Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Have a McCulloch 16" chainsaw bought years ago,
  • 7,733 Answers
Where can I get a parts manual?
I found one on line a few years ago for an old McCulloch on the web.
Sep 13, 2015 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Is a capacitor on a 3200 mcculloch chainsaw also called the coil
starting capacitors on electric chain saws just provide a short burst of stored up energy to get saw moving , coils on gas powered chain saws provide all the electric energy to "fire" the spark plug
the two are totally different and one does not work for the other , but both are an electric device
Jun 05, 2014 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
What type of gas do i use for my McCulloch 16 Inch Gas Chain Saw
If using an oil other than McCulloch, the ratio is 40:1. Brand Specific McCulloch two cycle oil is 20:1.
Jul 02, 2012 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Can anyone help with fuel mix and starting instructions for McCulloch 2214av chainsaw please
Ok, always use good quaility teo stroke oil, from a manufacturer who actually produces a chainsaw, ie Husqvarna/Stihl/Jonsered etc, all of these oils should be run at 50-1, avoid oil makes you have never heard of.
Starting instructions are as follows, switch the red ignition switch too on ( up ) depress the primmer bulb as many times as it takes to 3/4 fill the bulb ( you cannot flood the engine if you over prime, it is better to over prime ) pull the blue choke fully out, crank the engine until it fires once ( it will only fire once, do not continue to crank the engine after it first fires with the choke still out ) now push the choke fully back in, crank the engine until it fires up and runs on fast idle,now blip the throttle trigger to diss engage the fast idle position, the saw should now drop down to idle.
Regards
Jan 31, 2011 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Fuel mixture for a McCulloch 3.4ci chainsaw
I found my owner's manual. Ordinary 2 cycle oil the mixture is 50:1
Jan 29, 2010 | McCulloch Garden
Chainsaw won't stay running at full throttle
15 years old...
One cause to look in too is a leaking seal around the crank, this is causing a vacuum leak.
Hope this tip helps.
R/
David
Jan 27, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Looking for a manual for mcculloch pm 484 chainsaw. cannot start the chainsaw.
If the ignition and fuel supply systems are good that is correct. I was not able to find a McCulloch 484. Are you sure that is the model number?
Lou
Dec 17, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Gas, Oil Mix ratio for McCulloch Eager ******
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Sep 28, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
540 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
