Question about Frigidaire ATF6000ES Front Load Washer
DR ERROR Where do you order a door lock, will the place a bought it carry it or will i need to order from manufacturer? also, is there anyway in fooling the washer to think the doors closed? unplugging the door lock?
  • 413 Answers
Parts for all major brands of appliances can be purchased through Sears or an online retailer. The door lock has sensitive mechanisms that make it difficult to bypass.
Posted on Jun 17, 2008
Carriage assembly is broken. need a new one
The replacement carriage can be ordered either through a retailer that carries this brand or from the manufacturers or a distributors website. If you have the owners manual it may list the part number otherwise you can look it up using the model number
Jan 11, 2014 | Genie Company Garage Door Parts Genie Gwkp...
How do I take the right rear interior door panel(s) off to fix the electric lock. I need a diagram probably...
The panel is held on buy little plastic pop in pieces. They are a pain in the anyway. Start with the screw in the armrest and door latch area. Check to see if there are anymore screws hiding on the door panel. SLOWLY use a screwdriver or a paint scrapper at the bottom of the panel and slide it under the panel lip. Again SLOWLY pry outward on the tool, the panel will resist until the plastic clip pops. Repaet this all around the panel. Sometimes the plastic clips break, but Pep Boy or Autozone carry replacements, thank goodness!!! Replacemet is reverse of removal, just make sure the clip and its hole are lined up before you tap it back into place, that is another high probability break point for the clips.
I hope this helps you out.
Dec 22, 2010 | 1996 Ford Explorer
The door switch has failed and must be replaced. the switch information is OMRON RE2 1054H5 C-15G-3C25 15A 1/2HP 125 250 VAC 0.1A 125 VDC. Is there a place somewhere that I can order this switch from?...
In Canada B & E industrial electronics (Calgary) carries the switches typically used for microwave doors (~$5). Reliable parts carries the whole assembly of 3 switches and the plastic interlock housing for about $25. Probably worth calling your local industrial electronics supplier. Never purchased online but should be available from any online electronics reseller. Honeywell is another manufacturer (see Microswitches)... HONEYWELL HIGH FORCE PIN PLUNGER 15A Part # V71C17D8
Allied Electronics Online (US) carries the same switch which is interchangable with yours. Honeywell / MicroswitchSwitch, Miniature, Basic, SPDT, PIN PLUNGER Actuator, QUICK CONNECT TERMINATION
(Are you getting all these numbers off the switch itself as the OMRON RE2 sounds a bit like a relay number...?)
Oct 21, 2010 | Panasonic NN-S954WF Microwave Oven
What is sensor magnet in LG 6.5 kg washing machine? Recently I got a dE error and when technicians attended, they said, there was problem to closing door lid. To resolve this, technician replaced sensor...
There really is a sensor magnet that is necessary for door lock mechanism to work. Not sure about service call charge, but if it works the he did fix it anyway
May 19, 2017 | LG WFT1071TP Top Load Washer
Hi i need a power door lock module for lx honda accoe
the cheapest place would be to check with the junkyards.... but i also know that advanced auto parts carries a wide variety of door lock switches
Mar 22, 2010 | 1992 Honda Accord
Hi just wondering if you would know a good site where i can get a set of spare plastics , after market at a good price ? thanks scott.
Acerbis makes plastics for Husky's. Try:
www.westsideracing.com
Look under category: Acerbis Apparel and Accessories.
There are also a lot of other online shops that carry Acerbis products. They may not stock them due to demand, but can definitely order them for you. Likewise, so can local motocross shops such as the ones I have locally here in Minnesota.
www.bobscycle.com
www.denniskirk.com
Again, you're just looking for anyone who carries Acerbis products. Many of the online ones will list yours since most do not carry things in stock anyway and just have them drop shipped from the manufacturer whnen you place an order (regardless of make/model of MX bike). It's how they keep their overhead low.
Jan 25, 2010 | 2005 Husqvarna TE 510
I locked my keys in my 2004 Grande cherokee. Automatic door locks. What kind of door mechanism is it?
Just take your VIN # to a dealership, and some proof that it's your vehicle, and they can cut you a new key. Start fooling around trying to unlock it, and you'll end up repairing a bunch more stuff inside the door. They aren't like they used to be, in fact, the cops used to open them for you, now they won't touch them in most places.
Aug 11, 2009 | 2004 Jeep Grand Cherokee
Smahsed screen
First of all: on most cell phones it is possible, for a technician to change the screen.
Most likely the store where you bought/ordered the phone can put you in contact with the manufacturer of the phone, or a place which carries out repairs on LG-phones.
Dec 18, 2008 | LG KG220 Cellular Phone
Bought house from bank and trying to retrive lock combination
I'm trying to remove a unican lock from my door but I can't see how to get the handle off. any suggestions?
Nov 12, 2008 | Simplex Kaba Ilco Unican 1000 keyless...
Need owners manual
You can order the manual from any Babylock Sewing Machine dealer, look in the Yellow Pages for one local to you, if there is none then look in the 800 pages for Tacony, they are the manufacturer of the Babylock machine, I think they are in Fenton, Missouri.
Oct 27, 2008 | Baby Lock Imagine
Frigidaire ATF6000ES Front Load Washer Logo
155 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
