Question about Toshiba Satellite L10 Notebook
How do I save data on a Belkin memory stick?
I have never used one before - thanks!
  • 106 Answers
Just plug it up, it'll show up in your "my computer" as another drive.. copy your data over to it, and you're on your way!
Posted on Jun 17, 2008
How can I recover data from the Sony DCR-SR42 video camera. I set the recorder..I verified it was recording and when i turned the camera on it said "recovering" data and then no data found. Any...
You can recoverlost photos,videos from memory card or memory stick of your camcorder withthis
1. Do not save any new photos and videos into the memory card or memory stick.
2. Connect the memory card or memory stick with computer. You should see itshown as a drive letter (like H:) in My Computer.
3. Download memorystick recovery software, recommended one is Tenorshare Data Recovery(simply because i was using it and it worked)
4. Install and open the program, select your memory drive, and click 'Start'button to start scanning process which will find your lost photos and videos.
Sep 05, 2011 | Sony Handycam DCR-SR42 Camcorder
Memory stick with loads of data on it but computeer says it needs fromatting before i can use it. This will erase data what can i do please?
search google for ZAR (zero assumption recovery) software, download for free and use unlicensed test version. install to pc, put your card into your pc's card reader and run ZAR, follow steps given to copy your data to hdd, it will take some time to read and save the memory stick. hope to helped you
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Feb 20, 2011 | Computers & Internet
How to use a memory stick right from the start
  • Understand how a Memory Stick Pro works. The small card saves information from a portable device. You can save, delete and rewrite to the card as many times as you want. You can also remove the card and insert it into another device. For example, you can save photos from a camera, then insert the memory card into your laptop to view or download the images.
  • Step 2 Make sure you buy a memory card that matches the demands of your electronic device. The cards have different saving speeds and data-holding capacities. Generally speaking, the more data the card can hold and the faster its speed, the more expensive the memory card. Check your electronic device's product information for recommendations on the best type and size of memory card.
  • Step 3 Insert the Memory Stick Pro into the electronic device. Most devices have a small flap or cover on its side that holds the card. The memory card slides into a slot under the flap. Gently push in the card and close the flap.
  • Step 4 Save to the memory card. Once the card is installed, many devices know to save new data to the card. In some cases, however, you may need to specify where to save files, either to a built-in hard drive or to the memory card.
  • Step 5 To remove the card, open the flap and gently press the card in. The card should then pop out of the slot for easy removal. The card can now be inserted into another device.
  • vote me if your setisfied
    Jun 29, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
    I downloaded the update but the pc cannot open the file . the updater is called eboot. i have it in my pc but cannot open it
    The file is not supposed to be opened by your PC. You have the transfer the file from your PC to the PSP. To do this, you need a USB cable and you have to plug your PSP into your PC.
    Download procedure
    1. Prepare to save the update data on either system storage or Memory Stick Micro™ (M2)™ media, using one of the following methods:
      • Connect the PSP® system to the PC using the USB cable
      • Connect a commercially available Memory Stick USB reader/writer to the PC
      • Use the Memory Stick slot on a PC
    2. Create a folder for the update data on either system storage or Memory Stick™ media.
      Using your PC, create a folder named "PSP". Within the "PSP" folder, create a folder named "GAME". Within the "GAME" folder, create a folder named "UPDATE". (Folder names must be in all uppercase letters).
    3. Download the update data for the PSP-N1000 (PSP®go) series and save it in the "UPDATE" folder created in step 2.
    You must save the downloaded data as noted in these instructions. If you do not save in the correct location and with the filename shown below, the system will not recognize the update data.
    • Filename: Save as filename "EBOOT.PBP"
    Nov 19, 2009 | Sony PlayStation Portable (PSP) Console
    The Error message C:13:XX indicates that the Camera cannot read or write data on the Memory Stick or an unformatted Memory Stick is inserted in the Camera or the inserted Memory Stick cannot be used with your Camera or the data is damaged.
    1. Try reinserting the Memory Stick several times.
    2. Format the Memory Stick in the Camera.
    *Formatting a Memory Stick will delete all the data saved in the Memory Stick.
    Insert the Memory Stick in the Camera, Turn ON the Camera. Press MENU -> Memory Stick Tool -> Format -> OK.
    Memory Stick compatibility information for you Camera:
    3. Try with different Memory Stick.
    Good Luck!!!!!!!!!!!!!!!!!!!!
    Aug 28, 2009 | Sony Cyber-Shot DSC-P43 Digital Camera
    I need to know the steps to save data onto usb memory stick from accounting program
    I suggest that you save your data with Simply Accounting and know where you save it. In window explorer, find the file you saved and copy it to the USB memory stick. You should see the USB memory stick as another drive in Windows Explorer. After the copy is complete, Click the USB memory stick and you should see the file. This way, the copy (back up) is confirmed.
    May 30, 2009 | Dell Computers & Internet
    Pictures only save to internal memory, not memory stick...
    DSC-W80 sybershot camera has facility when you insert Memory Stick in its slot, it automaticaly selects this memory card and starts saving data on it and internal memory got suspended.
    Pls check memory stick 2GB and inert it correctly in memory slot in camera.
    Aug 14, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
    Memory stick use
    plug the memory stick into a USB port.
    wait for your system to recognize the hardware ( an autoplay screen should open)
    select open to view files.
    drag and drop what you want to save in the mem stick. that's it. pretty straight forward. ^_^
    Jun 09, 2008 | Toshiba Satellite L10 Notebook
    Cant upgrade my ps3
    maybe you didnt download the update data to the memory stick, maybe you downloaded it to your pc. Next time download the update data to the memory stick and not the pc.
    Aug 13, 2007 | Sony Playstation 3 (PS3) Console
    Sony psp
    If you tried to delete the save game from the memory stick and it's not letting you. Copy what you need off of the memory stick to your PC via the usb cable and reformat your memory stick.
    Jan 27, 2007 | Sony PlayStation Portable (PSP) Console
    Toshiba Satellite L10 Notebook Logo
    26 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
