Question about GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker model jvm230bv microwave is not heating food, water or popping popcorn. Power to the microwave is good, all electric features work, i.e., clock, lights, etc.
  • GE Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101=[=[
Posted on Mar 27, 2011
MCD1611W New, popping popcorn in glass MW corn popper. 3-4 minutes to pop. After popped I open the door and after a few seconds the MW shuts down completely, no lights, no response to pad pushing.
Popcorn is a low-moisture food which can cause a microwave to overheat, as can a failure of the cooling fan or blocked vents.
You should always turn a paper plate upside-down on the turntable (slightly off-center for better heating) and place the popcorn container on top of that.
The paper plate elevates the popcorn for better exposure to the energy and protects the turntable from excessive heat.
Placing food off-center instead of in the center increases exposure to the energy and prevents the same spot on the turntable from being overheated repeatedly, which leads to material fatigue and cracking.
It's also a good idea to put about 1/2 cup of water in a 1-cup microwave-safe container in the corner of the oven when cooking low-moisture foods like popcorn, bacon, and potatoes.
The microwave's magnetron has a thermal protector (thermostat, TCO, or thermal fuse) attached to it.
If the magnetron gets too hot, it can be damaged or destroyed, so the thermal protector opens and disconnects the power to the whole oven.
If it is a resettable device, the power will be restored when the device cools. If it is not resettable, the device must be replaced.
FixYa does not directly notify us experts of responses, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 28, 2017 | Magic Chef MCD1611W
GE Spacemaker SL 1800 arching
Get some warm soapy water and clean inside making sure there are no food particals, if no change! the magnetron may be breaking down.
Mar 13, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
It's working normally EXCEPT it will not heat food or pop popcorn, etc.
Hello :
It's could be a bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
That could happen because of slamming the door and not closing it gently .
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
PLEASE RATE !
Jun 08, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
MIcrowave doesn't heat up food
Microwave Oven Basic Troubleshooting Tips
heatman101
fdyjhd
Jul 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
A child burnt popcorn in our GE Spacemaker microwave. Now, everything works except for the heat. Panel works, light works, turn table works...no heat. Help pls.
Sadly popcorn kills more microwave ovens than peiple imagine. You can get an estimate on a repair but I believe you will probably decide in the end to replace it. Same exact thing happened to me............expensive popcorn!!
Jul 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Sensor error
I had the same exact thing happen...I put in some popcorn, it wouldn't pop. The screen said "sensor error". I tried heating water, a piece of chicken...nothing would heat. I unplugged it, plugged it back in...nothing. The manual says to close the door and hit the clear/cancel button. I could have sworn I had done that, but my wife simply hit the clear button and it started working again good as new. Hope yours does the same. : ))
Jun 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Food not heated in mocrowave
I'd say the actual microwave generator has gone bad.
Jun 05, 2009 | GE XL1800 1100 Watts Microwave Oven
Microwave not heating food
It's most likely the Magnetron. The are not very easy to install and quite expensive. Older models magnetrons cost about 80 bucks from GE. It's probably not something you would want to try and repair yourself. Call a GE service person.
Feb 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker making odd noise
We are having the same problem with our XL1400. I suspect it has something to do with the turn table but don't know for sure. We would be willing to disconnect the turn table...anything to stop the noise but don't know how.
Mar 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
405 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
