Question about Nikon 3-9x50 Prostaff Riflescope In Matte 6313
I have a 3x9x50 prostaff scope i mounted it on a 7mm rem mag will the point of impact change with increase in magnification @100 yards.
  • Anonymous Mar 23, 2014
    what best scope for 7mm rem mag ?
    President:
  • 2,702 Answers
You must zero the scope on full mag =x9 at 100 yds first then it should be ok,
Posted on Nov 25, 2010
Savage 110 7mm serial num f255638 what year was it made
Try the resources mentioned in these forums. Savage used to have them on their site, but appear to have suspended the service.
Savage model 110 date of manufacture? ' The Firearms Forum
www.thefirearmsforum.com > ... > Technical Questions & Information Jun 21, 2010 - I have a Savage Model 110, 7mm Rem Mag with the serial number. ... I'm trying to get all my guns info on record and was wondering if anyone could tell me the year of manufacture for this rifle? ... but absolutly cannot find the exact year of manufacture?
What Year And Month Is A Savage Rifle Model 110(7mm ...
www.gunvaluesboard.com/what-year-and-month-is-a-savage-rifle-model... What year and month is a Savage rifle model 110(7mm) Serial#. ... what is the value of savage mod.110 7mm mag with simmons 3x9x32 synthetic s.
Savage 110 Date of Manufacture - Savage Shooters
www.savageshooters.com > ... > 110-Series Bolt-Action Rifles Jan 15, 2013 - 15 posts - ‎5 authors The model number is 110L-H in 7MM REM MAG and the serial number ... the bolt and barrel is 131057 any ideals when this Savage was born. Savage 110 5 digit serial number 6 posts 13 Dec 2014 Thread: LH model 110 EL series K 7mm Rem Mag 4 posts 20 Mar 2013 More results from www.savageshooters.com
Jan 25, 2016 | Optics
How to adjust rifle scope
You need to sight in the scope and rifle to 100 yards then reset the dial making sure the knob as the manual says
do a check sight in
Then you turn on the electronics
the drop number you input is 112 and the BC is 55
as you haven't given an altitude for sight in or shoot site I have allowed for them being equal
you now shoot at a target at 400 yards and for each inch below or above the aim point add or subtract 6 from the drop number
drop number entered is 112 and your shot is 4 inches low
4x6=24 so your new drop number is 136
and if 4 inches high the drop number is 4x-6=-24 new drop number 88 so you now change the inputted drop number to the ones you have and shoot a few groups at 400 to confirm point of impact and aim point and adjust accordingly
Forgot to explain that the 112 drop number is the calculated drop for your round at 750 yards and that you are changing it by confirming the actual drop at 400 and the scope is calculating internally for 750
Apr 10, 2017 | Burris Optics
How do i zero my tasco silver antler rifle scope
Start out at 25 yards. the scope is I believe used 1/4 inch clicks. This is for 100 yards so 16 clicks will equal 1 inch at 25 yards. Fire three shoots from a solid rest. Measure the distance left or right and up or down from the desired point of impact. and move the setting in the desired direction. ie uo is moving the point of impact up from where it is. and left or right is the same. Next fire at the desired distance and move point of impact to where you want it at that distance. If the scope is wandering all over the target make sure the scope is not moving in the mounts. If it persist in changing point of impact send it back to tasco for a replacement as it has a loose recticle. Better yet I can recomend Leupold or Burris as a better alternative if they are in your budget. Not quite a S&B or Ziess but **** close for a lot less $$$$$
May 24, 2012 | Optics
I lost the instruction manual for my 3x9x50 nikon prostaff scope.I would like to find another one so i can properly site my scope in.
Here is a link to where you can download the manual
http://support.nikonusa.com/app/answers/detail/a_id/14383/~/nikon-riflescope-instruction-manuals
Hope it was helpful?
Jan 30, 2011 | Nikon Rifle Scope Prostaff 39x50 Matte...
Leupold VX II 3x9x50mm scope on a rem. 270. One year old. Worked fine last year. Sighted in last week at range. Windage was dead on. Wanted to move up 1 inch in hieght at 25 yards. Tried to adjust hieght...
16 clicks is about 4" at 100 yards not 25. did you try shooting it at 100 yards? remember the scope is mounted at least an inch and probably higher than that above the barrel. at close range you will always hit low with a scope because the bullet has to climb at least an inch or more before it will be right on at 25 yards. if it is dead on at 25 it should hit way high at 100. (or the scope/ mounts are bad).
Nov 05, 2010 | Leupold ® Rifleman® 3-9x50 mm Scope
Loss of focus when izoom in
This typically means that you are have exceeded the scopes ability to focus at the distance that you are shooting. This scope is optimized for 50 yards and will function well at all magnification settings. Closer than this optimal distance the higher magnifications may present problems with blurring. Many scopes have a "parallax" adjustment that changes the optical focus to correct this problem. Several of my 22 mag scopes have this adjustment on the objective bell. You simply set the indicator line on the appropriate yardage indicator (making minor adjustments to fine tune focus). Hope this helps
Sep 16, 2010 | Simmons 22 Mag 39X32 with Rings
Sighting in, clicks don't move where they're supposed to.
Ja, it's 1/4 M.O.A, so at 25 yards/meter it'll be ca 3 inches. You may have gone in the wrong direction. That is, if it was 3' high, and you went another 3 higher then you'd be at the top of the paper. Probably you've got it figured out by now.
The easiest, fastest, cheapest way to zero is with a rifle rest you can clamp your scope into, or alternatively somehow immobilize your rifle some other way. You take a shot, at 25 yards or so. It makes a hole. You now immobilize the rifle, via your rest or heavy sandbags, with the scope pointing exactly where you aimed before. You now, carefully and without moving the rifle/scope off of the point of aim, dial your reticle to point at the actual bullet hole. Your next shot will be at your point of aim now. So you just put it at the right height above your point of aim at 100 yards now.
Nov 02, 2008 | Bushnell ® Elite® 3200 3 - 9x40 mm...
Nikon 3-9x50 Prostaff Riflescope In Matte 6313 Logo
255 people viewed this question
Top Nikon Optics Experts
George Merkley
George Merkley
Tom Chichester
Are you a Nikon Optic Expert? Answer questions, earn points and help others
