I have been told that I need to buy a new gas fire because the thermocouple is not working and needs replacing.Unfortunately the fire is approx 10-12 years old and no longer made hence the heating engineer cannot locate a thermocouple anywhere which is specific to this fire (Britaflame).Do I have to buy a new fire or is there another option?
    Genius:
  • 1,015 Answers
I think before I went to the expence of buying a new fire place I would remove old thermocouple and take it to a heating equipment supply house and see if they can find a replacement. Most equipment manufactures don't make their own controls, such as thermocouples,gas valves ,sensors and other equipment. Many chain stores such as true value have good knowedgable people and if they don't have what you need they may know someone that does. I hope this helps you. thanks
Posted on Nov 09, 2010
Will not stay lite
probable wants a new thermocouple ( F F D flame failure device.)
or its not set directly in flame , or your flame jet is parsley blocked and the thermocouple is not hot enough to hold the gas valve open.
THERMOCOUPLES when hot generate a minute voltage that creates a magnet affect in the gas valve and holds it open if the thermocouple is burnt out or not set correctly the flame will not stay on . the black mark on your fire is a sign the gas is not burning correctly at that point causing ,may be due to oxygen
starvation , my suggestion is when the fire is off and cold give the part around the thermocouple a good vacuum to remove any build up of fluff /dust. if this does not work you need to get the thermocuple replaced and the fire serviced. good luck
Nov 19, 2016 | Cars & Trucks
Patio glow outdoor propane fire pit does not stay lit
Fire pits motivated by gas. Need suffocation. A natural fire needs oxygen. Gas fires need suffocation. Take the wood or rocks and make it tighter over the gas holes. Meaning Pile the rocks on top of gasoline tighter or more generously so the gas and the flame are not coming out hitting straight oxygen. Give the fire something to hold onto. Natural fires need the opposite. Propelled fires need a sauna /steam room / hot rock type of relationship.
Aug 13, 2014 | Heating & Cooling
How to replace thermocouple in 42v50-50f
Copy following link:
http://waterheatertimer.org/How-to-replace-thermocouple.html
Rheem 42V50-50 is ordinary atmospheric-vent gas water heater with mechanical (non-electronic) gas control valve, which says that unit has ordinary thermocouple, and not thermopile.
Buy generic thermocouple from local hardware.
To replace the thermocouple you need to remove entire burner assembly from water heater, and have replacement Burner access door gasket on hand. 1-800-268-6966
Combustion door held in place with tamper-proof screws
Since the water heater problem may be more complicated than just the thermocouple, and water heater flame arresor screen may need to be cleaned, and burner parts cleaned, door gasket replaced, and gas pressure checked, and piezo electrode checked, it might be best to have qualified service technician do the work for $300.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 28, 2012 | Rheem Water Heaters
We have not turned the heater on since 2010. it is a gas with fake logs.A rennai flame fire inbuilt standards. Husband says the thermacouple is not working? what do you recommend?
Stephanie, I 'm not sure how it was determined, that your direct-vent gas fireplace needs a Thermocouple? As a dirty pilot light will also mimic a faulty thermocouple. In addition, if the fire hasn't been used since Winter of last tear, and the gas line to the unit has been turned OFF since then, the air in the gas line must be purge, before the Pilot will light and hold.
If all of the above can safely be ruled out, then the thermocouple should be replaced. The facing of the fireplace will have to be removed, to access the Thermocouple.and it's connections to the gas control valve. You didn't mention which Rinnai Gas Fireplace you have, but most if their units, use Thermocouple part # 90193475. If you're going to replace it, it would be a good idea to also replace the Thermocouple Retainer, part # 9377.
I hope this helps you to further troubleshoot and solve the problem. Please let me know. Thanks.
Jun 21, 2011 | Rinnai Heating & Cooling
I can not light the pilot on my reliance sta-kleen 502 (30 gallon) waterheater. please help
Reliance is Rheem
Replace thermocouple is best start point.
Example Whirlpool manual shows general replacement steps on page 22:
Buy thermocouple at hardware or home center. measure length before going to store.
http://waterheatertimer.org/pdf/Whirlpool-6510397.pdf
Utube videos show how to replace thermocouple
Many things can affect pilot:
Low gas pressure, Water or air or debris in the gas control valve, High-heat event causing ECO to trip requiring new gas control valve, burner and tubes needing clean-out, FV sensor tripped, loose or bad thermocouple.
Manual above shows general steps for doing some of these things, but service technician is probably best choice if thermocouple does not fix problem.
Gas water heaters require periodic maintenance.
If repairs cost more than $330, then buy new gas water heater and install yourself.
Use the old one for a solar collector.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 22, 2011 | RELIANCE ELECTRIC WATER HEATER
My reliance sta-kleen 502 gas water heaters' pilot will not lihgt. can some one give me an idea what to do.
Reliance is Rheem
Upvote the help.
I havge an older RLP 100, When turn the knob counter clockwise to the low position and push it down the fire ignites. As soon as I let up on it the flame goes out. I held the knob down for a minute or so...
This could be that you just need to reseat the thermocouple.
Try this before you purchase new parts.
You can go to www.allpartsinc.com to purchase parts.
Just remove the end of the thermocouple from where is goes into the gas valve and leave the end that goes into the flame in place.
Clean the end of the thermocouple connect by scraping off just a little metal from the end just about there the nut tightens the thermocouple into the gas valve. After you have exposed some new metal do the same inside the valve where the thermocouple seats into the gas valve.
Use a small pic or similar item to scrape inside the gas valve to expose some new metal there also.
Now reassemble the thermocouple into the gas valve and see if the heater works.
Here is a link with some more instructions.
http://www.msservice.net/ts/reseat_thermo-clean_pilot-ODS.htm
Oct 17, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Williams Wall Heater thermocouple replacment I was told by service person that the thermocouple needed to be replaced on my 1992 50,000 BTU wall heater. He quoted $300 for the job. Doesn't this estimate...
A standard thermocouple will cost you approx $10.00 to $20.00 at a hardware store. I'm including a link to a site with a video to help you identify and replace the thermocouple. The video demonstration is on a gas-fired water heater; however, the principle operation and replacement of the thermocouple is the same for a standard gas-fired furnace. Let us know if this was helpful to you and good luck in your endeavor! :-)
http://videos.howstuffworks.com/discovery/34524-gimme-shelter-replacing-a-thermocouple-video.htm
Mar 05, 2010 | Heating & Cooling
Kenmore Water heater, Model # 153.339462, Pilot lights, burner burns for approx. 10 - 15 minutes then both go out. after which it is more difficult to light the pilot, and it goes out again in less time...
The thermocouple is the copper one the other is the gas supply to the burner check your flue pipe for restrictions see if a flame from a lighter sucks up the flue from the top hood you may need a new gas control valve
Nov 04, 2009 | Water Heaters
Furnace pilot problem
check the pilot gas pressure, might be too weak and blowing out when the blower starts, the clicking noise is the gas valve shutting down when it detecks no pilot flame, that park is normal.
Jan 10, 2009 | Honeywell Power Humidifier: Furnace...
Heating & Cooling Logo
144 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
