Question about Vacuums
LIGHTING QUESTION: I have a GE Pro line T8 Ballast w/ (8) wires (2) Blue, (2) Red, (2) yellow plus Black & White. I know what the Black & White are for and are not connected to the lamps. Can you give me a wiring diagram or explanation on how to wire the new ballast into the old fixture. This is for a (2) lamp configuration. Thanks
    Master:
  • 383 Answers
Try this link-- for a wiring diagram--- let us know if this helps-- Mack
http://www.replicasuper.com/wp-content/uploads/2016/01/T12-Ballast-Wiring-Diagram-Here-Is-An-Example-Of-A-Circuit-That-You-Can-Make-The-Guidelines-For-Making.jpg
Posted on Nov 04, 2017
  • 97 Answers
SOURCE: Replacing Power Cord Kenmore Progressive Upright
That actually sounds correct, if it's the model I'm thinking of. As long as you're talking about connecting to the wires that are held in by the wire nuts you should be good to go.
-R
Posted on Mar 03, 2009
  • 389 Answers
SOURCE: Connecting motor part
Hi Charlotte,  Yes, colour coding of wires is a nightmare, isn't it!? Red and brown both signify "live", and blue and black both signify "neutral".  So you should connect brown to red, and black to blue. I hope this is helpful. If you need more guidance, please post here again and I'll see what more I can do for you. I value your feedback, so please remember to rate my response. Good luck!
Posted on Mar 04, 2009
galati2k
  • 281 Answers
SOURCE: replacement motor wiring-not exactly like the old one
yes but make sure the motors are exactly the same.check the voltage on both of them and see if they are both ac motors and not dc motors.if the new motor is dc it won't work.i have a hoover savvy that has a dc motor that i want to replace with a ac motor
Posted on Apr 28, 2009
  • 41 Answers
SOURCE: i need a wiring diagram for a rainbow d4c
Are you talking about the power switch. The new power switches have 4 wires sautered to the power switch, where the old ones have 6 wires that slip in and lock into the power switch.
The blue ones are for your power cord, and the black ones are for your vacuum motor, and your power nozzle plug.
Secure one motor wire and one power nozzle plug wire to one of the black wires out of the new switch, and secure the other two, to the other black one from the power switch. It does not matter which ones that you match together. Secure one of each of the power cord to the two blue wires from the power switch. It does not matter which one of them goes to each wire neither. It is AC so power goes both ways.
Use twist on wire nuts to secure the wires to each other, and put some electrical tape around each of them, after you secure them securly with the wire nuts.
It is best to secure the cluster of wires to each other with a pull tie, after you are finished wiring everything.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Posted on Jun 13, 2010
  • 383 Answers
SOURCE: I put brand new T8
Are they actually flickering on and off?- or just sort of Twirling patterns of lighter and darker shade of light? -- That is normal when the bulbs are new-- That should become steady in a few days.
If not-- tell us more what is happening-- in detail.
Mack B
Posted on Dec 28, 2010
Which wire is the power wire on the jlt pump
post a picture of the wiring but hot is generally black neutral is generally white ground is always green sometimes they use red blue dark yelloow purple as hot so it is hard to say which color the unit uses there are only about 3 wires maybe a 4th if it has a seprate switch for the pump but the picture of the circut would answer my questions
Jul 12, 2014 | Rug Doctor Mighty Pro X-3 Ready Pack...
Ametek wiring diagram for a Oreck XL21 600 ECB
I cannot find a wiring diagram from where I am located right now, but I do know that the black wire coming from the power cord goes to the top side of the motor when you have it laying upside down with the cover off, and it will go to the tab towards the back of the vacuum. Sometimes they put a black dot beside the tab and if that is there you put your wires from the power cord on those. You will also have two wires coming from your light bar in front and the white wire will usually have a piggy-back terminal that your white wire from the power cord attaches to as well. If there are no black dots beside the terminal tabs the white wires will connect to the bottom terminal on the opposite side from the black power cord wire. It will usually be on the lower side of the motor as well. The black wire from the light bar will go on the remaining terminal tab as there is usually only three tabs on the motor. I will check back later this week to see if this has helped you and if not I should be able to get a diagram this weekend.
