Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My mom & I each have a Craftsman garage door opener at our respective homes & live @ 15 minutes apart. Our openers are about 13 to 14 yrs old. The past two yrs. we've both had the same problem. The openers work fine when the temperature is above 50 degrees. But as soon as it goes below that outside, when you press the wall or remote switches, the door starts to go down, then goes back up & the light blinks a couple times. You can close the door if you hold the wall switch in til the door closes completely, but if you let the pressure off the switch before the door is completely closed, it goes back up again & the light blinks. The openers both work fine in summer, but now we are getting into winter & its started again at both our houses. The "sensors" show solid green lights, so that does not seem to be the problem. Do you know what the problem is? Thank you.
    President:
  • 3,197 Answers
If the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure both lights on the sensors stay on and don't flicker while the door is moving and the sensors are firmly attached so they don't move. Tweak them just a bit.
Posted on Nov 10, 2010
  • Peg Lydon Nov 27, 2010
    But if its a sensor problem, why doesn't the problem occur when the temps are above 50 degrees? The door works fine when temps are above 50 degrees.
Don't know Mod. No. lost installation manual, approx. 5 yrs. old Need installation manual.
About 496,000 results (0.43 seconds) Search Results
    [PDF]GARAGE DOOR OPENER Model 3265 1/2 HP ... - LiftMaster
    www.liftmaster.com/.../en.../tucmanuals/114a3044.pdf Chamberlain GroupFasten the manual near the garage door after installation. .... This garage door openerhas been designed and tested to offer safe service provided it is installed, ...
    Manuals Download Craftsman Garage Door Opener Model ...
    www.craftsman.com/search=manuals%20download%20crafts...
    CraftsmanCraftsman has the best selection of Garage Door Openers in stock. Get the Garage Door Openers you want from the brands you love today at Craftsman.
    Craftsman 1/2 HP Chain Drive Garage Door Opener - Sears
    www.craftsman.com > ... > Garage Door Openers
    Craftsman1/2 hp Chain Drive Garage Door Opener Opens by Remote, Inside and from Car Enjoy a great end to every day by ... Owners manual - English (Warranty).
    Free Craftsman Garage Door Opener User Manuals ...
Feb 03, 2016 | Building Materials
Replaced logic board on my Sears garage door opener and still getting 5 blinking lights and not working. sensors seem ok.
The opener is flashing the code for "RPM sensor or motor overload." Try unplugging the opener for about 15 minutes and see if the memory will reset.
Aug 18, 2012 | Sears Craftsman LiftMaster Chamberlain...
Cannot get remote for garage door to work
push the green button on the opener then push your remote button
Jan 25, 2010 | Locks & Locksmithing
Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Opener operates on its own sometimes
maybe a short in wall wiring is causing motor to overheat and shut down for 15 minutes. try disconnecting wiring to wall pushbuttons and see what happens.
Dec 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
OLDER SEARS GARAGE DOOR OPENER WONT OPEN GREEN LIGHT FLASHING
do you have the sensors at the bottom of the door? if so they might be out of alignment. all you have to do line them up by getting the green light solid. let me know if this helps you.
Dec 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Door opens only 6 inches and stuck
I would try jumping a wire across the white & red terminal to see if your safety sensors are working Properly! If your door opens you have a loose connection or faulty sensors.
Oct 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
257 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
