Question about Acme 5001 Supreme Juicerator Juice Extractor
My Acme 5001 Juicerator vibrates around on the countertop. The rubber pads seem to be falling apart. Can I replace them? Where do I get them? Thanks David II
    Champion:
  • 356 Answers
Dave, contact Waring at 1-800-492-7464 and order
a new foot ring. Here's a tip. When the juicer is
not in use find a bowl cover or something to fit
in side the circumference of the foot ring for the
juicer to rest on. That way the foot ring won't
stick to the counter and rubber won't compress
over time.
Posted on Jan 30, 2011
Opening lid to add fruits
The Manual for the Acme 5001 Supreme Juicerator can be downloaded from the following link:
http://www.everythingkitchens.com/PDFfiles/6001.pdf
Items to be juiced must be cut to size and fed through the feed chute. The machine will not operate if the cover is not properly in place.
Jul 23, 2012 | Acme 5001 Supreme Juicerator Juice...
When i juice greens i am no longer getting any juice from them. is my blade dull?
If you mean green leafy greens, the juicer is
not really designed for them. A sharp blade
will extract some juice from them, but I found
a new blade seems to increase the vibration
issue. Acme works best on carrots, apples,
celery, etc.
Oct 25, 2010 | Acme 5001 Supreme Juicerator Juice...
ACME Supreme Juicerator sudden extreme vibration during juicing - top flew off...
These juicers vibrate, I don't care what anyone tells you.
Mine is 21 years old and I find using a worn resharpened
blade, after adjusting, lessens the vibration. If your not
close to being an auto mechanic, I suggest a pulp ejecting
type juicer like the Miracle MJ1000 for about $130.
May 22, 2010 | Acme 5001 Supreme Juicerator Juice...
Why does my supreme juicerator shake and make noices
the rubber banding on the bottom of the shredder disk gets worn over time and you might need to buy a new shredder disk. I was experiencing the same problem (the juicer was vibrating at an odd speed,shaking and the sound of the motor was distressed, when the plunger was inserted to push down the veggies it was banging and making an awful noise) replacing the disk solved the problem - good as new.
Sep 28, 2009 | Acme 5001 Supreme Juicerator Juice...
Acme 6001 juicer. Excessive vibration and movement during use.
usually the vibrations are caused by improper assembly ( it does not take much ) or the rate of feeding material into juicer. feed the juicer too fast and it gets out of balance.
Jan 04, 2009 | Acme 5001 Supreme Juicerator Juice...
Excessive vibration and movement of  acme 6001 juicer during use. Tried different products, using less, not helpful.
test by running empty for several minutes,, should be smooth running. then feed the juicer slowly. I have not seen a problem with what I feed in, solid or pulpy material not leafy material.
Cleaning
http://www.smallappliance.com/product.asp?pid=9879&cur=USD&sid=18956&mid=34&gid=18975&prdCls=P&shopBy=Category
Jul 12, 2008 | Acme 5001 Supreme Juicerator Juice...
Acme 5001 on / off button
REMOVE THE 4 BOTTOM SCREWS AND
TRY IT AGAIN. YOU CAN SEE THE SEAM
AROUND THE JUICER WHERE IT SEPARATES.
YOU CAN GET THE SWITCH FROM WARING
AT 800 492 7464. MINE IS FROM 1990 AND
RUNS LIKE NEW. DO ALL MY OWN REPAIRS.
Mar 10, 2008 | Acme 5001 Supreme Juicerator Juice...
Acme 5001 Supreme Juicerator Juice Extractor Logo
238 people viewed this question
Top Acme Juicers Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you an Acme Juicer Expert? Answer questions, earn points and help others
