Question about Sunbeam 5891 Bread Maker
Used 2 times in a row, but now get HHH when trying to restart
    Genius:
  • Sunbeam Master
  • 1,280 Answers
That just means that your the oven chamber is too hot from the last loaf you baked in it. It does that because the ingredients have to be at at the correct starting temperature or you won't get a good rise. It's designed to do that.
However, ifIf you have let your machine cool off (open the lid and leave it open after baking for about half an hour) and still shows the HHH then you have a more serious problem and should call or contact Sunbeam.
Posted on Nov 10, 2010
9VJL3 front panel
Do not have the Front Panel header pinout.
Do have;
Take an LED (Light), with two wires, and check the pins with it.
There is a Top row of pins, and a Bottom row.
Touch the first two pins in the Top row, left side. Does it light up?
No? Go to the next two pins. No? Go to the next two pins.
Keep going until the Power Supply comes on. (It is a BRIEF touch. The Power On switch is a Momentary Contact Switch )
Now you have the Power On switch pins.
LED light blinks? You have the Harddrive activity LED. (Light)
LED light stays on? You have the Power On LED. (Light)
Computer restarts? The Restart switch pins.
Short something out? NOPE. You can't hurt a thing using this method.
4 of those pins are for an internal speaker. (To hear BIOS Beep Codes with)
That's 12 of those 18 pins. (Probably less. It is two rows of 9 pins, that are stated for the Front Panel header)
4 of those pins probably won't be used.
You won't be using IR. (Infra Remote) (Only uses 2 pins, though)
Most of the time with an 18-pin Front Panel header;
Top Row:
Starting at Left side, going towards Right;
Pins 2, 4, 6, 8, 10, 12, 14, 16, and 18.
May be a pin missing in this row, or two.
Borrom row:
Pins 1, 3, 5, 7, 9, 11, 13, 15, 17, and 19.
Same thing here. May be 1 or 2 pins missing.
Pins 2 and 4 are usually for the Power On LED. (Light Emitting Diode)
Pins 6 and 8 - Power On switch.
Pins 10, 12, 14, and 16 may be for the Internal speaker.
Pins 18, and 20 are usually not used.
Pin 1 and 3 for the HarDDrive activity LED.
Pins 5 and 7 for the Reset switch.
Pin 9 is usually reserved for the factory, and is a 5 Volt test point.
Pins 11, 13, 15, 17 for speaker; or not used. Same with pin 19.
(So speaker pins may be top row, or bottom row. Dunno )
Another thing. This motherboard is old enough to be using a 3 wire LED, or dual color; for the Power On LED.
LED usually had the colors Green and Yellow.
Yellow for 'Normal' mode, Green for 'Turbo' mode.
(Which is a bunch of cr@p.
Green LED, or Turbo Mode; was actually NORMAL.
Normal mode was the computer operating BELOW the Normal mode)
So pins 2, 4, and 6, may be for a 3 wire Power On LED.
Regards,
joecoolvette
Dec 22, 2012 | Chaintech 9VJL3 P4(478)/VIA Motherboard
HHH code, NOT a second loaf.
1- DELAY TIMER HAS A SWITCH FUNCTION THAT HAS FAILED. 2- WASH INSIDE OF BREAD MAKER WITH COLD WATER, DRY, AND TRY TO SET TIMER. 3- BREAD MAKERS ARE NOT AS POPULAR AS THEY USE TO BE, AND ARE AVAILABLE AT USED ITEM STORES FOR 15 TO 25 DOLLARS.
May 03, 2012 | Sunbeam 5891 Bread Maker
Model# 501 ht mb HHH message in both wash and rinse temp display at different intervals,extreamly hot. cant find manual, washer installed 2 yrs ago not 1 problem untill yoday
Possibly the booster thermostat needs replacing. Expansion of the water in booster enters the wash tank when boiling showing HHH on both displays.
Mar 22, 2011 | Moyer Diebel 24 in. 501HT Built-in...
Help with Curious Village game on Nintendo DS
Hi Gill
For square 1, use pins 1 and 2 from row 1, and pins 1 and 2 from row 2.
Square 2 uses pin 1 from row 4, pins 1 and 3 from row 5 and pin 1 from row 6.
Square 3 has pin 3 from row 3, pins 2 and 4 from row 4 and pin 4 from row 5.
Square 4 is formed with pin 5 from row 1, pins 4 and 6 from row 2 and pin 4 in row 3.
Square 5 involves pin 3 from row 1, pin 5 in row 2, pin 2 in row 3 and pin 3 in row 4.
Square 6 has pin 3 in row 2, pin 5 in row 3, pin 2 in row 5 and pin 3 in row 6.
Square 7 uses pin 4 in row 1, pin 1 in row 3, pin 5 from row 4 and pin 2 in row 6.
Hope this helps and good luck!
Scott
Mar 25, 2010 | Nintendo DS Console
I can get 7 squares but I'm told it's wrong
SQUARE 1.= use pins 1 and 2 from row 1 and pins 1 and 2 from row 2!
SQUARE 2= use pins1 from row 4 , pins 1 and 3 from row 5 and pin1 from row 6
SQUARE 3= use pin 3 from row 3 , pins 2 and 4 from row 4 and pin 4 from row 5
SQUARE 4= use pin 5 from row 1 , pins 4 and 6 from row 2 and pin 4 in row 5
SQUARE 5= use pin 3 from row 1 , pin 5 in row 2 , pin 2 in row 3 and pin 3 in row 4
SQUARE 6= use pin3 in row 2 , pin 5 in row 3 , pin 2 in row 5 and pin 3 in row 6
SQUARE 7= use pin 4 in row 1 ,pin 1 in row 3 , pin 5 in row 4 and pin 2 in row 6.
Feb 24, 2009 | Nintendo Professor Layton & the Curious...
Type mismatch in MSFlexGrid Control
type mismatch error occours when there is a mismatch between the value which you are trying to assign to a variable which is dimensioned to store values of another, first you check if the datatypes match each other by applying the break.
Dec 19, 2008 | Microsoft Visual Basic 6.0 for PC
Sunbeam 5891 Bread Maker Logo
475 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
