Question about Timex Expedition 40141 Wristwatch
INDIGLO BACK LIGHT NOT WORKING AS BRIGHT AS IT ONCE DID, I've changed battery & still does not correct fault
5 Suggested Answers
diddydaveh
  • 154 Answers
SOURCE: Timex indiglo. Indiglo feature died.
The indiglo technology is time limited (it dims over the years with use) and cannot be repaired - have you had the watch a long time? if so, I'm afraid it's time to get a new one. Sorry!
Posted on Jan 02, 2009
  • 11 Answers
SOURCE: Indiglo does not work after changing battery
On a Timex a lot of times the back has to be on for everything to work. But I am going to assume the back is on. The indiglo could just be out. Timex repairs their watches for little or no cost. You would have to mail it to them for repair as they do not release parts to anyone. I believe their number is 1-800 for time
Posted on Jul 31, 2009
escapement
  • 2334 Answers
SOURCE: after about two years, my indiglo night light
Definitely, battery change will solve the Indiglo light problem. Many of wristwatches has separate battery for Indiglo function, but my advise is to change them both at once - will be cheaper for you.
Rate me, please.
Posted on Sep 01, 2009
SOURCE: Can't get the back plate of a Timex Indiglo WR30M watch back on
To open watch case, hold back of watch up with arrow pointer on the back plate pointing to the right. There is a pry point on the upper edge where you will see a small arrow pointing. Use a small flat end screw driver to pry the watch case open. Be sure to replace the back the same way with the arrow pointing away from the setting knob.
Take a 1-1/4 inch paddle bit and drill a hole in a 1-3/4 inch wide piece of wood about 1/8 inch deep. Then take another piece of wood about 2 inches long by 3/4 inch thick by 1 inch wide to lay across the back of the case plate. Place the crystal of the watch in the drilled hole. Used a vise or clamp with the watch between the two blocks of wood to press the back on. Be careful not to over press. Works great
Posted on Jun 05, 2010
How do I change time and date on timex indiglo
  • How to Set Dial Indiglo Watches
    • 1Pinch the winding knob on the right side of the watch between your thumb and forefinger.
    • 2 Pull the knob out from the watch slowly until it clicks into the first position.
    • 3Turn the knob to move the hour and minute hand to set the time. Move the knob clockwise to move the settings forward and counterclockwise to move them backwards.
    • 4 Pull the knob out further until it clicks into the second position. In the second position (the one furthest from the face), turn the knob to set the calendar, if your Indiglo has one. Turn the knob clockwise to move the settings forward and counterclockwise to move them backward. Push the knob back in to the watch face when you are done.
    How to Set Digital Indigo Watches
    • 1 Press the button on the lower right side of your Indiglo watch to unlock the mode function of the watch.
    • 2 Press the button on the lower left side to move through the modes. Each time you are in a mode, the digital display will flash. For example, when the time display begins to flash, you are in the correct mode to set the time.
    • 3 Change the time (or date) by pressing the button on the upper right side to advance the numbers or the button on the left side to move the numbers down. When you do this, you will be changing the first set of numbers (the hour or month, for instance); to change the minutes, press the button on the right side of the face until the second set of numbers is flashing and begin the process again.
    • 4 Press the button on the lower left side of the watch to save your settings. The button on the upper left side of the watch is not used in this process--it is the switch to turn on your Indiglo light.
  • Read more : http://www.ehow.com/how_5758168_set-timex-indiglo.html
    Mar 31, 2015 | Timex Indiglo Watches
    I have a ladies timex indiglo watch that I was able to get the back off and replace the battery but now I can NOT get the back on again. It doesnt seem to have any grooves on it. It seems as if it would...
    I have an old Timberland Indiglo watch in which I had the same problem. I folded up a paper towel for padding and I used two sets of pliers, one to hold one side of the watch while I used the other set of pliers to snap the back cover closed. It took two seconds to do.
    Sep 10, 2010 | Timex 27191 Wristwatch
    Display disappears when Indiglo is pressed
    That means your watch has two batteries - one for the movement and another one for INDIGLO. It may have just one battery, but in this case INDIGLO is taking up too much power. Replace the battery and you will be sorted. Rate me, plz.
    Feb 19, 2010 | Timex Watches
    INDIGLO does not work anymore
    Take this to a qualified watchmaker for inspection.
    If you have any further questions please let me know.
    Many thanks!
    Mike Kenley
    TimeOut
    Worldwide watch and clock services
    If it don't tick I can fix
    Nov 29, 2009 | Timex 27191 Wristwatch
    After about two years, my indiglo night light function stopped working. The watch is still working, keeping time. Will changing the battery fix the indiglo problem?
    Rate me, please.
    Sep 01, 2009 | Timex 2J611 Watch
    Jul 30, 2009 | Timex 27191 Wristwatch
    Timex T49271 Expedition Indiglo button dead?
    There is no separate battery for the indiglo,maybe indiglo circuit is lose or defected already,just open the watch and check for lose connection.If happen the circuit is tight and still not working then replace the indiglo circuit.
    Hope it may helps you;
    Regards
    VOTIT
    Mar 23, 2009 | Timex Expedition 40141 Wristwatch
    Dec 30, 2008 | Timex Watches
    Timex Expedition Indiglo light no longer works?
    Replace the back cover with the arrow pointing directly at the stem. Everything should work correctly with the cover in that position.
    Jun 22, 2008 | Timex Expedition 40141 Wristwatch
    Timex Expedition, beeps very quietly and indiglo doesn't work.
    To clarify... Replace the cover with the arrow on the back pointing directly at the stem. The Indiglo backlight, alarms and chimes should all work when the back cover is in this position.
    May 04, 2008 | Timex Expedition 40141 Wristwatch
    Timex Expedition 40141 Wristwatch Logo
    161 people viewed this question
    Top Timex Watches Experts
    Ansel Alberto
    Ansel Alberto
    Mark Schmit
    Mark Schmit
    Carol
    Level 1 Expert
    Are you a Timex Watch Expert? Answer questions, earn points and help others
