Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a Sears Kenmore washer (Model # 11092281100). I replaced the motor coupler, and I checked the alignment of everything before reconnecting the motor clamps/clips. It seemed like the motor shaft was turning everything properly. The machine works beautifully with no noises, but I too can smell something burning. The smell is very slight, and I thought it sort of went away last night when I tried out the machine. Today I started the washer and I smelled the slight burning again. If the coupler wasn't installed properly, would the washer work right with no noises? Could the smell be from silicone grease on the motor shaft? It's been a long time since I started this project so I don't remember exactly, but I may have put silicone grease on the shaft.
    President:
  • 1,430 Answers
It could be the grease. It could run without noise if it was not installed all the way. Here is a link for properly installing Motor coupler video Now if everything looks right it is probally just the grease.
Posted on Nov 09, 2010
My Kenmore heavy Duty 60 series washer is not completely spinning all the water out of my clothes. 25% at the bottom are wet. Is there a belt on this washer i can change? M# 81863110 S# 09240402
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11081863110/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
it doesn't have a belt and YES you can fix it yourself easily.
Two possibilities: since it will spin. None of the suggestions are very expensive.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the
transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or
spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Dec 20, 2010 | Washing Machines
How to remove and replace clutch on kenmore washer 110. series direct drive
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Before assuming that the problem is the clutch, I'd check the Motor Coupler first.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
Nov 18, 2010 | Kenmore 16812 Washer
My kenmore washer will wash okay, drain okay, but when it's supposed to spin, only the agitator spins; the tub stays stationary. Kenmore topload washer, model # 110.26742503
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11026742503/0582/0153200?pathTaken=
Three possibilities: since you can hear the motor (Ranging from easiest to messiest) None of the suggestions are very expensive.
Actually, the agitator isn't supposed to spin. See the section of the Whirlpool manual on the Agitate Cams also.
spinning.
If the Motor Coupler is fine, and the clutch bands and springs are OK the problem could well be the transmission. "Neutral Drain Assembly".
See the Whirlpool / Kenmore Service manual for transmission operations on top load direct drive washers.
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
When ours had a similar problem, we looked at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) and noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 15Oz of 80-90 weight gear oil, remove the clip holding the main spin gear on and check the plastic cams and spin gear.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit or spin gear, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
COUPLER OR CLUTCH:
spinning.
Nov 05, 2010 | Kenmore Washing Machines
Kenmore 80 series mod110.23832100 washer will not spin with a full load. does spin with small load.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11023832100/0582/0153200?pathTaken=
Oct 16, 2010 | Kenmore 24032\24036 Top Load Washer
I need an owners manual for troubleshooting for a kenmore 70 series model 110 20722, serial CK4011186, type 111 When it spins out the wash water and rinse water not all of it goes out? Does it have a...
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Based on the 20722 Stock Number, the following might be the Sears diagram site for your washer. Check under the Lid for the exact model number:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20722990&pathTaken=partSearch
Two possibilities:
These models don't really have a filter but I'd check the hoses to and from the pump and inside the pump to look for any obstructions in addition to the Motor Coupler (about a $20 part) and the clutch.
Jul 01, 2010 | Kenmore Washing Machines
Troubleshooting washer clutch, kenmore 90 series, stock 26912, model 110.26912691
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26912691&pathTaken=partSearch
Two possibilities: I'd check the coupler first (you don't have to pull the gearcase to check it.)
Sears (and Whirlpool) have a replacement clutch band kit.
Jun 12, 2010 | Kenmore Washing Machines
Stopped in mid-rinse cycle, whines
110.21082000 OR 110.21082001 (Sears requires 8 digits after the 110.
May 02, 2010 | Kenmore 22422 Top Load Washer
Washer won't aggitage or spin
Kenmore washers use a coupler to attach the motor shaft to the transmission. The coupler is designed to shear off to protect the motor.Often the repair is to replace the coupler (sears part # 285753A, $18.50) If you flip the washer over you can visually verify that the coupler is broken.Disconnect the hoses to the water pump by removing the hose clamp). Then remove the two small screws holding two clips, called retainers that attach the motor to the transmission. the two assemblies will separate at the coupler.
Jan 11, 2010 | Kenmore Washing Machines
Pins that center tub on my kenmore washer fell out into small cups that look as though they were made to catch them. the pins look like nails with holes drilled near the point. the holes i asume are for...
The pins may just be shipping pins that are designed to break and fall into white plastic holders when the washer is installed.
See the Sears parts site for your washer at:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=11092281100
to determine if these are the parts.
Sep 10, 2009 | Kenmore Washing Machines
Kenmore washer, 110.22722100, won't spin
It may be the coupler. see my link to sears parts for exploded view. coupler is number 13. The coupler is behind the motor and will need the main cover (case) removed to replace it. Inspection is also easier with the case removed. It's an $18.00 part and a bout $90.00 in labor to hire it done. I can help. http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22722100&pop=flush at this link choose BRAKE/CLUTCH/GEARCASE/MOTOR/PUMP
Jul 03, 2009 | Washing Machines
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
159 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
