Question about Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher
Bosch Exxcel model number SGS46E12GB had the check water light on a week ago, checked supply and cleaned filters, all good. light still on, got upset and slammed the door, light off. since then the unit will either wash stuff, or not. didn't seem the arms were spraying very well when I opened the door, so I bypassed the door switch tonight and put it through a pre rinse cycle. (I ran it with the bottom filters removed) upshot is the pressure of water was really poor. also, when I first turned on the program, it put water in, then emptied, then in, then emptied, 5 times it did this, then the MC started. as I felt thewater was way low, I threw in a few mug fulls, and hey presto, much much better pressure, and the blades are now spinning. so heres the rub, any idea what the issue is?
3 Suggested Answers
SOURCE: No pressure during wash cycle
check capacitor on motor. possibly not turning at correct speed
Posted on Jun 10, 2008
SOURCE: Bosch Exxcel Diswasher SGS43E08GB/43. Top spray
try starting the washer, then opening to door and checking the water level in the bottom of the machine, as far as I know, there should be enough water there to disolve the tablet when it sits in the bottom. if not that much, bung in a few cupfulls and you should see the pressure dramatically increase!
Posted on Nov 09, 2010
Machine is displaying F17 have cleaned out filter still having problem with dryer not working
Hi.
F17 means that there is poor or no water inlet detected.
From user manual: F17 Turn the tap on fully, check that the supply hose is not kinked/jammed; clean filter (see page 10 of manual). Also check water pressure is not too low.
If that does not fix the problem, then inlet valve, pressure from the house and water pressure switch must be tested. The defective part must be replaced.
Regards.
Ginko
Jun 18, 2011 | Bosch Exxcel WFX 2467 Front Load Washer
Hallo I have bosch dishwacher and red light check water. allready water pipe is fine.could you help me pls?? thanks
If your water supply is fine and filters not blocked the problem could be the water supply solenoid inside the machine has stopped working.
Please dont forget to vote this answer was helpful
Many thanks
Feb 13, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
What is fault code 17 on the bosch exxcel 1200 washing machine
I've found the following explanation for this fault code:
F17 Turn the tap on fully, check that the supply hose is not kinked/jammed; clean filter (see page10 of manual). Also check water pressure is not too low.
Hope this helps
kcomp1863
Jan 20, 2011 | Washing Machines
I have F:17 flashing on my washing machine, what does this mean?
Turn the tap on fully, check that the supply hose is not kinked/jammed; clean filter in pipe connector on machine. Also check water pressure is not too low. hope this helps. F17 is water problem
Sep 19, 2010 | Bosch Exxcel WFX 2467 Front Load Washer
My bosch exxcel has water sitting in bottom and doesn't appear to be draining down.
Check to see if there is a removable lower plastic cover at front of washer, if there is, then remove this, and you should find the pump filter located here, unscrew anticlockwise to remove and clean.
If no sign of filter, then remove rear panel of washer, and access the pump from here to check for blockage.
Please rate my solution.
Thanks.
Nov 09, 2009 | Bosch Exxcel WFO 2465 Front Load Washer
Check Water Supply display lights up
It sounds like there is a filter or screen on the water inlet that is partially clogged, check for that.
May 17, 2017 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch classicxx dishwasher not working check water light on
he there,
sounds like there may be something caught in the drain pump itself.
can you provide me with the complete model # on your dishwasher please?
thanks
Sep 25, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch Exxcel dishwasher "check light" indicator
**** out the water with a shop vac. Consult manual for self diagnosing keypad codes.
Jun 08, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher Logo
181 people viewed this question
Top Bosch Dishwashers Experts
shaun taylor
Carmen Mikulic
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
