Question about iLO 3200 32 in. LCD Television
Composit #2 no signal
Cannot change channel or volum
    Sergeant:
  • 260 Answers
This particular model has problems with the control board. This is a common problem with this unit. You can find control boards on EBay, or through a local technician. Please refer to our online technician list for a professional near you.
Good luck :)
Posted on Jun 20, 2008
Why won't my Goodmans digtial box remote change channels or volume on the TV?
Think about it. The digibox remote should only change its own channels, not the TV ones. Otherwise the TV would never be on the correct channel to see the digibox signal.
As for the volume, unless the Goodmans remote is programmable to emulate the TV volume, then it will just change its own volume. The result is the same. The TV gets louder or quieter.
Sep 03, 2014 | Televison & Video
Why is the Goodmans digital box remote not changing the channels or volume on My Daewoo TV?
My Haier tv says "No Signal" & won't show my channel I did auto scan & it's still blue with a grey box saying "No Signal"
To eliminate if it's the cable problem or not, see if you're able to get a picture and audio on another input by connecting a dvd player as an example. If you're able to receive a picture and audio tehn you know that input works. If you can then try connecting a antenna to the tunner, assumming that you had cable connected prior, and scan the channels again but instead of selecting cable select air then channel scan. If you still are not able to receive channels, then you have a bad tuner. You will need to have the main assembly board AKA scaler board replaced. You could however by-pass the tuner by using a VCR and connect your cable to the tuner on the VCR then use Composite wires from the VCR to the TV composite input and change the chanels from the VCR.
Oct 23, 2013 | Televison & Video
Cannot function to cable? what will i do? they did not give any manual when i purchase
Standard CRT TVs generally have a couple of inputs that BYPASS the tuner portion built into the TV. If you are using a standard coaxial connection you should see the signal from your cable box on either channel 3 or 4 (you may have to set your TV to search for signals in the TV's setup menu). Otherwise you may be able to use a composite connection that uses a cable with tree plugs (red, yellow and white). When these are plugged into the cable box out put and the corresponding plugs on the tv, then tune to "input 1" or "input 2" by changes the channel downward below channel two. You should see your cable signal. Then you change channels using the cable box only and not the tv. Your manual may be available at no charge from the manufacturer's website.
Oct 19, 2013 | Televison & Video
Missing red composite signal on panasonic pt-47wx52cf
Check your jacks and cables.
The RED jack is either (1) left or right channel AUDIO signal or (2) the RED color channel of an RGB (Red, Green, Blue) COMPONENT video signal.
Yellow is the COMPOSITE video signal.
Dec 31, 2012 | Panasonic PT-53TW54 53" Rear Projection...
How do i get the TV to play satellite? it just says weak signal when I turn the tv on. JVC RM-C18G
It has to be on the right channel. If you are supposed to be on channel 3, 61, 73, 113 (ask the satellite company which one you should be on) then you'll have to change the channel. If you are not supposed to be on a channel you have to find out which input you're supposed to be on (video 1, video 2, video 3, av 1, av 2, av 3, hdmi 1, hdmi 2, input 1, input 2, input 3 for example).
Jul 19, 2011 | Televison & Video
My t.v. has volume issues. Volume between channels and also within one channel (while viewing) not even. Happened when connected to basic cable and now when connected to just an antenna for reception. ...
it is fixable the sound may depend upon the channels also but the antenne might not beeing catching signals properly so by changing the face of antenna u can remove this problem
Mar 31, 2011 | Panasonic TC-32LX85 LCD TV
I cant hook up the red,white, and yellow wires to my magnavox tv
If you mean that the TV doesn't have a set of composite video/audio jacks, then you need a converter for the inputs on the TV. (Most likely you need a video converter (RF modulator) that converts the game console composite video to RF (coax) and set the TV to channel 3 or 4 usually. RF modulators are available from stores like Radio Shack for $30.)
If you have a TV with a composite video input and can't get the game console to view, then there is a different problem. First try new cables. Switch your input as needed for both the TV and the game system. This will depend on the TV and if you have the original remote/unlocked front panel buttons on the TV or a substitute remote that maintains all of the features of the original remote. On some TVs you can cycle through to the A/V inputs by increasing (or decreasing) the channels until you are between channel 2 and the highest available channel. (This doesn't always work if the TV has been programmed to skip channels that previously had no signal.) Otherwise look for a Source or Input button on the remote or TV (or an OSD menu (sub menu) that lets you change the source).
I hope this helps.
Aug 10, 2010 | Video Game Consoles & Games
No signal
You have changed the input to a selection that does not have a signal. Look at where the cable goes into the TV, this should show the name of that input, then change input back to that exact one via your remote.
Apr 19, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Can't access AV Channel on Sony KV-C27TD
If the TV has no RCA inputs, then there is no "AV channel" option for it on any remote, just channel selection.
The purpose of a RCA to SCART converter (aka RF modulator) is to convert one of your channels to an A/V input. They operate (standard) on either channel 3 or 4 as selected by a switch on the converter.
If your converter is unpowered, it's entirely possible that the signal coming out is not good enough to overpower your antenna signal. In this case, you may need a powered unit (such as this one http://www.bestbuy.com/site/olspage.jsp?skuId=5806345&productCategoryId=abcat0107025&type=product&tab=7&id=1067388827858#productdetail) which can actively "shut off" the antenna input when signal is received from the auxiliary device.
Nov 13, 2007 | Televison & Video
iLO 3200 32 in. LCD Television Logo
26 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
