Question about Singer White Speedylock 1634
My white speedylock serger 1634 thread keeps getting in knots
Whenever I thread my serger, the stitches come out in knots and then the thread breaks. I have the correct tension, maybe could it be in the threading?
  • Anonymous Apr 02, 2009
    I have this same problem, and I don't have a book either, nor can I find one. I have been looking for two years! My serger breaks the thread on the far right (the pink on my machine, a Speedylock 234DE). I have rethreaded over 50 times with the same results. I have tried putting one thread on the bottom, then the other, nothing works. It was fine the other day, I didn't use it for a few days, and then it was like this. I didn't even change the thread, I didn't touch it, I don't know why it's like this all of a sudden! I need my manual, I don't even know what the dials do (besides the individual tensions.)
  • Anonymous May 02, 2009
    I have rethreaded my machine following (painstakingly) the guide provided by vthe vmanufacturer and stillo have the #2 thread breaking and the overlock not completed. I have tried adjusting the tension to no avail. any suggestions? I have a White Speedylock 1634.
I have the book and it says thread from inside out, inside looper (upper) then lower, then thread the needles, first right then left.  I have found that it does not matter if you thread the needles or loopers first but that you should try to thread from inside to out.
Posted on Feb 25, 2009
I've had this same problem. I finally fixed it by removing all the thread and slowly and painstakingly re-threaded the machine in the order shown in the instruction. The error occurred when the wrong thread was on top of the bottom looper.
Posted on Jun 23, 2008
  • 3 Answers
I have threaded and re-threaded until I am so done with this machine! I have followed the directions, but the directions are not in color, and all of the thread is shown in one diagram, and the thread is black. It is impossible to know which thread goes where, and the colored dots on the machine are good, but they are not on every little place the thread needs to go, nor does it give color order. Poor design!!!
Posted on Aug 20, 2010
My serger is not looping at all. I changed the needles and nothing is working.
Start with the threading sequence. Upper looper, lower looper, left needle, right needle. Your upper & lower loopers must be threaded before your needles or it won't make the stitch. If it still doesn't work, it's out of time and will need to be taken in to a shop.
Mar 05, 2015 | Singer White Speedylock 1634
My white speedylock 1634 the left needle only picks up the loop every 3 inches.Serger left needle is going in holes are there. I have re-threaded it several times. how can i fix this?
Try putting in a new set of needles. Make sure to fully insert the needles into the machine. If the needles are not set fully into the shaft, or if there is a burr or nick on the needle tip skipping stitches can result. If this doesn't solve your problem, possibly the timing is off and needs to be serviced.
Oct 26, 2014 | Singer White Speedylock 1634
I'm having trouble learning how to thread my White 1634 serger machine.
Take a deep breath, then go to singerco.com and look at and download your manual for free. You will be able to make the diagrams much bigger to see the threading. Take your time and do not get too frustrated, you will get it. Good luck
Sep 08, 2010 | Singer White Speedylock 1634
Can I disengage the upper looper on the White Speedylock 1634? If so, How? My manual says nothing about it. I want to do a hem on a sleeve that has two parallel top stitches and the lock-stitch underneath...
No. You would want to disengage your upper KNIFE not upper looper to do this but you need a serger with the COVER STITCH feature to do this. You can get the same effect using a twin needle on your sewing machine. Hope this helps!
Aug 22, 2010 | Singer White Speedylock 1634
My serger machine does not do the stiches and I replaced the needles already and I know that I thread the machine correctly, please help me! thanks
Sometimes we think we have the machine threaded correctly, but the stitches just won't knit - I threatened my old serger many times only to find the lower looper thread had popped out.
Open the doors and watch what is happening when you turn the hand wheel.
Make sure the thread antenna is fully extended and thead the machine with the tension open (zero) and in the order shown in the manual.
Once you get this great, but sometimes naughty little machine stitching as it should, do not let it run out of thread.
Cut the thread near the cones and tie off to the new thread.
Open the tensions and slowly run the machine until the new thread appears - you will have to stop as the knot gets to the needles and thread manually.
Mar 01, 2010 | White Sewing Speedylock 1600 Mechanical...
Coverstitching on White Speedylock serger
Your machine cannot do a cover stitch. Check the Brother website, they make a cover stitch only machine, it works much better than any of the serger/cover stitch combination machines, and it is a lot less money.
Nov 19, 2007 | White Sewing Speedylock 1600 Mechanical...
Singer White Speedylock 1634 Logo
885 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
