Question about HP PHOTOSMART PLUS B209A All-In-One Printer
I have a HP Photosmart Plus B209 a printer. The black ink won't print. The colors print just fine. All the ink is brand new.
  • Doctor PC
    Doctor PC Mar 08, 2014
    Try using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English)
You are one of many B209 owners with this problem. The B209 has a defectively-designed printhead. The HP site is clogged with complaints about it. The HP customer support chat people will ask you to disassemble your printer in order for you to read them several dates and code numbers. They will then tell you that your warranty has expired and they won't do anything to help you.
If you take your print head out of the printer you'll find a thick, gummy residue of black ink on it. I don't even want to think what that residue cost me with HP ink costing more than most precious metals. You can try cleaning it but the only solution is the purchase of a new print head. Or, you can try my alternative solution:
1. Open window 2. Throw HP B209 out window 3. Order non-HP printer on Amazon 4. Never buy HP again
If HP is going to sell a faulty product then they should stand behind it and make it right. It's clear from my 2 hours chatting with the HP man overseas that HP will not be doing this.
Posted on Mar 21, 2011
  • Rod Eslinger
    Rod Eslinger Feb 18, 2014
    Folks, the Printhead is fine as long as you use inks which are compatible. This includes HP original/genuine ink & Costco's ink cartridge refilling service. I strongly suggest you refrain from purchasing compatible/clone cartridges off the internet as these have been found to cause damage to the PRINTHEAD according to Buyer's Laboratory (BLI) January 2014 test report. Ink refilling services are now available throughout North America at all Costcos, Frys and now Micro Center stores. For details please visit: Costco USA Ink Refill Service (450+ stores):http://www.costcoinkjetrefill.com Costco Canada Ink Refill Service (52+ stores):http://www.ca.costcoinkjetrefill.com If anyone has questions regarding the use of refilled ink cartridges can visit http://www.inkjet411.com -Thank you
This is from the HP site from another ripped off customer...
Any lawyers out there looking for a case?
Hi PC Wizard
Yes I have certainly tried everything that HP has advised. I have wasted hours of valuable time and a fortune in buying genuine ink cartridges. I have tried a new printhead. I really don't think you can expect your customers to do any more to get a printer to print on a piece of paper, it's hardly rocket science.
If you look on your own forums, there is a thread "HP Photosmart Plus B209a-m Black Ink won't print" it has been viewed 17,443 times. Another thread "Photosmart Plus B209 Printhead Problems" has been viewed 3,646 times. I would think the fact over 20,000 people are looking at your site for answers to this problem ought to flash a warning bell somewhere that you have a faulty product. So far no one has offered a permanent solution. I can spend thirty minutes rinsing my printhead with warm water and then waste a pile of ink doing some cleaning cycles and then print off what I need, but the next day it is clogged again and does not print properly.
HP should do the decent thing and redesign the printhead and send them out free to people who have spent a lot of money on this printer which is not fit for purpose. Please do not insult our intelligence by suggesting various short term fixes. We need a long term fix that will eliminate this problem !
Posted on Oct 25, 2012
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • HP Expert
  • 307 Answers
For severe print quality or missing color issues (...printers which use HP564 ink cartridges) there could be an air bubble/gap between the ink cartridge and PRINTHEAD, or a portion of the PRINTHEAD is dry, so you should first perform a CLEAN PRINTHEAD procedure from your printers control panel (i.e. select TOOLS - CLEAN PRINTHEAD).
NOTE: If one or more the colors were previously dry fired during printing (i.e. if you continued printing using only a few colors to one, air may have been accidently ingested into the ink lines between the cartridge(s) and PRINTHEAD. To recover from this more severe condition, you may have to run the CLEAN PRINTHEAD procedure 2 or 3 times. Print the SELF TEST REPORT or PRINT QUALITY REPORT to see if there is any visible improvement in colors and/or print quality.
