Question about Goodman Heating & Cooling
CAPACITOR Z97F9003 12.5 uf 370 VAC WIRING DIAGRAM GUPS
  • kennethd53 Nov 10, 2010
    ACTUALLY, IT IS THE FURNACE BLOWER MOTOR. THE MODEL NO. IS GUPS120-5 AND THE SERIAL NO. IS 9301061608 TO THE FURNACE. TWO BROWN WIRES ARE CONNECTED TO THE CAPACITOR. THE BROWN WIRES GO FROM THE CAPACITOR TO THE BLOWER MOTOR. A RED WIRE COMING FROM THE BLOWER MOTOR IS SUPPOSED TO CONNECT TO THE CAPACITOR, AND A WHITE WIRE COMING FROM THE ON OFF SWITCH ON SIDE OF FURNACE IS SUPPOSED TO CONNECT TO THE CAPACITOR. THEY BECAME DISCONNECTED WHILE CLEANING AND I AM NOT SURE WHICH WIRE (RED OR WHITE) GOES TO WHAT SIDE. A PICTURE OF THE CONNECTIONS WOULD BE GREAT, OR DOES IT MATTER WHICH WIRE IS ATTACHED TO WHICH SIDE?
    yes, the white routes to the on/off switch and the red routes to the motor. Does it matter which brown wire is connected to red or white?
    Guru:
  • 1,524 Answers
Tell me what part of the diagram you need and the model number of the air conditioner not the part number for the capacitor.
Posted on Nov 09, 2010
  • 1 more comment
  • Robert Moller
    Robert Moller Nov 10, 2010
    The brown wires are to the capacitor. The red and white (on/off switch) wires would go to the motor.
    Usually 120 volt capacitor motors usually have 2-Brown/flag terminals which go to the capacitor.
    two colors for power (usually red) and neutral (usually white) but you stated the white was tied to the off/on switch ???
  • Robert Moller
    Brown wires are interally connected to the motor. If white is wired to switch then that is power.
    Would not know why you think red and brown are connected all the wiring diagrams I have available show the browns by themseleves . Unfortuneately I do not have a diagram for your model per say.
  • Robert Moller
    Goodman web site says no such model number.
Where. Is the capacitors
the capacitors are connected to the electric motors and compressor
they will be small units in the room unit and large unit on the outside unit
Oct 14, 2015 | Heating & Cooling
How do I install the Start Capacitor and Run Capacitor
the 30 uf side is for compressor run cap and 5 uf side is for fan motor. the other capacitor is for compressor start should be able to replace wire for wire.
Sep 23, 2015 | Heating & Cooling
How can you tell if the capacitor is not dead?30/4mfd/370 for air conditionner york
Usually you just change them out. They are not on motors that have other parts the fail in most cases. They are not that expensive either. But if you want to test one, the cost of the meter is more than the part.
Jun 17, 2013 | Coleman York Luxaire 30 4 Uf 370 Volt Dual...
Indoor fan barely turning
the three post capacitor has c for line voltage in, the f or fan is for the outdoor motor,and com or comp goes to start winding compressor.youll have to follow wires from indoor motor to find capacitor. to find wires to outdoor motor to capacitor you have line voltage and capacitor wires .look for schematic it would help or send colors of wires from both motors and compressor common,start .run.
Jun 07, 2013 | GE Zoneline AZ55H07D Air Conditioner
What is the value of the dual run capacitor
Hi, depending on the size like a 5ufx35 or 40 uf x either 370 volts or 440 volts cost around $14.00 give or take. The last I bought at Grangers supply, a 5uf 370 volt x 40 uf was exactly $ 14.80. Not that expensive. They go up the higher the volts as 440 and mirofarads.
Best to you,
Shastalaker7
A/C and Heating Contractor
Jul 01, 2010 | Carrier 38CKC048 Air Conditioner
Does a gemtech 40 + 5 mfd work with a comfortair
Hi, as long as the 40uf x 440 volts and 5uf x 440 volt capacitor are the same is what you are replacing, yes it will work. Don't replace this 40 uf x 440 volt with a 40 uf x 370 volt cap. Voltage and microfarads must be the same, brand name makes no difference or these numbers, only the uf and voltage. Must be a 40 uf x5 uf, 440 volt dual run cap. It will work if the unit you want to put it on calls for that cap. The comfortair is a 3 ton unit, just be sure it takes a 40x5x440 volt and it will be fine.
Shastalaker7
Jun 04, 2010 | Heating & Cooling
YORK CONDENSING UNIT MODEL H1RA042506D WIRING SCUMATIC BLOWER MOTOR WILL NOT START WITH OUT A PUSH. START COMPASITOR MAY BE BAD BUT WITCH ONE IS IT. MOTOR NAME PLATE CALLS FOR A 370MFD. I FOUND A 36MFD...
The capacitor for the fan will read 370uf 5 uf. The 370 is voltage at cap. My guess would be a 7.5 uf cap for your fan. If you read the cap. it will tell you size. Fan caps go between 5 and 20 uf or microfards. Easy to replace you can do it yourself. Rus
Oct 29, 2009 | Heating & Cooling
WHAT SIZE DUAL CAPACITOR DO I NEED FOR A RCA36A21
You need a 40 by 5 uF by 370 VAC capacitor ,also you can look at the old one or with the model number of the unit go to the a/c supplier and they 'll give you the rigth one.
Aug 16, 2009 | Amana Heating & Cooling
Schematic missing - need to know which cond unit
Black wire goes to contactor. On your capacitor the brown wire goes on one side the blue and the other wire from your contactor goes on the other sideof the capacitor. Russ
Aug 07, 2009 | Heating & Cooling
Reinstall capacitor 370 vac from a/c
Here is the standard connection of dual capacitor. Actually you can see the diagram on the unit but Im not familiar with the Intertherm model. What can I give to you is only the standard connection of dual capacitor.
Feb 26, 2008 | Heating & Cooling
Heating & Cooling Logo
151 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
