Question about Amana NAV5800AW Top Load Washer
The washer does not initiate a drain of either wash water or rinse water ( and consequently a spin ) of it own accord. Rather i twill continue to agitate and wash right through the normal rinse cycle as indicated on the timer/control. However if one interrupts the power by opening the lid or pushing the control knob in and then reapply power via lid or knob while the timer is in the drain or spin portion of the cycle, it will empty and spin. Thus I believe that all pump, motor, belt, transmission, and couple functions are working.
  • 2 more comments
  • sailorg Nov 10, 2010
    Caroldon,
    Caroldon,
    From your solution can I assume that even though the timer control knob
    continues to move through the marked cycles on the dial, it is still
    possible for the stepper motor or gear to be bad? It should also be
    noted that something is progressing in the timer because the washer will
    shut down when the dial indicates a completion of the wash program. A
    further question? Is it possible to take the timer apart to inspect it's
    inner parts such as gears contacts etc.? I also question the suggestion
    that a nudge due to the turning power on & off corrects the problem
    because an interruption of power using the lid switch (carefully and
    gently without nudging the control knob) also corrects the problem.That is, an interruption of power is all that is required to allow the programmer to recognize where the dial is set in the sequence and then continues to perform that portion of the program.
    George B.
  • sailorg Nov 11, 2010
    The washer does not initiate a drain of either wash water or rinse water ( and consequently a spin ) of it own accord. Rather it will continue to agitate and wash right through the normal rinse cycle as indicated on the timer/control. However if one interrupts the power by opening the lid or pushing the control knob in and then reapplies power via lid or knob while the timer is in the drain or spin portion of the cycle, it will empty and spin. Thus I believe that all pump, motor, belt, transmission, and coupler functions are working.
    Although the washer continues to agitate in the wash portion of the program the dial continues to progress through the rinse portion of the program until the machine finally shuts off at the end of the program. It should also be noted that something is progressing in the timer because the dial continues to move and the washer will shut down when the dial indicates a completion of the wash program. That is, an interruption of power is all that is required to allow the programmer to recognize where the dial happens to be at that time in the sequence and then performs that portion of the program.
    George B.
  • sailorg Nov 16, 2010
    This solution was helpful in that it confirmed my suspicion that the problem was in the timer. The replacement part is expensive and the solution gives me confidence that the purchase of a replacement part is not a waste of money.
    President:
  • 1,891 Answers
The motor/ trans / pump / belt / ect yes they are all fine the problem is the timer . the timer stopes the motor after the wash and starts it in the other dir to spin and drain . but this is not happing . so the timer is at fault . pt # 27001088 100.99 hope this helped mm feed back pls
Posted on Nov 16, 2010
  • Amana Master
  • 17,130 Answers
You seem to be right to confirm that the pump, motor, lid switch and moving parts are in order , functioning correctly. The problems seems rooted in the program timer unit as it is not energizing to move on to the next cycle as the contacts are not moved forward except with a manual nudge.
The timer unit can be checked with a good visual check while on a cycle to see if the timer works to move forward with the help of the stepper motor. It can be failure of the small stepper motor in the timer unit , failure of the gear tooth that moves the contacts or maybe a mechanical jamming in the drive . Put the set off and use a good de-greasing spray( WD(40), clean and reset the motor checking if this works, if not replace motor or the timer unit as you visually confirm with the wearing of the unit.
Posted on Nov 10, 2010
  • Donald DCruz
    Donald DCruz Nov 11, 2010
    You inference seems to shed some more light into the problem. If an interupption contacts to run the cycle then I think there is a relay action failure possible in the water level sensor or the lid switch that must give connection for the program to advance further.
    If so the timer should be working alright but the external trigger is not coming to the timer contacts for the cycle to continue.
    Please check the external attactments to the timer unit, , check if there is any click noise when the power is cut off or the lid lifted up , if so look out for a relay hidden somewhere which is not contacting properly or is in wrong sequence.
  • Donald DCruz
    Looks like that the timer can be a possible suspect. Might have to try if you can swap a timer to confirm, the fault seems relative to the timer or a possible relay in the unit
H6 error code on a NEC NFL-1065 washing machine
see this causes, and fix it. God bless you
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
f the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components
f the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Sep 26, 2012 | Washing Machines
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
My GE SpaceSaver Washer/dryer will wash, but when it's time to rinse and spin the machine stops. It will not drain, riinse , or spin.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jul 27, 2012 | GE Spacemaker Washer and Dryer Electric...
MY WASHER WHIRLPOOL LA5430XTW0 AFTER THE WASHING CYCLE IS DONE IT DRAINS OK, BUT DOESNT SPIN, AFTER THAT IT ADVANCES TO THE RINSE CYCLE BUT DOESNT DO ANYTHING AFTERWARDS, IT DOESNT FILL THE TUB, IT DOES...
hi Luis.
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump
If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Other Causes and Conditions
Clogged Pump or Hose
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt
If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly
If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose
If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap
If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
What do you do when your washing machine wont drain? Steps
  1. Consult your troubleshooting manual. Most washers come with a troubleshooting manual. ...
  2. Check your drain hose. ...
  3. Run the rinse/spin cycle on your washer. ...
  4. Clean the pump. ...
  5. Turn the handle counter-clockwise to remove the screen. ...
  6. Remove everything from the screen and rinse it off. ...
  7. Run the rinse/spin cycle again
https://www.wikihow.com/Fix-a-Washer-That-Won%27t-Drain
Dec 12, 2017 | Whirlpool Washing Machines
Maytag washing machine skips rinse cycle
I found this problem with mine intermittently and it was because i had filled the machine too full that it was too heavy to initiate the spin. maybe try a lighter wash?
Jul 03, 2009 | Maytag Washing Machines
Washer will not advance in the rinse cycle,water just runs continuely.
check the drain hose it should be only 6 to 8 inch in your drain line if drain hose is all the way in the drain line correct it and you will be fine.
May 21, 2009 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
MAYTAG NEPTUNE MAH9700AWW continues to fill on rinse, code "oe",
if the water continues to fill even with power off, and you have to manually shut in off at the wall valve, the 3-way inlet valve is stuck open. you have to replace it. $90
Mar 02, 2009 | Maytag Neptune MAH9700 Front Load Washer
Whirlpool AWN 321 washer continues to drain water out of drum throughout the whole wash and rinse cycles. The consequence of this is the machine continually draws in hot and cold water to achieve the...
This sounds like a siphon condition. Remove the drain hose (the thicker black hose from the back of the machine) out of the wall. Now re-insert it back in only 6" going into the drain. When they go in too far, the drain in your house that prevents odors from coming back out of your drain causes a siphon that pulls the water back out when the washer is filling. Make sure to tie the drain hose down with a tie so it does not pop back out when the washer is draining/ spinning.
Jun 30, 2008 | Whirlpool Washing Machines
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Amana NAV5800AW Top Load Washer Logo
140 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