Sep 22, 2013 | Oreck Vacuums
Need wiring schematic for ametek 119550
I had the same problem after not paying attention to the connections when replacing my motor. I spent days searching for information and only found several non-answers with small photos that no one can read.I contacted Oreck for wiring information. They explicitly stated that they can't provide any wiring information for safety and liability reasons.
I found the Ametek schematic which shows the LINE and TAP locations on the motor.
Note: I have a 2600HH XL with 2 headlights.
Connect as follows:
3A, LINE: White lead w/piggy back terminal from light harness #1 & white lead from the power harness to the piggy back terminal
2A, TAP: Black lead from light harness #1
3B, LINE: White lead w/piggy back terminal from light harness #2 & black lead from the power harness
2B, TAP: Black lead from light harness #2
Dec 13, 2012 | Vacuums
I am tiring to install a GE touch auto shut-off timer, I have 2 wires in the wall 1 black & 1 white, the switch has 4 wires (1 green[ground?], 1 blue, 1 black & 1 white) when I try to follow the...
You might not be able to use that switch in your configuration. It appears that the power was run to the light and only two wires were run back to the switch. The old switch only closes to connect those two wires completing the circuit at the lighting fixture, but you need a hot and a neutral to operate the electronic switch that you have.
Gary
Apr 18, 2011 | Vacuums
Hello, I am looking for a wiring diagram to install a touch/dimmer switch by "Comfort" mdl # RH-934B - Darjung Ind Ltd. It has a standard lampcord (two wires) coming from it as well as one...
the black and the white will go to the lamp ,eg,output.The yellow is the sensor wire which should be firmly attached to the metal base of the lamp
Mar 25, 2011 | Vacuums
I am trying to install a ge digital timer (model 15086) for a porch light. I have one black wire and one white wire coming from the wall. The timer has a white, black, red and green wire. How do I procede?
I am commenting on things are here in the u/k not u/s which is not the same but i hope this is of some help.......From the wall black and white ,this is a switch wire which is on or off, i would link this to white to white , black to black or black to red with the rest left unconnected,,,,,Check to see if you have fitting instructions indicating what wire goes where....Good luck
Feb 19, 2011 | GE Vacuums
I am installing a ge #15070 basic timer and there are 3 wires. Which wire do I attach to the ground?
GE 15070 timer does not have ground wire.
I assume this timer is double insulated, just like some power tools and electronics only have two prong plug.
Leave bare ground wire attached to other bare grounds in the box, and shove grounds to back of box.
I have one of these timers installed.
Timer has red, black and white wires
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
How to wire GE 15070 timer:
1) Switch has 2 insulated wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
3) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
4) Turn on electricity, and slide switch to ON-or-OFF. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
5) Add a comment for more free help.
6) Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 13, 2011 | GE Vacuums
GE on/off timer for a bathroom fan - switch has four wires Green - ground White - neutral Black - power Blue - lead My fan has two - white neutral and black lead I have tried...
I would guess that the black wire on the timer is the power in and blue is the power out to the fan (hook it to the black wire going to the fan) The other colors are right.
Mar 23, 2010 | Vacuums
How do you wire a 2 speed fq motor. I know the blue/blue. the red/red. The yellow /yellow and I believe the whites together with the grey of the pn outlet. Does the black from the motor the black from the...
I have not seen the new two speed but sounds like the wiring is coded to teh switch by colorOn a single speed it would be this way.
Power cord to side 1 of switch.
Switch to motor 1 and PN receptacle 1, etc
Then cord to remaining motor 2 and PN 2 so by color should be accurate.
Note PN receptacle should likely be powered at both speeds....it is on other vacs
Oct 23, 2009 | Filter Queen Cheetah II Ash - MU305...
Vacuums Logo
112 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
