Question about Garden
My John Deere 3000 pressure washer heats up after only a few minutes running and shuts off. This has happened numerous times.
    Scholar:
  • 100 Answers
Could be that the motor is low on oil, if the Honda engine runs low on oil it will shut down after running for a couple minutes. I would check that first. If you still have a problem next time before it shuts down take the gas cap off, it is possible that your gas cap is bad and is causing a vapor lock in the tank. Anything other then these items will indicate that something is wrong with the carb.
Posted on Nov 10, 2010
What is causing, to lose 3piont hitch and PTO during operations, can shut down wait a few minutes. Start it back up and they work again ,for a little while Working on an old 1020 John deere
Could be a internal leak in pump causing it to lose pressure, when you shut it off you allow it to build up pressure again. There has to be a way to have it pressure tested. Good starting point for a diagnosis. Hope this will help you good luck
Aug 28, 2016 | John Deere Garden
Have john deere lt190 after a few minutes running it shuts down. New fuel filter cleaned carburetor and gas tank changed oil. What else could it be??? Stumped
run it till it stops, have a spark plug ready to check for spark, if there is no spark, chances are the coil is bad
Sep 04, 2015 | John Deere Garden
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Gary
Jun 26, 2011 | John Deere Garden
Engine will not run but a few minutes at a time
Check your spark plugs, see if they are failing, if they are then your motor is getting to hot. meaning that you either have the fuel mixture set to high or the setting on the spark plugs are not correct causing you to burn hot.
Please rate
Jun 01, 2010 | Honda Pressure Washer PSI 3000
John Deere 3000psi pressure washer stalling
Mine is having the same issue...I googled and found this with no answers. I'll update if I can find a cure on my own...
Have you checked your oil level?? Small engines have a cut-off switch if your oil is low...mine is topped off so this is not the solution for me..but it could possibly for you.
May 01, 2010 | Garden
John Deere 3300 PSi pressure washer shutting off while in use.Everything appears fine Oil level,Gal level,Air cleaner ok etc.. May run 2 minutes or 12 minutes then spudders a bit then Bang "Off" as if i...
John Deere will replace the cap for free; they acknowledge the vendor who supplied Briggs & Stratton gas caps provided faulty caps. Call 1-888-228-3068 then 1 (English), 2, 1 and a technician will ask you for model number and Serial Number (which they need to replace the cap). Don't drill a hole in your cap: debris will find a way into the gas tank and end up possibly fouling the engine. Bob from NJ
Nov 03, 2009 | Dewalt 3800 PSI Pressure Washer
My 1979 111 john deere lawn tractor deck blades shut off
If it has a clutch, that would be the problem. An electric clutch will kick on and off when it is hot if it is bad.
Sep 27, 2009 | John Deere 420,1020,2010,2020,2510,2520...
My pressure washer works 4 a while then starts to sputter & dies?
I am going to suggest a tune of of the engine. Change the oil and oil filter. Check the air filter is clean and replace it if it isn't. A new spark plug.
Jul 05, 2009 | Karcher 2500 PSI Pressure Washer
Pressure washer, john deere 3000 psi, honda engine
It sounds like your intake is plugged with debris. What usually happens is a water hose that has been laying around will get various stuff in it -- dirt, grass clippings, small insects (and whatever they take into it nest building). These days most homeowner pressure washers do not have a proper inlet filter, but just a screened hose washer like on a washing machine. The unloader valve can cause pressure variance, but usually not in the manner that you described. The pump is being "starved" for input water. Just use a pair of needle-nose pliers and pull out the screen and clean it or replace it.
Sep 23, 2008 | Garden
Garden Logo
305 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
