Question about Rangemaster Ballista 619004 Kitchen Hood
I have a used rangemaster 643600 , I can't find the manual. The vent is 36 " wibe and 10" high and 21" deep . What is the recommended height to the underside of the cabinet above . Thanks Terry
I have a 1999 Ford contour lx neither the brake lights nor the turn signals will work what would cause this
a fuse number 24,,,
The following specifications are for the Ford Contour and Mercury Mystique manufactured throughout 1995-2000.
Fuses Rating Color Circuit Engine bay fuse box 1 80 Black Power supply to main fuse box 2 60 Yellow Radiator fan 3 60 Yellow ABS 4 20 Yellow Daytime running lights 5 30 Light green Fog lamp 6 30 Light green Not used 7 30 Light green ABS 8 30 Light green Air pump 9 20 Light bue PCM module 10 20 Light bue Ignition switch 11 3 Violet PCM memory 12 15 Light bue Horn & hazard flasher 13 15 Light bue Oxygen sensor 14 15 Light bue Fuel pump 15 10 Red Right-hand low beam Passenger compartment fuse box 16 10 Red Left-hand low beam 17 10 Red Right-hand high beam 18 10 Red Left-hand high beam 19 7.5 Brown Heated door mirrors 20 10 Black Windshield wipers 21 30 Light green Electric windows 22 7.5 Brown ABS 23 15 Light bue Reverse lights 24 15 Light bue Brake lights 25 20 Yellow Door locks 26 20 Yellow Main light 27 15 Light bue Cigarette lighter 28 30 Light green Power seats 29 30 Light green Heated rear window 30 7.5 Brown Engine management 31 7.5 Brown Instrument pannel lights 32 7.5 Brown Radio 33 7.5 Brown Front and rear sidelights (left) 34 7.5 Brown Interior lighting & clock 35 7.5 Brown Front and rear sidelights (right) 36 30 Light green Air bag 37 30 Light green Heated blower 38 Unused Relays Color Circuit Location Engine bay fuse box R1 Green Daytime running lights (Canada) R2 Black Radiator fan (high speed) R3 Blue AC cut-out R4 Brown AC clutch R5 Dark green Radiator fan (low speed) R6 Yellow Starter R7 Brown Horns R8 Brown Fuel pump R9 White Low beam headlights R10 White High beam headlights R11 Brown PCM power supply Passenger compartment fuse box R12 White Interior and courtesy lights R13 Yellow Heated rear window R14 Yellow Heated blower R15 Green Windshield wiper motor R16 Black Ignition R17 Unused R18 Black One touch window switch Driver's door R19 Blue Cruise control cut-off Central fuse box bracket R20 Unused R21 Unused R22 White Fog lights Interface module bracket R23 Black Turn signals Steering column R24 White Left-hand flasher Door lock module bracket R25 White Right-hand flasher Door lock module bracket R26 Unused Bulbs / Lights Wattage Type Low beam headlamp 55 9006 Halogen High beam headlamp 55 9005 Halogen Parking / Side light 5 2357A Wedge Front turn signal 21 2357A Bayonet Rear turn signal 21 1157 Bayonet Tail light 21 1157 Bayonet Stop light 21 1157 Bayonet High mount stop light 5 2723 Bayonet Fog/Driving light 55 893 Halogen License plate 5 6418 Festoon Reverse light 21 1156 Bayonet Front sidemarker 5 2357A Wedge Glove box Map light 5 64111 Wedge Dome light 10 6411 Feston Step/Courtesy light Trunk/Cargo area Engine compartment 10 89 Wedge Instrument-general Automatic trans indicator
Apr 15, 2015 | 1999 Ford Contour
Fuse box layout for 2005 honda crv
No. Amps Circuits Protected 1
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38 7.5
15
10
7.5
(15)
(20)
_
10
7.5
7.5
10
10
10
7.5
7.5
10
10
20
15
7.5
20
_
_
(20)
20
20
(20)
15
15
20
(15)
20
20
7.5
7.5
10
7.5
30 Power Window Relay
Fuel Pump
ACG
ABS/VSA
Heated Seats*
Front Fog Lights*
Not used
Rear Wiper
ODS (Occupant Detection System)
Meter
SRS
Right Headlight High Beam
Left Headlight High Beam
Small Light (Interior)
Small Light (Exterior)
Right Headlight Low Beam
Left Headlight Low Beam
Main Headlight High Beam
Small Lights MAIN
TPMS
Headlight Low Beam
Not used
Not used
Moonroof*
Door Lock
Front Left Power Window
HAC Option
Rear Accessory Socket
Accessory
Front Right Power Window
Accessory Power Socket on the Center Table*
Rear Right Power Window
Rear Left power window
ACC Radio
ACC Key lock
HAC
Daytime Running Lights
Front Wiper * If equipped
Dec 06, 2013 | 2005 Honda CR-V
We bought a brand new dual fuel Rangemaster cooker and the adaptation of our bungalow and building works have now been completed and ready for the cooker to be installed. However, my husband ( who has a...
