Question about GE Profile Prodigy WPSE4200A
Ge washer water leaks onto floor. nothing is leaking visible on the rear of machine.
    Sergeant:
  • 225 Answers
Hi.
I would check the rubber seal around the door - down at the bottom, to see if it has perished or got torn.
Does it leak only when running or all the time - that is, when powered off and idle?
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills. If they do not, please add a comment with more details so I can try to help you further. Cheers, D
Posted on Jul 10, 2008
Washer and dryer stackable unit. water is leaking from somewhere onto the floor causing floor swelling. what could be the problem?
Thanks for choosing FixYa and welcome to the sight. You need to make sure your drain hose is not clogged up or your hoses are not damaged. You need to check the water pump also. It may be clogged or leaking from the pump area. Make sure the tub is not cracked or damaged, causing water to run out. Your best bet is starting the washer while you are viewing the hoses and the pump. You should be able to find the leak this way.
Apr 22, 2011 | GE WSM2420T Top Load Stacked Washer /...
I have a GE Top Poad WasherWJRE5550H1WW that intermittantly leaks
There seems to be an overflow drain from the top of the tub to the bottom (inside the cabinet). I don't know why this was designed to dump water onto your floor.
May 13, 2010 | GE Washing Machines
Water leak
i went to the parts store asked about it and they told me what to do . I didn't even buy a part from them.
Jan 13, 2010 | GE Washing Machines
Intermittent water on floor
Check the inlet valve hoses, even if inlet is at the back, the water may drip down and flow on the front part on the machine. There you also have the PUMP, a faulty pump may leak intermittently.
Here you get all diagrams and parts for your appliance.
Sep 25, 2009 | GE WJSR2070B Top Load Washer
Water leaking onto the floor
hat leak may not be in the machine. It may be one of the hoses going into it. Look to find out where the water is actually coming from. If it is a hose from the faucet behind the machine, the hose can easily be replaced at a low cost. If it is only leaking with hot water, check the water inlet valve at the rear of machine where the hoses connect, top left rear facing it. If it is leaking and running down the left side, it is the wrong side for the pump unless it running across the floor and out the left side. If it were the hose, it would leak all the time. It sounds like the hot side has gone bad on the inlet valve. You can save several dollars by fixing this yourself.
Tilt it back and look for two screws, near each corner on the bottom front. Remove these screws and pull the bottom toward you. It should lift off the clips on top. Run the machine carefully, moving parts and see if the leak is actually coming from the left rear and from somewhere up high. First try cold water, then hot. If it leaks on one and not the other, then it is the valve. Be sure to unplug the machine if you decide to change this part. Also you might want to mark where the wires go back to be sure you do not reverse the hot and cold water, as well as fittings and connections. The water leakage evidence should be visible. If not, wash a load and watch for where water leakage occurs. Just look. Do not touch since there will be electrical current supplied.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
Water leaking out of the bottom
Sounds like the main bearing has gone bad and that is causing you to loose water on the floor. There is also a rear seal back there that will need to be replaced
May 22, 2009 | GE WSXH208A Front Load Washer
Some water drains out onto the floor.
the drum seals will need to be replaced. there are seals that are used for the screws that connect the drum to the drive. they are leaking.
Mar 11, 2009 | GE WBSR3140DW Top Load Washer
Whirlpool Cabrio Washer- When draining, water leaks out of hole
probably rubber hose from tub to pump broke, access from back or bottom, (cabrios are open bottom) pump in rear. there is a recent bulletin about tub ring not channeling water from dispenser completely into tub
Mar 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
GE top load washer leaks on floor
Check your hoses mostly the small hose going from the side of the tub to the water switch these come off a lot. you need to look and see if the seal is leaking from the center of the tub you do this by putting water in the tub and just looking around the bottom of the tub and transmission
Dec 29, 2007 | Washing Machines
Washing Machines Logo
62 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
