Question about Dell 924 All-in-One InkJet Printer
I am getting cartridge error 1203 on my printer
  • blkelly2 Nov 11, 2010
    I have already done this and I even uninstalled my printer and reinstalled my printer and I still
    get the cartridge error 1203 and my printer is a 946 but I did use the instructions you sent
    me and that is why I contacted you cause it did not work. I even used air and blew it all out
    in case of dust or whatever.
    President:
  • 1,216 Answers
Error 1203
is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
It mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
If you do not have a manual and need a manual juat click here to download your manual.
Posted on Nov 11, 2010
  • Aviral Saxena
    Aviral Saxena Nov 11, 2010
    You should try another cartridge may be fpom your friend's printer or office just for a check.
    this will clarify us whether the problem is with cartridge or printer so that we can proceed accordingly.
    good night...
  • Aviral Saxena
    You should try another cartridge may be from your friend's printer or office just for a check.
    good night...
Printer says cartridge error: error 1203
Remove both ink cartridges and check the bottoms to be sure all of the tap is removed. Small pieces of tape frequently are stuck to the cartridge bottom causing errors. Confirm you have the correct cartridges (# 34 for Black(HIGHYIELD) and #33 for color). Reseat the cartridges and try again.
Sep 06, 2010 | Lexmark X7170 All-In-One InkJet Printer
Cartridge Error # 1203 when replacing black ink cartridge
It sounds like the printer thinks it is not a genuine ink cartridge. Fit a Lexmark cartridge to cure it.
Jul 16, 2010 | Lexmark X8350 InkJet Printer
Printer does not work. is Lexmark x4270 . I replaced cartridge and it shows on panel this message: Error #1203
There are 3 step to repair lexmark 1203 error
If you got lexmark 1203 error then there is a 94% chance that your computer has registry problems. To repair lexmark 1203 error you need to follow the steps below:
* Step 1 - Download a lexmark 1203 error repair tool,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair lexmark 1203 error.
Here are the url of lexmark 1203 error repair tool:http://www.fixerrorquick.com/ttfix-lexma… http://www.fixerrorquick.com/ttfix-lexma…
Jun 29, 2010 | Computers & Internet
Cartridge error 1203
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
or
Hope it will work for you take care all the best Pineworks
Mar 13, 2010 | Lexmark X7170 All-In-One InkJet Printer
I have inserted a new color ink cartridge, but when i close the printer I get an error message that reads 'Cartridge Error, Error #1203'. I have tried two different cartridges with no success. What is...
Yes ok it will be the inks.
or
Jan 05, 2010 | Dell 966 All-In-One InkJet Printer
Error 1203 I'm getting error 1203 on the printer. I have new cartridges in. Fresh paper. Still getting error 1203
1. Press Power to turn your All-In-One off.
2. Unplug your All-In-One from the wall outlet.
3. Plug in your All-In-One.
4. Reinstall the cartridges.
If this does not resolve the problem, replace your cartridges to fix the problem.
Nov 26, 2009 | Lexmark X7170 All-In-One InkJet Printer
Lexmark x9350 printer gives error message #1203
I logged into Lexmark's web site and checked their printer support page. It said that if you get error message 1203 your ink cartridge has leaked fluid. In order to find the right cartridge, do the following. Remove both ink cartridges, put in one, turn off the printer, turn it back on and if you get the message 1203 that's the cartridge with the problem. I did not get that message. I turned off the printer, put in the other cartridge, and turned it back on. Sure enough, I got the 1203 message again. (I had cleaned the wrong cartridge before). I removed the leaky cartridge, cleaneded it (making sure I did not leave any residue) and put it back in the printer. It worked!
Jun 13, 2009 | Lexmark X9350 All-In-One InkJet Printer
Lexmark P6250 Printer error 1203 - Consult User Guide
It is a hardware printing problem . Try to clean contacts in printers in cartridge holder by alcogol and elastic rubber. it may become dirty an poor contact. after this you can try this:
Put some layers of the sticky tape on cartridge to improove force of contact.
Mar 06, 2009 | Lexmark P6250 All-In-One InkJet Photo...
I am getting a message error 1203
Try this first see if it will help.
or
Aug 02, 2008 | Dell 924 All-in-One InkJet Printer
Error message 1203
This link should have the answer for you.
http://www.dellcommunity.com/supportforums/board/message?board.id=A940&message.id=13761
Jul 27, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
