Question about Linksys Wireless-N WRT150N Router
Port lights not on
I just replaced a router with a Linksys wrt150n. I now have access to my ISPN, but I cannot get my printer to work. When I plug in an ethernet cable, the front panel "port lights" do NOT come on, whether in port 1, 2, 3 or 4.
On the chance that the cable is the problem, I replaced that to no avail.
My laptop, running Vista, cannot find the printer when searching on the "network".
Can you please help me?
  • Linksys Master
  • 6,487 Answers
Since you already tried a different ethernet cable and still the same, you can try this just to make sure if the lan port of the router is bad or not, connect one of your pc or your laptop to the router and check if the lan port of the router will light up. If the port light of the router is on when the pc is connected to the router better check the lan connection of your printer.
Posted on Jun 17, 2008
I have a linksys router wrt150n but no driver to install it with. Can anyone help me!
You do not need a driver to connect to routers or access points. alternatively, you may need the driver of the network cards on your computer, not the router. So make sure those are installed.
Feb 19, 2012 | Linksys WRT150N Wireless N Router -...
My wireless connection is running super slow AND I cant access the router via 192.168.1.1
You can try to reset your router
Reset the Linksys WRT150N wireless home router if you are experiencing connection issues or have forgotten your customized router login information. Resetting the Linksys WRT150N will erase your Internet connection settings, wireless security preferences and all other personal settings from the router. This procedure will restore the WRT150N back to its factory state.
Instructions
1 Locate the "Reset" button on the back panel of the router. The button is situated to the right of the Ethernet ports and to the left of the power port.
2 Press and hold the "Reset" button.
3 Release the "Reset" button after approximately five seconds. The device resets
Tips & Warnings
Use the Linksys WRT150N setup CD-ROM to run the setup wizard and reconfigure the router after the reset.
Dec 29, 2011 | Linksys Wireless-N WRT150N Router
I am trying to connect a wrt150n wireless linksys router to my dsl. I am using a desktop windows 7 and laptop windows vista. Please help, I have tried everything but it just does not want to work.
unplug everything, including ethernet cables. then work in this exact order.
if you get a wireless signal and no internet, plug a computer in into the router in one of the available ports and check for internet. If no internet, unplug everything and test the modem without the router. If internet available without the router, then follow these instructions
  1. plug phone line into modem
  2. plug power into modem
  3. wait for all lights to become steady
  4. plug ethernet cable into modem
  5. plug other end of same cable into port labled "internet"
  6. wait for lights to become constant on both router and modem
  7. check your wireless device for wireless service.
if you dont get a wireless signal at all, plug your device into the rear of the router and type 192.168.1.1 in the adress bar
the password and username are both "admin" or simply leave the password blank if that doesn't work
navigate to the wireless option and turn on the wireless transmiter.
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Dec 01, 2010 | Linksys Wireless-N WRT150N Router
Router problem
This is a problem with the router's firmware, so i suggest you go to linksys web site and download the latest firmware for this router and upgrade it , so everything will be working but if still the same problem after the update better call linksys support and have the router replace...
Feb 19, 2009 | Linksys WRT150N Wireless N Router -...
My internet icutting out unless i plug power adapter from router
Cannot access internet with a linksys router
Make sure DHCP is turned off on the modem or else you will get ip conflicts. Also make sure it is plugged into the wan port on the router
Jan 15, 2009 | Linksys Wireless-N WRT150N Router
Linksys WRT150N
I only have 3 suggestions.
1st one is to make sure the ssid is not similar to other routers you are using on your profile. ie.(change it to a unique name)
2nd is to make sure you check the box that says broadcast your ssid.
3rd check to make sure you select the router as an access point and not adhoc or infrastructure option. Finally you can try to change the channels eg. i like channel 3 b/c it doesnt interfere with any phone lines.
good luck
smeags.
Jan 06, 2008 | Linksys Wireless-N WRT150N Router
Linksys Wireless-N WRT150N Router Logo
70 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
