- Stop the Microsoft Exchange Search Indexer service. Run Stop-Service MSExchangeSearch if you are into Shell.
- Browse to where the database files are located on the disk. Along with the database file, you will see a folder with "CatalogData-random string" as its name. Delete this folder, which stores the corrupt index.
- Restart the Microsoft Exchange Search Indexer service. Run Start-Service MSExchangeSearch if you are into Shell.
- Give it a minute and a new folder will be created and a new index will be built.
If you are still experiencing the issue after applying this fix you can tryExchange Server Repair Toolbox https://www.repairtoolbox.com/exchangeserverrepair.html
Please elaborate the exact problem facing with exchange server. Earlier I came across through a discussion where corruption of exchange edb file and extraction of mailboxes data from that edb file was discussed. In conclusion, got that a exchange server recovery application is helping against exchange crashed, down times & all issues.
To reset your phone: 1. Press Menu/OK > Settings/Tools > Settings > Security. 2. Enter your lock code. (The Security menu is displayed.) 3. Select Reset Settings. 4. Select the option you want. 5. If you are sure you wish to reset the selected option, press Yes (left softkey).
This is taken from the user guide for the motorola ic902 found here http://www.sprint.com/cdma/assets/pdfs/phone_guides/motorola/ic902_ug.pdf
If you are yet to travel, unlock codes will be the best way to be able to use your phone anywhere. The Samsung ic902 unlock codes will permanently unlock your phone from other network. Once your phone is unlocked, you could just simply swap your SIM so you could save on roaming charges. Just purchase the codes from a SAMSUNG UNLOCK CODE website. thanks
There is no problem just take out the old and place it in the new one the only thing that you should consider (if you care for it) is the data such as your pics any document, when you deside to change download your files on to a compurter and re-install it on your new I hope this was the answer you where looking for.
Be sure you have the proper drivers from the DELL, there are 2 listed for your model If you are certain your using the correct driver, then perform a search on your PC for the file that is referenced. You can manually enter the path to the file and use the same path for additional files that are not found.
1. Press the Menu/OK key, select Settings/Tools, select Settings, and then select Security.
2.
Enter your lock code. The Security menu is displayed.
3.
4.
Select Phone Reset.
5.
If you are sure you wish to reset the phone, press the Left Softkey to select Yes.
need a driver to put music on my ic902 phone
i don't know how to put music on my phone
i cant download the pictures from my ic902 to my computer?????????????????
