Question about HP Pavilion dv1000 Notebook
No power - no boot
I actually got it to power up and it worked for over an hour. Then it suddenly shut down, and have had no luck re-booting. When you say the powersupply, do you mean the power adapter? Or do you think this sounds more like motherboard?
Thanks so much for you help!! One day it just would no longer power on. I took it to a shop and when he plugged it in, it work for a short period and then shut down again. Are there any solutions. I've only had it for two years and I can't believe it has died on me.
  • 4,472 Answers
I'm sorry you couldn't find my solution a little more acceptable at least helpful. Like i said previously it is about a 200$ laptop and the servicing of the parts in question are more then that.
If you need any further assistance don't hesitate to ask me,
Lee
Posted on Jun 17, 2008
  • 3,940 Answers
Could be the power adapter. Sometimes they start to overheat and shutdown.
Could be other things, but the AC adapter is the least expensive to fix
My D620 starts to boot up then shuts down suddenly
could it be that your battery is no longer holding a charge?
try powering it up with the power pack attached (and ensure the light on the power pack is indeed lit) - it also could be that the laptop is not being charged by the power pack.
Jul 14, 2010 | Dell Latitude D620 Notebook
My laptop turned off but it has 35% remaining battery
Laptop turns off suddenly? Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage.
If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed.
Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
May 29, 2010 | Computers & Internet
Turns off suddenly
Mar 27, 2010 | Toshiba Satellite M55-S331 Notebook
Shuts down
Hi..
If the laptop shutdown maybe it cause overheating.
Laptop shuts down? Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot. The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down. Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Good luck !!!
Regards
PCmania
Jul 15, 2009 | HP Compaq Presario V6000T Notebook
Dell Inspiron E1505 Notebook will not power up..
Try taking out battery and plug in power. If it works, battery is faulty.
If not, try taking out your hard disk plug in power, if it works, hard disk is faulty.Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Apr 19, 2009 | Dell Inspiron E1505 Notebook
THE LAPTOP JUST SHUTS IT SELF DOWN
Check if the cooling fan is actually turning on or if the exaust is cloged with any derbis. If so, you should try cleaning them and later observe if it works. However, if the cooling fan fails to run you should replace it.
Mar 22, 2009 | Toshiba Satellite A205-S5809 Notebook
No power - no boot
You need to State some of your Symptoms... Like what you are seeing when attempting to boot.... is the screen just black?? do you see the BIOS POST... does it go to loading windows... do you see any lights turn on after hitting the power on button.?.. do any fans spin?? More Info.....
You might want to check the Heatsing Fins and the fan(s) they're probably clogged and your laptop is getting overheated and causing it to shut down... Unless it doesnt power on at all.. no lights no nothing... then it's most likely your motherboard..
Jul 07, 2008 | HP Pavilion dv6000z Notebook
No power - no boot
no power no boot can be indicative of a motherboard failure or could also be the memory. try removing all the memories, hard drive, the optical drives and all external devices connected to your computer. if you get to hear a beeping sound .. your in luck your motherboard is alive and just need to isolate which among the remaining pieces is causing the no power.
Jun 14, 2008 | HP Pavilion dv1000 Notebook
No power - no boot
for this two resasons is there one is your power and other one is your ram in your note book can do change the both the thing for testing purpose . or check it the power adapter to other note book. after that you get it.
Jun 11, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
