Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
How can i reconnect wireless network back on to new computer when i have forgotten pass word
  • 45 Answers
If you have forgotten the password you can completely reset the router. there is a button somewhere on the router that resets the router back to factor defaults.
here is an article that tells you how to reset reset it:
http://www.dslreports.com/faq/13631
I hope this information was helpful, If you have any comments or question please reply to this post and i will help as much as possible
Posted on Nov 09, 2010
Rembering a forgotten wifi network
I'm guessing you may have tapped on the network and hit "forget"? if this is the case you simply need to go to your wireless settings and manually reconnect to the wifi (you will need to know the wifi name and password).
make sure the network is in range and shows up in the available network list, if it does not and you know you are in range, it may either be the network itself is not broadcasting or your device may not have the wireless turned on/ functioning correctly.
hope this helps.
Dec 30, 2013 | Amazon Tablets & eReaders
I'm trying to sign into my Netgear Router to reset my password, because I do not remember it and to set-up a secure connection. However whenever I type in http://routerlogin.net, All I get is information...
How to View or Change Your Wireless Network Password Symptoms:
  • You have lost or forgotten the password to your wireless network
  • You have lost or forgotten the password for the router, access point or other network device
  • You left the default password or used a weak password and someone has hijacked your network
Depending on the router, you can either view or reset the wireless network password (also referred to as the passphrase or security key) if you can log into the router. Some routers mask the wireless network password, so while you cannot recover it, you can enter and save a new password.
If you cannot log into your router because you have forgotten the router password or your network has been hijacked, please refer to "Lost or forgotten password for router or other device" below.
To view or reset a wireless network password:
  1. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  2. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
  3. From the center screen, select your encryption type from under the Security Options heading.
    • If the wireless network passphrase is visible, review it and use it to log devices onto your network.
    • If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
If you cannot log into your router:
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
If you have changed the default password and have forgotten the password, you may need to reset the NETGEAR device to factory default settings.
When a NETGEAR device resets, it goes back to the state when it was new - all information that was entered by hand is lost! Examples include critical things you need to get online, such as ISP username, ISP password, IP addresses, wireless security keys, and ports and services that were opened. It all needs to be re-entered.
So, have your ISP information before resetting the router.
Naturally, if you moved to a new city, or if you bought a used router, the old information in the router may not be of use to you. Contact your ISP if you can't connect any computer directly to the Internet. Then, if there is a connection problem when the router is added, see No Internet Access Through the Router
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
For DGN2000 / DG834Gv5 Routers
To restore the factory default configuration settings when you do not know the login password or IP address, press both the Wireless button and WPS button on the side of the modem router for 5 seconds.
For FR314, FR318, and FV318
These routers require reloading the firmware in order to recover from a lost password. Download the most recent firmware from NETGEAR's Web site before proceeding. Follow the instructions in the manual.
For routers with a 9-pin manager port on the rear panel: RT314, RT311, RM356, RT328, RT338, RH340, and RH348
See Updating Router Firmware That Uses a Manager Port.
This applies to:
  • All NETGEAR devices
Related articles:
Mar 26, 2011 | NetGear WGR614 Wireless Router
I am getting the message "Limited or Non Connectively" are two new devices I have added to my wireless network.
Please Turn off all electronic devices for 30 seconds and turn them back on. This would include the computers as well. Also when connecting to the wireless device, if you have it set to automatic connect, please disconnect from it then reconnect by finding the wireless network and reconnect. This should work for you, please let me know if this is any issues still and I will help you for free :)
Sep 30, 2010 | Linksys WRT160N Wireless Router
Acer can't connect to wireless network
Given the Acer sees the network, the times I have been frustrated connecting a new computer to a wireless network, it's usually been something very simple. I have forgotten one setting, transposed a letter or number. Go back through and make sure everything is exactly right.
Apr 29, 2010 | Acer Aspire One Netbook 8.9" Notebook
On my D-Link Dir-825 Wireless Router, can I change my wireless networks name without having to go around reconnecting all the computers in my house afterwards
If your network is "unsecure", which means no pass keys will be provided by client computer when they connect, then you can do it. Just change your SSID from your router's admin interface and your connecting computers will recognize it as a new network and try to negotiate connection. If there is a passkey, then the connecting computers will be prompted for a pass key (though it is an old pass key) since they recognize it as a new network.
Feb 01, 2010 | D-Link DIR-825 Wireless QuadBand Router
I need to reset the wireless network key
If you have forgotten your password to log into the unit, you can get it back to the factory defaults by pressing and holding the reset button on the back of the unit for approximately 5 seconds
If you can log into the unit, you can reset it through the menus.
Sep 13, 2009 | Linksys Wireless-G WRT54G Router
Have forgotten NetKey password to add laptop to wireless network
Just reset the router and you can configure it again like before.
Jul 01, 2009 | Linksys Wireless-G WRT54G Router
Need to retrieve pass word
If you have a new router, try accessing your router configuration page and set a new wireless network name and a new wireless password.
Jan 30, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Have forgotten my pass code foe my netgear wireless router
there will be a button at the back usually that you can press in for about 10 seconds.
this will restore the router back to factory settings.
Dec 24, 2008 | NetGear WGR614 Wireless Router
I would like to add a new laptop to my wireless network but have forgotten the password for the network. I am using a Belkin wireless pre n Router F5D8230-4. How can I find the password to setup the new...
If you dont know the password or have forgotten it, just remove the power and hold the reset in under the bottom of the unit in, reconnect the power and count for 7 sec. lights will flash and the password will be default again. It resets it back to factory settings.
Jul 20, 2008 | Belkin Computers & Internet
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
