Question about Falcon Continental 1092 Dual Fuel (Electric and Gas) Kitchen Range
How do i fit a grill element - Falcon Continental 1092 Dual Fuel (Electric and Gas) Kitchen Range
My bosch oven grill element is not working and my oven does not seem to be getting as hot as it should. any ideas what it could be.
More than likely the grill element has failed, and this could account for the oven not getting hot enough, as on some makes, the grill element is on at the same time as the oven element, so if the element has failed, then it will not be hot enough.
My advice would be fit a new grill element, and this hopefully will solve the problem of the oven not being hot enough.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Bosch HBN 430560B / 430520B Single Oven
I need to replace the bottom element in my oven
You need to check the heating element for continuity and the thermistor for continuity. Use an ohmmeter or multimeter to check. The element should not be any reading over 24 ohms for a 220-250V supply and not over 12 ohms for a 110Vac supply. A good tip is to take digital photos of the job before starting on removing and testing wiring etc so that you can refer back to it if you have to replace any items or forget which wires attach to any particular terminal etc.
To test and replace the element:
  1. Turning off the mains power to the oven.
  2. Remove the lower back panel. Fan assisted ovens will have a coiled 2 or 3 turn element around the outside of the fan.
  3. Remove the 2 power connectors to the grill element if one is fitted.
  4. Check the element resistance reading on the main oven heating element and not the grill element.
  5. The thermistor or fusible link is located on top of the oven cavity if fitted and has two wires attached to it - most likely to be red and black or both white wires.
  6. Remove the earthing wire to the main oven heating element screw terminal.
  7. Unscrew the grill element securing screws(s) - there will be 1 or 2 depending on the element fitted to your oven. Do this from inside the oven cavity itself.
  8. Refit the new element (make sure it has the same mounting screw holes as the one you want to remove) then secure it.
  9. Reconnect the earthing wire to the element screw post.
  10. Make sure that neither of the element tags touch the chassis - check with a continuity tester of ohm meter and adjust if required.
  11. Reconnect the power cables to the main oven heating element.
  12. Reconnect the power cables to the grill element if one is fitted.
  13. Reconnect the power and check that the element works correctly.
  14. Disconnect the mains power again and replace the rear panel(s).
  15. Reconnect the mains power and recheck that the oven, and if appropriate the grill, functions correctly.
Nov 14, 2009 | Ovens
Hi - I have a creda solarplus cooker (48349) - I wish to replace the 8 bar grill element with a 4 bar grill element - can you please advise me of the steps necessary to do same - yours michael clancy
It’s basically as simple as:
Turn off the gas supply to the range.
Turning off the mains power to the range.
Remove the back panel behind the grill.
Remove the 2 power connectors to the grill element.
Remove the earthing wire to the element screw terminal.
Unscrew the grill element securing screws(s) - there will be 1 or 2 depending on the element fitted to your range.
Reconnect the power cables to the element.
Reconnect the mains power and recheck that the grill functions correctly.
Turn on the gas supply.
Oct 05, 2009 | Rangemaster Toledo 110 (Dual Fuel) Dual...
Hi need a manual for a select 920 diplomat oven
I have a Hygena 920 twin oven and grill .The electrical element in the grill started to droop several months ago, now it has stopped working . the element has burnt through. Could this have caused a fire?
I should like to know if it is possible to get a spare element and fit it myself. What would be the cost of the element? Thanking you in anticipation.
Mr J. Walden
Sep 02, 2009 | Ovens
Oven problem
Check that the solar plus grill element is working properly by selecting full grill, the whole element should heat up, if only half element heats up , then you need to fit a new grill element complete.
If the grill element is o/k , then it is possible the top oven base element is faulty, to check that is working, put top oven on and after a few minutews feel the base of the top oven, and it should be hot to the touch if it is not, then the base element has probably failed , and you will need to fit a new one.
These are the possible reasons for it to heat up slowly.
Plz rate my solution.
Thanks.
Jan 25, 2009 | Ovens
Fan and grill works but not heating up
Hi.
If the fan is working o/k, then you need a new fan oven element fitting.
Remove panel at rear of oven compartment, there you will see the element, undo any screws you can see to remove rear cover.
disconnect element taking care not to loose wires, and fit new element. test before you refit rear cover.
Plz rate this solution.Thanks
Dec 24, 2008 | Belling XOU252 Electric Single Oven
Grill element stopped working in the middle of grilling roast pork. Blown element vs fuse - don't know where to find fuse box on oven. How do you tell if the element has blown? Is it easily repairable or...
there is no fuse actually in the oven
take rear panel off oven and use a multimeter to check continuity across the grill element. can also be the grill regulator if fitted
Jun 29, 2008 | Kitchen Ranges
Rangemaster Toledo 110 oven/Grill element
How easy is it to fit a new grill element. The element on the left hand side of the grill is not working so I need to replace this. I'm just wondering if this is easy to do myself or do I need an
electrician
Regards
Sandra
Dec 15, 2007 | Kitchen Ranges
Falcon Continental 1092 Dual Fuel (Electric and Gas) Kitchen Range Logo
Top Falcon Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Falcon Kitchen Range Expert? Answer questions, earn points and help others
