Question about Singer 2517 Mechanical Sewing Machine
Thread from the bobbin is not threading into the machine
  • 244 Answers
First, be certain you have the bobbin in the case correctly. Next, be sure you have a good, tight wind on the bobbin thread. Third, be sure the needle is inserted correctly( the groove should be toward the front of the machine). If none of these is the problem, I might have some other suggestions, but check each of these three first! Good luck!
Posted on Nov 10, 2010
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
kent581
  • 87 Answers
SOURCE: Upper thread knots up with bobbin thread when sewing a stich
Thread test
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Thread knotting on the bobbin can be a lot of things but here's some guidance:
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Jamming bobbin case:
If it is damaged from turning out of place once, it could have rough spots on it that makes the thread hang on it, and keeps making it turn over and over. Use a finger nail board (fine sanding) and smoothall rough spots. Then reset the bobbin case taking care to put the notch in the bobbin case in alignment with the proper spot in the machine (basically 5 o’clock) when looking at the round area where the bobbin case goes.
Posted on Mar 18, 2009
  • 25 Answers
SOURCE: machine is threaded but thread not sewing into material, just holes!
Check bobbin thread....Insert the bobbin thread into the bobbin case in a clockwise direction...pull the thread through the **** on side of bobbin case and slide up into small opening...make sure you pull through about 2 inches of thread to enable upper thread to loop. Good Luck
Posted on Jun 02, 2009
Mongo32
  • 111 Answers
SOURCE: Sewing machine will not pick up bobbin thread.
needle's in backwards
Posted on Jun 11, 2009
  • 1116 Answers
SOURCE: Bobbin thread will not stitch.
Have you had the machine serviced since you purchased it? This is something that should be done at least once a year.
Take the machine to a certified Singer dealer and explain what is happening. There may or may not be something that needs to be adjusted.
Your warranty is still in effect, but is now limited. Attempting to repair it yourself or having someone who is not a Singer dealer repair it will invalidate the remaining warranty.
Posted on Apr 16, 2010
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
The directions are very vague about how to thread the bottom bobbin. I have no idea how this is to be done or how the needle will pick it up. Help Please!
you don't thread the bobbin as such
wind sufficient thread on to the bobbin (use the rewind section of the machine )
place the bobbin in the bobbin carrier in such a manner that the thread unwinds anticlockwise
take the thread and pull it around the edge of the bobbin holder until you reach the slot in the holder
pull the thread down that slot and under the flat spring plate at the bottom of the slot
That plate controls the tension of the bottom thread
pull out about 5" of thread and while holding the thread put the bobbin holder and the bobbin into the machine making sure that it goes right in and clicks in place ( turn it to achieve the click
The needle should be fully up for this procedure
now thread the needle and hold the end of the thread while you hand turn the machine in the sewing direction
the needle will go down and if not on the first time will on the second time pull up the bobbin thread
pull that bobbin thread up and place it along with the needle thread under the foot plate and out the back comment if that doesn't work as there may be a bigger fault that can be fixed
May 27, 2016 | Sewing Machines
Thread a bobbin on a 5825c
If you mean the Singer 5285C, the manual is available from Singer here: http://www.singerco.com/uploads/download/449_5_6_8_10_slide.pdf . The diagram for winding the bobbin is on page 14 and inserting the bobbin is on page 15.
I'll attempt to walk through the steps. Push in on the indent on the hand wheel to lock the needle in the current position (note rotate the needle up first). Then with a spool on the spool pin and the cap securely holding the spool on the pin, snap the thread through the thread guide post (near the center back of the top of the machine). Then wind the thread clockwise through the bobbin tension guide (towards the center front of the top of the machine). Next run the thread through the hole in the bobbin (inside to outside). Place the bobbin on the bobbin spindle on the front of the machine near the right hand side of the machine. Hold onto the thread end at the bobbin and start pushing down of the foot controller. Fill the bobbin to the amount of thread that you need, or until it stops. Cut the thread going from the spool to the bobbin.. Remove the bobbin from the spindle and trim the thread end that is sticking through the hole in the bobbin. Press the hand wheel disc on the side opposite from the indent.
