Question about Garden
How to I change bits in the Dewalt DW272 type 4?
2 Suggested Answers
smjdragonfly
  • 79 Answers
SOURCE: how do you load screws in Dewalt DW272WT VSR
You definitely need a hex-bottomed screwdriver bit. Please rate me
Posted on Jun 18, 2009
What is the best lubricant to use on my dewalt hammer drills please
It depends to where you want to apply your lubricant.
If you want to lubricate the chuck with the sds drill bit you simply add some cheap grease on the drill bit and the drill bit will slide easily on the chuck. On the other hand if you want to lubricate the sds drill machine then there is a special type super grease that you can buy from Dewalt in order to do so. Also since in order the super grease to be needed this means that you have used the drill a lot then also is needed to change o-rings, brushes and so on. So usually you have to ask for a service center to do it since they know how to do it properly and using the right kit.
Oct 18, 2014 | Dewalt Drills
How do i insert bit in cordless dewalt keyless hex chuck?
It only accepts 1/4" hex shank bits and nut drivers. Mine just pops in and to release it, you push the black collar around the bit down. Cannot put round end bits in it. Only hex shanks
Oct 26, 2013 | Dewalt DW056 18 Volt Cordless Impact...
Magnetic Extension for Dewalt Drill Bit
I have the same problem and am thinking of cutting that extension to get it out. A real pice of !@#$$%
May 13, 2012 | Dewalt DCF815S2 12-Volt Max 1/4-Inch...
My dw272 type4 don't work with new brushes
in most cases we have seen with dewalt drills the fault is corrosion around the power points to the motor they snap off if this is not the case then it will be the trigger switch
Jan 03, 2011 | Dewalt Drills
Hi, I have a dewalt dc925 drill. When running the
They all do that a bit. The sparks when starting up and stopping are normal. If it has been used alot brushes may be a good idea but before they need to be changed it will spark quite a bit.
It will not hurt to inspect the amount of brush material remaining.
Jan 04, 2010 | Dewalt DC925 Cordless Drill
How do you load screws in Dewalt DW272WT VSR
Jun 09, 2009 | Dewalt Drills
Hearing protection statement for use
If this is a Dewalt tool as the picture indicates I would go to Dewaltservicenet.com and type in your model number for a manual, I also believe there is an area that you can click on for this information
Sep 15, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Garden Logo
488 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
