Question about HP Photosmart C3180 All-In-One InkJet Printer
Colour issues Hi. When I print in color, what should be balck comes out as green. But when i print in black it prints black. Just not in color. Please help? Cheers
    Novelist:
  • 106 Answers
Try to follow this document.Just double click here=> DOCUMENT
Thank you so much.
adonscott
Posted on Jul 05, 2008
The blue color is not printing correctly. It comes out sort of pink and greens are yellow. I have a new balck drum. I have put in a new blue toner cartridge. I have tried adjusting color saturation. ...
create a doccument with four identical lines of text.
the text should be as follows:
your text in the colour Black, the cyan, then yellow then magentta
see if they print in the colours you used, if they are all wrong then delete all drivers associated with the printer and delete the printer, then follow the install proceedure again to reinstall, if just one colour is wrong the it is most likely a deffective cartridge.
Dec 06, 2013 | OKI C5100n Laser Printer
My magicard alto prints fine except the color quality is not very great. when i use the color ribbon and print black letters with it the letters come out gray and not black and it has a problem making the...
The printer driver must be set to print text with the K resin panel.
If the text is part of a bitmap image and not a true-type font then it will print from the coloured panels and be dark grey.
To create the correct green on the card you need to change the RGB values so it prints correctly but look wrong on the badge design program. Even different printers print the same colour differently.
Jan 29, 2010 | Magicard Alto Card Printer
No black when printing color
Dear Sir,
You are getting black lines in green color,and apperence of parallel light and dark lines because your colour catridge is almost empty.So solution is replace the catridge and take a printout. There is no proplem with a printer. i think it solves your problem.
good luck
chandrashekhar
Jul 29, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Printer only prints in red!
In this case, i would request you to follow the bellow steps:
1)click on File Menu ->select Print->Select Preference->color tab->Select "print in graey color->now select only Balck ink....
I Hope by following above steps, your issue will resolved.
Thanks
Sushant
Jul 06, 2009 | Dell 946 All-In-One InkJet Printer
Mono color
These models use a "3 colour" printing process. In other words, these printers do not contain black ink when the BC-05 colour cartridge is installed. To produce black print, a 3 colour printer mixes an equal amount of the three primary colours. This process is known as "composite" black.
As the ink in the cartridge runs out, one of the three primary colours will run out first, depending on the material that has been printed. After one of the three colours has depleted, this colour will be missing from the mixture required to print black, and the print will change colour. This is the indication that the cartridge needs to be replaced. Usually the remaining colours in the cartridge will run out soon afterwards.
Rate the solution as appropriate !
Feb 07, 2009 | Lexmark X7170 All-In-One InkJet Printer
Colour problems when printing with dj 130
I had similar problems when I first installed the printer and after different tests we found out that the Magenta ink print head was faulty. Changed head to a new one and problem solved. You will need to recalibrate and do paper set up's again.
Aug 16, 2008 | Designjet Black Designjet 30/130 Series...
Grey tone problems
Hi,try this: in the printer driver choose imaging and find "color reproduction" button. Just adjust that balck and gray will be printed FROM BLACK TONER ONLY(print black text and graphic from black toner only)
Regards
Mar 17, 2008 | Kyocera FS-C5030N Led Printer
Canon Pixma ip1000 does not print Grayscale and other colours
Hi , try to nozzle check if lucking of colors appear need head cleaning twice it depend how color are present during test print.
Feb 03, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Hp psc 1210 all in one colour problem
Sounds like Color cartridge problem...
Colors on the cartridge are mixed together
Dec 05, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
