Question about Technics SA-AX6 Receiver
My tuner will play for a short time (fm radio)then shut off with a loud click and the message "OVERLOAD" appears on the display. Help! Thanks.
    Novelist:
  • 87 Answers
This is a common question on this site. Amps of all types have protection circuits to keep them from doing a self meltdown. Testing follows this logic.
1. Remove all speaker wires. 2. Keep the volume down - all the way. 3. Turn the unit on. 4. If it does not trip off, then there is a problem either in a speaker or the wiring. a. Reconnect one at a time until/unless it trips off b. That will tell you where to look further.
If it does trip off, then there is an internal circuit issue in the amp and probably requires professional help to fix.
Posted on Nov 10, 2010
FM Tuner not receiving - Yamaha R7 receiver
Take the cover off and look at the cable that connects the tuner to the main board. Make sure it is connected straight and tight. Make sure all screws in the back are tight, just in case it is a grounding issue. Iff all checks out and you still have issues, replace your tuner.
Apr 30, 2012 | Yamaha Audio Players & Recorders
How do i change the AM radio to FM?
Hello
Press RADIO BAND.AUTO PRESET until the band you want appears in the display (direct power on). Each time you press this button, the indication changes as "FM" --> "AM". Hold down TUNE + or --, until the frequency digit begins to change in the display. The player automatically scans the radio frequencies and stops when it finds a clear station. If you can't tuned in a station, press the button repeatedly to change the frequency step by step. If FM broadcast is noisy, press "MODE" until "Mono" appears on the display and the radio will play in monatural without any noise. Only strong FM signals can be decoded to stereo. OK.
Oct 22, 2011 | Sony CFD-S300 Radio/Cassette/CD Boombox
My Philips AJ3980 radio suddenly has no sound. Also, the band "MW" appears in the display and I'm unable to tune AM stations. The clock seems okay. Thanks for your help!
1. Press the RADIO button to switch on the radio.
- Radio touch screen controls appears throughout
radio operation
- The radio frequency and waveband appears in the
display for 10 seconds before reverting back to the
clock display.
2. Press the BAND button to select your waveband FM/AM.
3. Tune to your station manually or automatically
by using up / down.
Here is a figure to help find the control buttons:
Please change waveband to FM.
Thanks.
gylacz
Jun 20, 2011 | Philips AJ3980 Clock Radio
I WANT DRIVER AND SOFTWARE FOR PHILIPS SAA 7130 TV CARD-TV TUNER - FM
Click here to download drivers for Philips SAA7130 TV Tuner/FM Radio/Video
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Apr 04, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
Radio locked no code
Unlocking the Delco Radio Theft-Deterrent Feature After a Power Loss
If you know the code that was used to lock the radio then use the following instructions from the owner's manual to unlock the radio.
Quote:
Enter your secret code as follows; pause no more than 15 seconds between steps:
1. Turn the ignition on. LOC will appear on the display.
2. Press MIN and 000 will appear on the display.
3. Press MIN again until the last two digits agree with your code.
4. Press HR until the first one or two digits agree with your code.
5. Press AM-FM after you have confirmed that the code matches your secret code. The display will show SEC, indicating the radio is now operable and secure.
If you enter the wrong code eight times, INOP will appear on the display. You will have to wait an hour with the ignition on before you can try again. When you try again, you will only have three more chances (eight tries per chance) to enter the correct code before INOP appears.
If you don't know the code that was used to lock the radio then you will have to use the dealer's unlock procedure as follows. The dealer code changes over time - the one listed is current as of this posting. If it doesn't work try 08359 or search the forum for messages with a more recent code.
Quote:
1. Press and hold presets 2 & 3 for about 10 seconds until the first three digits of the display code are displayed.
2. Write the numbers down.
3. Press the AM-FM button, write down the next three numbers.
4. Call 1-800-537-5140. When asked, enter dealer code 202108, press the * button, and enter the six digit code from the radio. You will get an unlock code, write it down.
5. Go back to the car, press the HR button and set the first two numbers, press the MIN button and set the next two numbers, then press the AM-FM button. The display will show SEC, indicating the radio is now operable and secure.
To remove the code, repeat step 5. you should see --- on the radio face indicating the code is now out of the radio."
Dec 29, 2010 | 2000 GMC Jimmy
How to play fm using tv tuner.i mean i'd purchased tv tuner but and installed driver and software provided with it.now give me directions to play my local city fm channels on it.
use the remote control that comes with the tv tuner package. click fm. wait to initialize then presto...fm it is! Just choose ur channel and enjoy.
Dec 13, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
How do I record FM radio programs and transfer them to my computer?
unfortunately, the voice recorder works only as voice recorder, it cannot play FM and record it at the same time. though you can play fm radio from another device and record it using your SanDisk mp3 player.
To transfer your recordings from your mp3 player, connect your device to your PC.
Open "My computer" from your PC and you'll there "your Sansa Player"
Double-click on "your Sansa Player", then open the "Music" folder, then, open "Recordings" folder.
You'll find all your recordings on that folder.
May 14, 2010 | SanDisk Sansa Clip MP3 Player
IBOUGHT MY PHILIPS SAA7130 TV TURNER/FM RADIO THE MANUAL STATES THAT I MUST INSERT THE CD KEY FOR THE FIRST TIME WHEN ISTALING BUT I DIDNOT SEE THE OPTION WHEN INSTALLED MY CARD AND IT SAYS FM RADIO...
BOUGHT MY PHILIPS SAA7130 TV TURNER/FM RADIO THE MANUAL STATES THAT I MUST INSERT THE CD KEY FOR THE FIRST TIME WHEN ISTALING BUT I DIDNOT SEE THE OPTION WHEN INSTALLED MY CARD AND IT SAYS FM RADIO OPTIONAL BUT NOTHING IS PLAYING FROM RADIO
Mar 04, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Zenith Z212B CD clock radio
Have you done the presets on the memory. Do that then select the station you want to wake up to. Hopefully its fm. Per the instruction manuel . Set or adjust the alarm time if necessary. Press the Alarm on/off button if necessary until one of the alarm indicatior either the note or alarm appears on display when the buzzer alarm is selected. While the alarm time display is flashing press the tuner button to select am, fm, or tv band. The selected indicatior appears in the display ( Note : you can only select the band when you have selected wake to music. While the alarm time display is flashing press one of the preset buttons to select the station you wish to hear when the alarm goes off.
Apr 17, 2008 | Audio Players & Recorders
109 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Morne Olivier
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