Inserting the bobbin requires you to lift the presser foot and have the needle in the highest position. Slide open the face plate and remove the empty or wrong color bobbin. With the hole in the bobbin up, pull about 4" of thread off the bobbin. Place the bobbin in the bobbin case and hold it down lightly with a finger. Guide the thread through the notch near the front of the bobbin case. Then lead the thread down into the slot on the left and then around the second notch. The thread should be heading towards the center of the bobbin (left to right). Pull the thread diagonally back to the back of the machine and slide the bobbin cover closed. The thread should be coming up through the opening between the cover and the needle faceplate. To pull up the bobbin thread, thread the needle and then hold onto this top thread. Rotate the hand-wheel towards you until the needle rises above the needle plate. Gently tug on the top thread to bring up the loop of thread. Separate the needle thread from the bobbin thread with your fingers. Bring the top thread through the left side opening in the presser foot and then pull both threads to the back of the machine.
I hope this helps.
May 24, 2013 | Sewing Machines
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
The bobbin thread will not pick up. The machine had jammed and I forced the wheel and can't get bobbin thread to pick up. When I thread manually, I only get holes, no stitches. Is it a timing belt?
check your needle to see if it's bent---roll on flat surface to see if it roll correctly
on some sewing machines when the thread comes off the thread take up lever it can cause the machine to jam
also if the bobbin thread becomes tangled it can jam
check the bobbin area for lint or loose threads
try having a top thread tail & bobbin thread tail of 3-4 inches
try holding the top thread tail & turn the handwheel on the right side on the machine manually & put the needle down into the bobbin area & see if the bobbin thread will pick up that way
Sep 24, 2010 | White Sewing 2037 Mechanical Sewing...
How do you load the bobbin properly?
Well you may please follow the steps below -
1. Remove the bobbin from the sewing machine. Note: whether you have a drop-in, front or side-loading bobbin on your sewing machine. A drop in bobbin will load from the top, may be via a removable bobbin case cover near the machine-fed dogs. A side or front loading bobbin needs to be loaded into a removable bobbin case under the machine.
2. Choose the right size bobbin for the sewing machine.
3. Wind thread onto your bobbin. Your sewing machine should have a standard thread spool to hold the thread and a short, squat post wide enough for a bobbin.
4. Put the thread and empty bobbin into position on your sewing machine. Wrap the thread around the bobbin to start it. On most machines, disengage the needle by turning the smaller hand-wheel on the machine toward you. Push the bobbin post into position, securing the bobbin into place. Press gently down. Thread should begin to wind neatly onto your bobbin.
5. Break the thread, push the bobbin post back into an inactive position and remove the bobbin. Tighten the hand-wheel. Thread your sewing machine again if necessary before loading the bobbin.
6. Remove the bobbin case cover and put the bobbin into position. The thread should slide through a catch on the bobbin case and up through the cover.
7. Access the bobbin case for a front or side mount bobbin. Lift the catch and remove the removable bobbin holder. Put the bobbin into the holder and run the thread through the holder, bringing it to the front. Lift the catch and slide the bobbin holder back into the case. Hold your needle thread gently forward with your left hand and turn the hand-wheel. The needle thread will pass down into the machine and catch a loop of the bobbin thread. Pull this loop up and slide both threads to the back before beginning to sew.
Good Luck!!
Thanks for using FixYa!!
Sep 22, 2010 | Euro-Pro Shark 60 - 384
How to thread the bobbin on a singer simple sewing machine
Drop-in bobbin: Note: thread must change direction when entering bobbin shuttle notch. Usually bobbin will turn counter-clockwise when threaded properly.
1. hold bobbin so that the tail of thread is facing to left.
2. drop bobbin into bobbin shuttle.
3. pull thread toward you.
4. guide thread into notch and pull to left so that slot engages thread.
5. pull thread diagonally across shuttle toward back of machine.
6. draw bobbin thread up through needle plate with threaded needle.
Oct 31, 2009 | Singer 3116 Simple
Machine is threaded but thread not sewing into material, just holes!
May 10, 2009 | Sewing Machines
Thread test
Step 2:
Tension:
Mar 16, 2009 | Sewing Machines
Singer 2517 Mechanical Sewing Machine Logo
49 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
