My computer won't completely turn on what should i do
  • 1,179 Answers
I suggest going through my tip pertaining to this matter, it is entitled My Computer is not
turning on!!! Is it dead!!! No POST!!! this should guide you through the process and get
your PC going again.
Thanking you
damnor01
Posted on Nov 10, 2010
My U200E won`t charge unless it`s completely dead and the touchscreen won`t work anymore
Hi Bell, please don;t panic. Let us try to solve it.
> remove -- and don't replace -- the battery, than connect the charger and turning on the Laptop.
> also check the charging LED is turned On.
> if its working than check the battery else check the charger.
Feel free to revert back if issue not resolve.
Thanks
Nov 07, 2013 | ASUS Computers & Internet
Power flashes on for a second and then turns off completely
The most likely problem is that the power supply has failed.
Jul 19, 2013 | Shuttle XPC SD32G2 Barebone
Dell Pc won't boot gets black screen with floating dialog box
Floating dialog box is the monitor's self test. Your monitor tests good. Your computer is the problem.
Mar 04, 2013 | Dell Dimension 3100 PC Desktop
I'm getting this message "The operation could not be completed. No other information is available about the problem." I had a paper jam..fixed it and now it won't scan anything without that er
1. Quit neat app.
2. Turn off scanner.
3. Unplug scanner from computer and outlet.
4. Wait a minute.
5. Plug scanner into outlet and computer.
6. Start Neat app.
Hope this helped.
Feb 21, 2013 | Neat Company NeatDesk Scanner for Mac
My LG 500g cell phone won't connect to my computer to transfer pictures.
Completely shut of your LG 500G and remove the back. Take out the battery (and SD card) and then put them back in. Make sure your SD card is seated correctly. Turn your phone back on and connect your data transfer cable to your phone and computer. You should then be able to see your phone on your computer (under My Computer). This has worked for me when I couldn't see my phone on my computer. Hope this helps.
Mar 04, 2012 | LG 500g TracFone
Screen locked up, turned computer off, turned computer back on, fans running, monitor won't come back on, and keyboard won't respond
Hi hay783...
Sounds like you may have a virus/trojan/worm/etc...
To remove a virus,trojan,worm,etc from your computer...do it the EASY way...let someone else do it for you.
Start your computer, as the computer is starting keep tapping the F8 Key.
This will start the computer in the Safe Mode.
Once in the safe mode go to the following webage below and download,install, and run Microsoft Safety Scanner for FREE.
Once you run the Microsoft Safety Scanner (it may take quite a while depending on the size of your hard drive) it will remove all the virus's,trojans,worms,etc it finds, if it does not completely remove them all you will be given a chance to chat with a Microsoft Professional thru a pop open window and he will take control of your computer (with your permission) and finish removing all the rest of the virus's, trojans, or worms that are on your computer for FREE!! Can't beat FREE!!
Please take time to rate me
Sep 05, 2011 | HP Pavilion a620n (PC028A) PC Desktop
Hard drive won"t come on
Does it say it cannot locate the hard drive? Try turn the computer completely off, unplugging the power to it. Then, ground yourself by touching the PC case, and open the PC up. Once you do that, unplug the hard drive,then reconnect it and make sure its completely pushed in. Then put the case back on and power plugged back in and turn your computer on.
Jul 18, 2011 | Computers & Internet
My BB pearl won`t turn on, first the screen went white
You can re-charge your battery fully by the provide electrical charger for 6 hr , then you can try and send me status.
Jul 22, 2010 | RIM BlackBerry Pearl 8100
My sansa e250 mp3 player is unable to connect to computer nor recognized to use .It won`t turn on change the modes
turning on to change modes is your problem. If it's completely dead you may need to replace it or refurbish it. Or if the battery is completely dead plug it in all day until you can get it to turn on. ONCE ON then you can worry about getting it to connect. Try this:
There are two connection settings in USB: MTP and MSC. For some reason MTP is the default, but it doesn't connect properly on all computers. Select MSC and plug the player in again, the computer will recognize sansa e250 but not show the driver just yet. It is installing recognition software (just basic drivers - nothing heavy) and it doesnt tell you what its doing until its complete. WAIT FOR IT. Once it is complete you will see both the sansa e250 and the removable memory slot in your "my computer" now you're good to go.
Jan 18, 2009 | SanDisk Sansa e250 MP3 Player
Computers & Internet Logo
David Payne
David Payne
