAUTION: Make sure the product is idle and silent when you load paper into the input tray. If the product is servicing the print cartridges or otherwise engaged in a task, the paper stop inside the device might not be in place. You could push the paper too far forward, causing the product to eject blank pages.
  3. Slide the paper-width guide inward until it stops at the edge of the paper. FigWhen you send something to print it stops, the - c00636178.gif the paper guidesc00636178.gif
    NOTE: Do not overload the input tray; make sure the stack of paper fits within the input tray and is no higher than the top of the paper-width guide.
Posted on Nov 10, 2010
Samsung ml1640 laser red light blinking
samsung ml1640 laser red and green light blinking continuously and printing not happening
Jul 02, 2010 | Samsung ML-1640 Monochrome Laser Printer
Paper stops half way
Please check for torn piece in the carriage which is causing the error
Jul 06, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
My printer mp160 canon is not printing. E is blinking on the printer and the page appears as if it is going to print and it just stops. i reinstalled the cd. i used the refill ink and it was printing but...
Ok try this see if it will help.
  • Turn off the canon printer
  • Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  • Hold the Power Button, release the Resume Button.
  • Not releasing the Power Button, double click “Resume” and release Both Buttons.
  • Click “Resume” for Four times
  • Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again.
  • Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    Jan 17, 2010 | Canon PIXMA MP160 All-In-One Printer
    'Printer out of paper' message
    on note pad or word you should select the paper size first because it might set to a different size. when you click file click print click properties or printing preference and choose what size of paper you have in your tray and then click ok. print ok.
    check the printer paper tray setting to make sure the paper tray side guide is right agains the paper. I hope this will solve your problem.
    HH
    Aug 12, 2009 | HP LaserJet 5p Printer
    MY PRINTER : COLORJET 2550L DOES NOT START TO PRINT AND A RED LIGHT SHINES (NEXT TO THE GREEN ONE THAT SHOULD ). IT STARTS PRINTING ONLY AFTER I STRIKE THE FEEDED PAPER INTO THE PRINTER'S FEEDING TRAY. I...
    Solution :
    1. Reinsert the print cartridge. If the print-cartridge light is still blinking but the Attention light is not on, turn the printer off and then back on again.
    2. If the problem persists, replace the cartridge. If the print-cartridge light is still blinking but the Attention light is not on, turn the printer off and then back on again.
    3. If the problem continues, contact HP Customer Care for technical support at http://www.hp.com/support/clj2500 or http://www.hp.com/support/clj1500 . Or see the flyer that came in the printer box for additional contact information.
    Jul 26, 2009 | HP Color LaserJet 3500 Printer
    Epson CX7450 paper jammed
    In some cases, this is cause by a nozzle that got clogged during the jam. You can run head cleaning utility either from the printer or from the computer.
    1. Make sure that there are no error lights (red lights), just a solid green light.
    2. Take out all cartridges from the printer and put them back in.
    3. Once the printer is done charging the inks and you have a solid green light again. Hold down the Ink Button for 3 seconds, after this you'll hear movements within the printer, this is the head cleaning process.
    4. Once the printer stops making noises, and you have a solid green light again. Power Off the printer
    5. Once the unit is OFF, hold down the paper button while turning the printer ON. Once you see the blinking green light release BOTH buttons. The printer will then print the nozzle check pattern.
    * Note: The nozzle check pattern should display all colors in the printer and there should be no gap or break between the lines itself.
    6. Do this step 3-4 consecutive times. and that should resolve you concern
    Feb 21, 2009 | Epson Stylus CX3200 All-In-One InkJet...
    Keep getting 10.00.03 supplies error, have tried turning the machine off and on several times.
    10.00.03 - The printer cannot read or write to the yellow print cartridge memory tag.
    Solution:
    Turn the printer off and then back on again.
    If error returns, remove all print cartridges and turn off the printer.
    Cold reset the printer:
    Turn on the printer.
    Watch the control panel.
    When the memory starts counting, press and hold the green (Select) button.
    Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    Release the check button when the Ready, Data, and Attention light are on steady.
    The control panel will display SELECT LANGUAGE.
    Press (Down Arrow) button once. The control panel will display COLD RESET.
    Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
    Wait for the printer prompt to install each print cartridge.
    This should return the machine to operating condition. If you still get the error, replace the yellow print cartridge.
    Jan 15, 2009 | HP LaserJet 4600dn Color Printer
    TLP2848Z blinking red, will not print
    1: Is it a TLP2844 or a TLP2844Z.
    Operationally they are completely different printers. TLP2844 uses ELP (Eltron Programming Language. but TLP2844Z uses ZPL (Zebra Programming Language). You need to calibrate the printer to the labels.
    Calibration:
    If its a TLP2844. Load media. Connect power.
    Hold down feed key, power on, count one, two, release feed key. The printer will go through a calibtation routine and print config label. IMPORTANT - When it prints this label you must press the feed key and see the message OUT OF DUMP. Your printer will now be calibrated. Check this by hitting the feed key a few times and printer will feed one label each time feed is hit.
    Calibration:
    If its a TLP2844z.
    Load media. Turn printer on and wait for green light (Approx 1 minute)
    Press feed key and keep it pressed until green light blinks once, then twice, now release feed key.
    Dec 22, 2008 | Zebra TLP 2844-Z Thermal Label Printer
    Green ready light on, but will not print
    When you refilled the paper, did you load a different size paper? Try this: on your PC, left click on START, then left click on CONTROL PANEL. Next, left click on PRINTERS. Find your BROTHER on the printers page and view the status box. Does it show READY? Are there any DOCUMENTS pending? Left click (you may have to click twice)on the BROTHER icon. The PRINT QUEUE appear, showing any documents waiting to be printed, and their status. If anything is in the queue, cancel all documents so the queue is clear. Next, RIGHT CLICK on the BROTHER icon . On the drop down menu,left click on PRINTING PREFERENCES. Make sure the settings match the paper you have loaded in your machine. If something is not right (Paper size, orientation,etc) the machine will not print. Carefully check all the settings and correct as necessary. To test, first click OK to exit PRINTING PREFERENCES. On the same menu, left click on PROPERTIES. On the GENERAL tab, left click on TEST PAGE button to generate a test print.
    Aug 09, 2008 | Brother HL-2040 Laser Printer
    Ink absorber
    E27 = Waste ink absorber full or platen waste ink absorber full
    Reset Your printer.
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Turn off the printer ( "Power" button).
    Hold the button "Resume" (red circle in the triangle), add a printer (click "Power") - an indicator light green.
    Hold the "Power" button, release the button "Resume".
    Not releasing the "Power" button, double click "Resume" and release both buttons.
    Four times click "Resume"
    Once you click "Power", to confirm the selected action (reset counter absorber). To disable the printer "Power" button to click again.
    Aug 02, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    HP LaserJet P3005n Printer Logo
    160 people viewed this question
    Seeker5211
    Seeker5211