If a problem persists then it is suggested to review the steps outlined on the following Inkjet411 HP564 support page, including printhead removal/printer electrical contact cleaning and service station cleaning. A dirty service station can cause poor image quality and/or ink cross-contamination between different colors:
http://inkjet411.com/?page_id=1451
If the problem still cannot be corrected, then the PRINTHEAD may be dry and may need to be flushed (i.e. with warm water as it could have dried out, but this is a function of how much you print). Remove and thoroughly flush all ink ports for 2-3 minutes...thoroughly dry printhead prior to re-installing. Retest. For complete instructions refer to video here: http://inkjet411.com/?page_id=2412
Worst case scenario the PRINTHEAD may simply be electrically damaged or at end-of-life (while rated for 10-12,000 pages, the average consumer may only see an average of 5,000 printed page throughput) and may require replacement. A severe failure of the PRINTHEAD is typically accompanied by error messages such as INCOMPATIBLE PRINTHEAD, REPLACE PRINTHEAD or INK SYSTEM FAILURE. NOTE: The PRINTHEAD will eventually fail in time. For more information on the how the PRINTHEAD works, watch the video here: http://inkjet411.retailinkjet.com/?page_id=1983
To verify Printhead electrical performance, activate the Tap 41 diagnostic test, (i.e. Pen Status: Pen OK).....for printer model instructions please visit: http://inkjet411.com/?page_id=1813
To solve other HP564 ink-series printer/printing related issues please visit http://www.inkjet411.com
Posted on Jul 25, 2013
I too am one of you now....Many wasted hours on this useless printer. I have cleaned the printheads, thought my husband was techno-wortless and spent $ on a computer guy to come to my house to help me get setup to print on this machine. Lesson? Never buy HP again!! It's hardly been used and we have spent a fortune on ink. RIDICULOUS!
Posted on Feb 18, 2013
Don't buy HP printers. What ever kind of printer they have been putting out the last 5 years stink. I've had 3 of the top of the line ones. Each and everyone has had a print head failure. Prior to that HP had the best printers out there...NO MORE! Even worse, they don't care.
Posted on Feb 17, 2014
    Guru:
  • HP Master
  • 2,178 Answers
The black ink cartridge is probably clogged. Remove it from the printer and clean the heads with a "Q" tip and alcohol. Also, HP recommends you use the genuine HP cartridges - if it's an off brand name they sometimes don't work.
Posted on Nov 09, 2010
  • parker_brook Nov 10, 2010
    They are HP cartridges. Brand new and clean. Still not working.
  • Rommel Alilin
    Rommel Alilin Nov 10, 2010
    Do you have another black cartridge - maybe you have a defective one from HP?
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
Won't print black ink
Try to print with other colors. Change the font color to red. If that printed, then you need to change cartridge for the black ink.
Jul 12, 2011 | HP Photosmart Premium C309A All-In-One...
I have an HP Photosmart C3180 printer color ink issue. Instead of printing yellow its printing pink. I've cleaned the head multiple times and the ink cartridge is brand new. Please advise. Thanks!
If what you're saying is still the result after cleaning everything up, there must already be something wrong with the printhead because the printheads are the one's that are responsible for the mixture of the ink cartridges.
Try calling HP Tech Support. They might still be able to replace the printheads for you.
Feb 03, 2011 | Office Equipment & Supplies
My hp photosmart c4480 is printing in horrible color, redish tint and hazy. i just installed brand new color and black ink and can't get my pictures to print right. Help!!!!
Hello Friend,
First of all please check for correct drivers for printer.
Secondally : Please draw three different - different color boxes in word and print them on you printer and find out which one color is missing. Example as follows.
Apr 06, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
HP Deskjet 990cxi Printer NOT printing B/W, only red.
To customer of HP deskjet 990cki: I purchased the HP photosmart Plus B209 ~ January 2010. 3 months into, I have learned that when the color ink that you don't use evaporates, the black ink will not work at all, no matter what you adjust or clean.To make it work you have to purchase more color ink...on & on & on..$$$$. Neither HP nor Best Buy will refund my investment. Spoken with HP customer service reps. in the Philippines & Canada both being outside of the US. NO customer satisfaction. No refunds. I suggest Boycotting both corps.
Jan 24, 2010 | HP DeskJet 990cxi InkJet Printer
HP Photosmart 3210xi - some colors (magentas) will not print
Remove the magenta cartridge, and try cleaning the head with alcohol, maybe with a small paint brush or an acid brush. It sounds like ink has dried and plugged up that head.
Jun 04, 2017 | HP Photosmart 3210 All-In-One InkJet...
HP Photosmart 4150-I am unable to get the colored ink on a print from a website. My ink is new, color and black. Thx
if colored printing fine from other application ( Word, excel etc) then pls follow theses steps -------- in internet explorer goto tool ----- advance ------- look for Printing in the list and check the box Print background and color and images.
Sep 25, 2009 | HP Photosmart 4180 All-in-One Printer
HP PHOTOSMART PLUS B209A All-In-One Printer Logo
10,346 people viewed this question
Seeker5211
Seeker5211