I used to have the same range with 2 electric ovens, but it is available with the lower large oven on gas and the tall oven electric.
The manual for theToledo with tall electric and large gas oven can be found here:
http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/Toledo90Gas.pdf
The manual for theToledo with both electric ovens can be found here:
http://www.rangemaster.co.uk/media/575792/toledo%2090%20dual%20fuel.pdf
The main product page for the toledo 90 can be found here:
http://www.rangemaster.co.uk/range-cooking/toledo-90.aspx
Sep 16, 2011 | Rangemaster Toledo 90 (Dual Fuel) Dual...
I have an old GE Microwave jvm240av001 and would like to know the specs so I can replace it. It is so old (1995) I can not find anything on line. Please let me know if you can help. Thanks so much!
Hi and welcome to FixYa, I am Kelly
(trim kit required)
For all newer units the dimesnions are
15 & 3/4" high 16 & 1/2" high hole required for vent connection in rear
15" deep
Needs a 30 inch wide hole for installation
or call GE 1-800-626-2005
Use this link for all models OLD and NEW:
http://www.geappliances.com/service_and_support/literature
To get dimensions you look up installation manuals for each model.
Your manual cam up here: (1.51 Mb)
http://www.geappliances.com/search/older-pdfs/49-8621.PDF
Your microwave is not vented externally but your replacement microwave will be capable of being used in a non-external vent and an external vent cofiguration. Personally.... I would recommend the external vent installation. Either will work.
Thanks for choosing FixYa, Kelly
Sep 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Multiplication table
x 01 02 03 04 05 06 07 08 09 ...
01 01 02 03 04 05 06 07 08 09 ...
02 02 04 06 08 10 12 14 16 18 ...
03 03 06 09 12 15 18 21 24 27 ...
04 04 08 12 16 20 24 28 32 36 ...
05 05 10 15 20 25 30 35 40 45 ...
06 06 12 18 24 30 36 42 48 54 ...
07 07 14 21 28 35 42 49 56 63 ...
08 08 16 24 32 40 48 56 64 72 ...
09 09 18 27 36 45 54 63 72 81 ...
Jun 15, 2010 | Mathematical Technologies Inc. MTI Tristan...
I am looking for the dimension and capacity of fridge 69852990
Measure Exterior Height & Width and Depth for Dimension.
Interior Space = Then, Measure all open accessible area inside the fridge and add the two together, following the formula of H+W+L Freezer and H+W+L Refrigerator,add together and BAM ya got cubic inches.= Square inches, then divide by 1,728 (the number of cubic inches in a foot (3) Cubed.
Example 1: 60 inches tall, 42 inches wide, 30 inches deep = 75600/1728 = 43.75 Cubic Foot AREA
Example 2: fREEZER dIMS = 24 DEEP x 18 HIGH x 36 WIDE =15552/1728 is 9 CuFt. Refridgerator 36 wide, 36 high 28 deep = 36,288/1728 = 21 CuFt. + 9 CuFt. = 30 Cubic Foot Capacity.
By the Math Wiz RUDY :)
Apr 18, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Oil for yardman lawn mower
Only 30wt DETERGENT HIGH QUALITY oil, never use NON detergent or 10-40. Takes approx. 20 ounces to fill
May 27, 2009 | Mtd LAWN MOWER PART # 782-0082A-0638 DECK...
Can I mount a Delta 36-T30 T2 30-Inch Fence and Rail System on my
I just installed a Delta T2 fence on my 10" Craftsman Table Saw. It's 27" deep. The bushing either could be relocated or you could use spacers on the front, back, or both on the saw to get the required distance. Also, you'll have to drill new holes, however, I used one of the existing holes in the front and back of my saw as well.
Mar 11, 2009 | Delta 36 T30 T2 30 Inch Fence And Rail...
Rangemaster Ballista 619004 Kitchen Hood Logo
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Mike Carew
paulcarew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
