Question about Brother MFC-3240C All-In-One InkJet Printer
My paper keeps jaming - Brother MFC-3240C All-In-One InkJet Printer
    Top Expert:
  • Brother Master
  • 11,573 Answers
Paper keeps jaming - Brother MFC-3240C All-In-One InkJet Printer
Posted on Aug 03, 2016
  • 425 Answers
Hi, the flashing error code that indicates a jammed printer is the digital-age equivalent of a flat tire. Sooner or later it happens to everyone, so you'd better know how to get things moving again if you want to finish your print job.
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Turn off the printer.
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Tips & Warnings
If you get toner or ink on your clothing, wipe it off with a dry cloth and then launder the clothing in cold water.
Watch out for loose toner or ink on jammed paper, and do your best to avoid spilling it on yourself or the printer. If a little bit of loose toner or ink gets in the printer, though, it should clear after a few sheets are printed.
Hope it helps.
Posted on Nov 09, 2010
My dell All-in-one keeps syaing it is jamed but there is no paper in. I have done everything that the web cite tells me too and it is still saying it is jamed.
Printers are a pain. Having said that, if there is a sensor claiming to have a paper jam, then it is one of 2 things: a piece of paper or debris that you dont see, or, a failed sensor. If you cannot clear the jam, you likely have a failed sensor. If you have a failed sensor, your easiest option is replace that printer. If you replace it with an identical model, you wont need to buy anything extra, you can use the same carts and plugs and discs as before. Check ebay or such places for your model. Someone may have one for you.
Oct 26, 2009 | Dell 924 All-in-One InkJet Printer
Paper keeps jaming when trying to print fax it
If the jam is consistent with exiting the drum, there's a chance the drum isn't secure and is the paper is getting caught on the exposed area of the drum. If this isn't the case, there may be paper caught in the feeder wheels.
Oct 18, 2009 | Brother IntelliFAX 4100 Laser Fax
PAPER JEM WHILE PRINTING. I NEED A HEIP TO REPAIR THE PRINTER.
first, if thare any paper is jamed in the paper tray, pull the paper stright out. take out the remaining paper. close the paper tray.
opne the front cover pull out the toner cartirdge, remove the jamed paper.
open the inner door (where the paper exit). make sure there is not paper jamed it.
close the front door. if any paper jamed inside of the machine, it should automatically eject it out.
Note: reset the printer by opening and closing the front door.
Apr 03, 2009 | Samsung ML-2510 Laser Printer
My MFC 5890 cn Brothers printer paper keeps getting jamed and won
What kind of paper are you using?
Normal paper or Photo Glossy paper?
If you use Photo Glossy Paper, you have to put at least two sheets of paper. If you read the photo glossy paper instructions that came in the package you will see it.
The package brings one sheet more than mentioned because of this specification.
Mar 23, 2009 | Brother MFC-5890cn Color Flatbed...
Paper keeps jaming
problemwith the roller or with the gear which is attached to themotor
Jan 10, 2009 | Lexmark X83 All-In-One InkJet Printer
Cannot print anything. Paper goes in halfway and then says 'paper jam'. Checked back - no jammed paper. Keeps on doing this. Have been in to cancel print but keeps saying paper jam. Have tried a print test...
Dear Customer,
you ahve to use batter quility papers for prints,
cause when paper fixed up your printer says its jammed but as realesed its says printing but when ALL THINGS DOIN VERY FAST JAMMING & PRINTING ITS SEEMS LIKE PAPER JAMED ALSO SAW YOU AS PAPER JAMED,
so try to check your inner cartrige,ink & paper rolls,batter quility papers you ahve to use,
THNX
May 18, 2008 | HP Computers & Internet
Brother MFC-3240C All-In-One InkJet Printer Logo
201 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
